irab88's 1993 PickUp Build-Up Thread
#1241
while everything is still on the trans jack? like twisting it? it's worth a shot. thanks
#1247
Don't forget to take out the throwout bearing. You might need a press to get it out of the fork. I just took the fork to pepboys to have done. Cost me a whopping $12 to have them do it. And unlike me, don't forget to grease it during install.
#1248
My pleasure, Ian... coming along well!
Brandon is right, that can be a bear. I did it by simply using proper sized sockets and a piece of wood.... BING, BING, BING w/a hammer, tapping around the edges of the socket, and voila, it fell into the other socket within a few raps(Ok, maybe it was more like 20). At 12$ I guess I should have maybe tried that... But I was deep into the costs by then, just wanted the thing done and convinced myself I could do it, lol.
(Hmmm, I'm trying to remember EXACTLY how I did it,... I will look it up, maybe bring you a pic or two if I can find it)
#1249
Hmnmmm, this is what I posted in my build thread, AGES ago, lol........
"The T.O. Bearing had to come off that sleeve, and the book calls for 2-3 jaw puller(not the best idea, lol), so I went down to Kragen for their 50% off tools sale, got a 1 3/16's socket and a 32mm socket, pounded the old bearing off, and then pounded the new one on" .......... I think what I didn't mention there, Ian, is that pounding it off was much of "back and forth from side to side" with the tapping... til it came off. I didn't care about the original because I was replacing it with a new OEM one. Anyhow, it worked getting it on with those sockets, over a piece of wood, as I mentioned. I think I used the notches on the sleeve to hold it up on the 2 pieces of wood... then rapped on the bearing from the back, side to side until it came off. Putting it on I turned it over, but it would be best with a vice and the sockets.
Best wishes, man!
Best wishes, man!
#1250
mark- is that a "one and three sixteenths" or "thirteen sixteenths" socket? just want to make sure i get the right one
flywheel is off. not much left to do tonight. i'll get started on the rear main, but i have to wait on the rest of my packages to show up
in the meantime, here's some pics!
#1253
"cut"? dunno what that means, but i am going to get it re-surfaced
yes. the pilot is "fun"
(in the middle of that now)
#1256
i need help again-
i'm doing the paper/water pilot bearing removal, and the bearing refuses to budge.
i know the process, but i must be doing something drastically wrong. aaaaahhhh!!!!!!
thanks mark!
