Jason in tn's 1986 4Runner Build-Up Thread
Old Jan 22, 2014 | 07:13 PM
  #1281
jason in tn's Avatar
88 build thread
https://www.yotatech.com/forums/f199.../#post52160807
Old Jan 22, 2014 | 07:14 PM
  #1282
Originally Posted by Grego92
Hahhaha...nah, believe me I kept up on your thread and knew what you were dealing with. I would've went to the Master long before you did.
Look forward to a new build thread 88' SR5 V6 Auto. I just found the same exact vehicle for my buddy's son except it was a manual, we picked it up and trailer'd it back about a month ago. He's gotta rebuild the engine as it had a thrown rod. I was very close to keeping it for myself, but with my current/upcoming Camry project I decided to give him first dibs.
the details on this one is about the same.
Old May 27, 2014 | 09:27 AM
  #1283
Wow long time since an update. Plans on how to get this old girl back on the road keep changing, the plan was to drop it off with terry and let him have at it, I would still like to go this route but it's just not worked out to get it up to him. So after much encouragement from Terry I again have her back in the shop, the fuel tank is out and soaking, I knew it would be nasty but it was way worse than I expected since I'd already soaked it before while still in the truck. Pulled the injectors again terry and both think the problem is all 4 are plugged, the screens look clean but they could be just stuck. I haven't decided whether to clean and use these if I or terry can get them to work or pick up a set of flame throwers that decision will be made soon. I need to retest the injector wiring to make sure I'm getting signal if not that will be a whole new can of worms, but the system needs cleaned and sealed anyway so that's where I'm starting. I did the noid light test but I'm not sure I did it correctly so that's the next step. Hopefully have some answers soon. Thanks for checking in
Old May 27, 2014 | 11:21 AM
  #1284
Terrys87's Avatar
Here is couple of links I thought you would be intrested in.
https://www.yotatech.com/forums/f189...unners-280703/
Complete fuel pump kit http://www.ebay.com/itm/NEW-HERKO-FUEL-PUMP-MODULE-REPAIR-KIT-E8023-FOR-ACURA-CHEVY-DAIHATSU-1983-1996-/380876491960?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1986%7CMake%3AToyota%7CModel%3A4Runner&hash=item58ae020cb8&vxp=mtr
This one doesnt have the screen with it http://www.ebay.com/itm/Electric-Fuel-Pump-/110737264484?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1986%7CMake%3AToyota%7CModel%3A4Runner&hash=item19c8748f64&vxp=mtr
Old May 27, 2014 | 12:03 PM
  #1285
Thanks Terry, a ? For you or anybody, why would I have antifreeze in the front 2 intake runners? I noticed it one other time and have no idea where it's coming from.
Old May 27, 2014 | 02:12 PM
  #1286
Cyberhorn The Dragon's Avatar
well like the tester terry made a momentary switch, 9volt battery (smoke detector) some aligator clips or old injector harness clip and some wire carb cleaner to help lube the pintile
the injectors just need enough volts to pop the magnet pulling the pinlte up off its seat 9vt seems to be enough i cleaned my injectors that way an terry found couple of his were stuck a firm tap on the metal side with a screw driver handle while clicking the injector while stuck could free it up
Old May 28, 2014 | 07:02 AM
  #1287
Dragon I'm to the point I don't trust myself with any of this, you guys that follow me know how long I've been dealing with this, at some point you have have to ask yourself "hmm maybe it's me" lol. I may give cleaning the injectors another shot just have to see when I get back home.
Old May 28, 2014 | 07:41 AM
  #1288
well you n terry were thinking stuck injectors its an easy test he did it an can talk you through
Old May 28, 2014 | 08:19 AM
  #1289
I'm gonna owe a few people on here BIG when I finally get this thing running, lord knows you've put your share of brain work in on it buddy.
Old Jun 2, 2014 | 04:03 PM
  #1290
Spent so time in the shop working on the old girl today. The tank is still soaking, it's filthy inside, really wish I could get terry to look at it and say yep that's good or no let it go a little longer, it's starting to sound like sand sloshing around in it so I guess it's working.
I also tried to check the injectors in the manner that terry and Cyberhorn have explained to me, the first 3 did nothing and I assumed I was doing somthing wrong but the fourth made a solid click and I could get fluid thru it, I thought hmm might be onto somthing here, I soaked the other with PB blaster let them sit awhile and tried it again, after a few lite wraps with a small hammer in managed to get all of them freed up and clicking and could pass fluid thru them both directions. However the just don't seem to make the same sound as the one good one I found, still thinking about just replacing all of them.
Still have to pick up a fuel pump, filter, red coat and a few other things but moving along Nicely for the moment. Thanks for checking in.
Old Jun 2, 2014 | 05:37 PM
  #1291
glad ya got the idea an its working jason if youve been trying to run on 3 stuck no wonder she wouldnt go
Old Jun 2, 2014 | 05:48 PM
  #1292
I just couldn't wrap my mind around all 4 injectors going down at once but live and learn I guess lol.
Old Jun 2, 2014 | 05:50 PM
  #1293
dirty tank if the sock on the end of the pump wasnt catching it all and rust powder it wouldnt could have gotten into the electromagnets of the injectors all kinda stuck gona go on
Old Jun 2, 2014 | 05:58 PM
  #1294
I can see it happening now, kinda frustrated with myself for trying to cut corners all this time.
Old Jun 3, 2014 | 12:44 AM
  #1295
Terrys87's Avatar
I forget what you wanted me to post. Put up a reminder and I will get it for you.
Old Jun 3, 2014 | 11:20 AM
  #1296
Styer86's Avatar
how I get to see it sometime
Old Jun 3, 2014 | 11:32 AM
  #1297
I think it was the syringe but I picked one up this am. We talked about a bunch last night I don't remember everything.
Old Jun 3, 2014 | 11:33 AM
  #1298
May I'll have it back on the road soon, otherwise you will have to make a road trip lol, thanks for stoping by.
Old Jun 3, 2014 | 06:11 PM
  #1299
Last day at home so I wanted to get as much done as I could. Drained the vinegar out of the tank and flushed it several times with water, I can't believe how much trash keeps coming out. The areas that I can see look really good I just need to let it dry completely and vacuums it out.
Also removed the fuel pump and started cleaning the bracket for it. Not sure about the rest of the country but in tn in the fall we get covered up with these little beetles that look like ladybugs they get into everything I guess even fuel tanks the bracket for the pump and float were just covered with dead ones, inside the pump aswell, tough little bugs anyway.
Got the float freed up so it's move I hope it works I will check it before I put it all back together.
That's going to be it for awhile it's time to head back to work but I'm really happy with the progress this go around. Thanks for checking in.
Old Jun 3, 2014 | 11:06 PM
  #1300
awesome news on the tank an float jason
