irab88's 1993 PickUp Build-Up Thread
Old Jan 15, 2012 | 01:55 PM
  #1241
irab88's Avatar
Originally Posted by RBX
Put a jack under the transfer case and jack it there, up a little...down a little, repeat and wiggle while supported. You'll get it, take your time, double check for any hang-ups.
good luck
while everything is still on the trans jack? like twisting it? it's worth a shot. thanks
Old Jan 15, 2012 | 02:09 PM
  #1242
RBX's Avatar
RBX
^^^ exactly
Old Jan 16, 2012 | 06:52 AM
  #1243
irab88's Avatar
pop goes the weasel... ftw
Old Jan 16, 2012 | 08:24 AM
  #1244
irab88's Avatar
the trans is dropped. boo-yah!
Old Jan 16, 2012 | 08:31 AM
  #1245
ChefYota4x4's Avatar
Nice!!!! Best wishes, man! Anxious to see what's going on in there. Way to persevere, bud!
Old Jan 16, 2012 | 09:27 AM
  #1246
irab88's Avatar
thanks mark!
the trans is sittin' pretty in the middle of the garage now. next up is getting everything prepped for the repair
Old Jan 16, 2012 | 09:31 AM
  #1247
xxxtreme22r's Avatar
Don't forget to take out the throwout bearing. You might need a press to get it out of the fork. I just took the fork to pepboys to have done. Cost me a whopping $12 to have them do it. And unlike me, don't forget to grease it during install.
Old Jan 16, 2012 | 09:34 AM
  #1248
My pleasure, Ian... coming along well!
Brandon is right, that can be a bear. I did it by simply using proper sized sockets and a piece of wood.... BING, BING, BING w/a hammer, tapping around the edges of the socket, and voila, it fell into the other socket within a few raps(Ok, maybe it was more like 20). At 12$ I guess I should have maybe tried that... But I was deep into the costs by then, just wanted the thing done and convinced myself I could do it, lol.
(Hmmm, I'm trying to remember EXACTLY how I did it,... I will look it up, maybe bring you a pic or two if I can find it)
Old Jan 16, 2012 | 09:45 AM
  #1249
Hmnmmm, this is what I posted in my build thread, AGES ago, lol........
"The T.O. Bearing had to come off that sleeve, and the book calls for 2-3 jaw puller(not the best idea, lol), so I went down to Kragen for their 50% off tools sale, got a 1 3/16's socket and a 32mm socket, pounded the old bearing off, and then pounded the new one on" .......... I think what I didn't mention there, Ian, is that pounding it off was much of "back and forth from side to side" with the tapping... til it came off. I didn't care about the original because I was replacing it with a new OEM one. Anyhow, it worked getting it on with those sockets, over a piece of wood, as I mentioned. I think I used the notches on the sleeve to hold it up on the 2 pieces of wood... then rapped on the bearing from the back, side to side until it came off. Putting it on I turned it over, but it would be best with a vice and the sockets.
Best wishes, man!
Old Jan 16, 2012 | 11:44 AM
  #1250
irab88's Avatar
mark- is that a "one and three sixteenths" or "thirteen sixteenths" socket? just want to make sure i get the right one
flywheel is off. not much left to do tonight. i'll get started on the rear main, but i have to wait on the rest of my packages to show up
in the meantime, here's some pics!
Old Jan 16, 2012 | 12:00 PM
  #1251
RMP8080's Avatar
Hey, going to have the flywheel cut?
Old Jan 16, 2012 | 12:41 PM
  #1252
RBX's Avatar
RBX
I've never had a problem with removing the throw-out bearing.
The real fun is in the pilot.
Old Jan 16, 2012 | 12:44 PM
  #1253
irab88's Avatar
"cut"? dunno what that means, but i am going to get it re-surfaced
yes. the pilot is "fun"
(in the middle of that now)
Old Jan 16, 2012 | 12:59 PM
  #1254
RBX's Avatar
RBX
I like the Jenga jack booster.
Old Jan 16, 2012 | 01:06 PM
  #1255
irab88's Avatar
it works, and it's sturdy. and i like working with bottle jacks
Old Jan 16, 2012 | 01:52 PM
  #1256
irab88's Avatar
i need help again-
i'm doing the paper/water pilot bearing removal, and the bearing refuses to budge.
i know the process, but i must be doing something drastically wrong. aaaaahhhh!!!!!!
Old Jan 16, 2012 | 02:16 PM
  #1257
RBX's Avatar
RBX
Patience grasshopper, I've done four that way. It takes time and the key is a punch gues large enough to not let out much water.
Old Jan 16, 2012 | 02:17 PM
  #1258
RBX's Avatar
RBX
Pretty sure I used a 3/8" ratchet extension.
Old Jan 16, 2012 | 02:40 PM
  #1259
I think I used a 1/4" drive 3/16" socket on mine, and lots and lots of paper.
Old Jan 16, 2012 | 03:04 PM
  #1260
irab88's Avatar
i found a 7mm that works... i need to get ready for work this week, so no more progress til friday
when the bearing moved, was it in small increments or a single pop?
