irab88's 1993 PickUp Build-Up Thread
Old Jan 23, 2011 | 05:33 AM
  #281
irab88's Avatar
Originally Posted by mfwimg82
what type of class are you taking?
thanks for the bump on the other thread.
i'm in school for aviation maintenance and repair. this class is about working with sheet metal. riveting is so much fun. if i had the resources, i would rivet new aluminum body panels for the caboose
Old Jan 23, 2011 | 06:27 AM
  #282
mfwimg82's Avatar
nice choice ! I do body work in mass transit field lots of rivets too much drilling for me . now every thing is glue and clamp that is nice.
Old Jan 23, 2011 | 06:57 AM
  #283
irab88's Avatar
i think a polished aluminum, riveted car would look su-weeeeet
Old Jan 23, 2011 | 09:12 AM
  #284
irab88's Avatar
picked up this today on craigslist. $60, not too bad...
Old Jan 23, 2011 | 09:30 AM
  #285
mfwimg82's Avatar
cb?? scanner ?
Old Jan 23, 2011 | 09:48 AM
  #286
irab88's Avatar
cb. all the controls and components are in the mic itself. no "base unit" except for a small box for power and antenna hook-ups.
Old Jan 24, 2011 | 01:12 AM
  #287
mfwimg82's Avatar
nice! I do not see many cb radios any more
Old Jan 31, 2011 | 11:47 AM
  #288
irab88's Avatar
ok, so i've had a bit of an incedint. left bed body panel is smashed in. now the auto body place gave me two options: replace the section (no bondo) for ~1400 or repair the section (with bondo) for ~1000. i can get a junk-yard bed for ~700 (in good condition, possible option), or i can bang it out myself and have it look like a half-a55 job until i save up for a proper fix. right now, i can afford to do all but the first mentioned repair, but in a few weeks, i can get more done.
i've also heard of a mysterious "taco bed swap", but all i've heard is that it has been done. i dunno if this would be cheaper, but it's another option.
any and all help appreciated!!!
Old Jan 31, 2011 | 11:56 AM
  #289
ChefYota4x4's Avatar
DANG! What happened, man? sorry to hear, Ian, really brudda. Not sure on the taco swap, but you could probably do well by making sure that there is no other damage to things under there(meaning, can they make it AS STRAIGHT as it was, and would it be easier to just swap out the bed?).
Old Jan 31, 2011 | 12:00 PM
  #290
irab88's Avatar
i'm thinking bed swap. i have another phone call to make, but it would probably be about the same (~900 or so total cost)
pic. more tonight
as to how it happened, let's just say that i now hate volvos
Old Jan 31, 2011 | 12:09 PM
  #291
Swimmerboy2112's Avatar
pic. more tonight
ahh not good man I think with that much damage you're better off getting a whole new bed. I wouldn't want to repair that and definitely NOT use bondo.
Have you thought about a fiberglass bed?
Old Jan 31, 2011 | 12:23 PM
  #292
RBX's Avatar
RBX
Those beds are pretty flimsy because toyota changed the style in 89 so they wouldn't rust out around the wheel well.
You could probably take your hand or 2x4 and push some of that out from under the truck. I've replaced whole bedsides before, pretty easy(i used to do collision repair). You certainly don't need an entire bed. But you will need to remove the bed to fix it, oh and your cap.
I have a welder and air if you want to replace it when the weather gets warmer. You know where i live.....just bring the Root Beer.
I think a fibergalss bed would be great, but VERY expensive.
Old Jan 31, 2011 | 12:36 PM
  #293
Nervo19's Avatar
I would probably do the bed swap. Don't forget Bondo should never be more than 1/4 inch thick or it will eventually crack.
  #294
irab88's Avatar
i don't want bondo, and am not getting it. period. don't worry
as for the fiberglass beds, i want one. but they cost about the same as the full replacement of panel, and not to mention the place that makes 'em for 3rd gens is in canadia
i could do that... very do-able, and could be less expensive if i do it right. and my cap is fine. volvos arent that tall
Old Jan 31, 2011 | 01:03 PM
  #295
Woah woah! If you 2 are meeting up i may have to drive back down to Maryland...
Old Jan 31, 2011 | 01:06 PM
  #296
yotarob2005's Avatar
Sorry Ian, I know how you feel but at least yours will be a relatively easy fix, I would go for a new panel.
Old Jan 31, 2011 | 01:58 PM
  #297
mfwimg82's Avatar
Look into bed swap and paint
Old Jan 31, 2011 | 03:03 PM
  #298
irab88's Avatar
maybe. dunno yet. and it probably won't be 'till it warms up. just don't get stuck on the way down... we don't want you to loose another toe!
Old Jan 31, 2011 | 03:07 PM
  #299
Lol yes warm is good!! No toes shall be lost!
Old Jan 31, 2011 | 03:11 PM
  #300
irab88's Avatar
all right, i'm out untill 1230 tonight... now to go eat...
