irab88's 1993 PickUp Build-Up Thread
Old Apr 28, 2013 | 12:43 PM
  #2261
RBX's Avatar
RBX
Nice.... Those 11mm wrenches? Or standard...haha.
Old Apr 28, 2013 | 08:23 PM
  #2262
irab88's Avatar
everything on the door is standard, but the main bolts are 1/2", which is close enough to 13mm. i have a set of ratcheting combination wrenches i use for the doors.
as for swapping them out, i can change the doors out in about 15 mins by myself. and that's without that much practice
Old Apr 28, 2013 | 08:36 PM
  #2263
aviator's Avatar
looks good Ian... now you need to get an alarm with one of those proximity radar sensors they use on convertibles and jeeps to scare away the tweakers... and put a locking glove box latch in... etc. etc.
Old Apr 29, 2013 | 03:41 AM
  #2264
irab88's Avatar
got one a while back. i just need a good weekend to install it. maybe this coming weekend? we'll see.
Old Apr 29, 2013 | 06:52 AM
  #2265
4ever4running's Avatar
Damn dude those look sweet! Nice work on the latches too, they look like they work pretty smooth.
Old May 3, 2013 | 03:22 AM
  #2266
irab88's Avatar
put mah doors on for work today. i found i can get most of the stuff ready the night before, so all i have to do in the morning is remove and replace. took about 10 mins, and i was cruisin'
Old May 4, 2013 | 02:21 PM
  #2267
irab88's Avatar
i got bored today, so i decided to install my alarm system.
Old May 9, 2013 | 12:33 PM
  #2268
RBX's Avatar
RBX
Did you know about this, elocker shaft length:http://www.pirate4x4.com/forum/toyot...rs-trucks.html
Old May 9, 2013 | 01:49 PM
  #2269
irab88's Avatar
interesting read. now i'm all concerned about breaking a third, thanks a lot!
you're having your shafts custom-made, right? so you'll be sure to get full spline engagement. what's your axle housing off of? (the new one)
Old May 9, 2013 | 05:04 PM
  #2270
aviator's Avatar
Another option might be to just take a whole tacoma e locker axle and swap that on as one piece no?
All you might need to do is change the ring/pinion gears to get the right ratio.
Old May 9, 2013 | 05:30 PM
  #2271
RBX's Avatar
RBX
Ian,
I may be able to get away with some dirty 30s from trailmart. I've got to do more home work.
I just found out about this myself while I was on pirate.
Old May 9, 2013 | 05:52 PM
  #2272
irab88's Avatar
aviator: i'm planning on a full-float rear, so i can live with it like that for now. i'm not running large tires or a big motor either.
rb: let me know what you find. more than likely, i'll be following your lead for the axle shafts and hubs.
so if you went d-30's, you'd be using a drive flange, then?
Old May 9, 2013 | 06:03 PM
  #2273
RBX's Avatar
RBX
Yes I've got some fj80 drive flanges coming. They are the new style that have more engagement, so I may be able to mill a bit off the top if it permits. The DF was changed for more spline engagement on the front axle due to the wear of the full time 4wd. We will see.
Old May 10, 2013 | 03:39 AM
  #2274
irab88's Avatar
for reference
http://www.pirate4x4.com/forum/toyot...e-problem.html
Old May 11, 2013 | 04:22 PM
  #2275
Red Wagon's Avatar
One hell of a camping truck. This is going to take me awhile to get through all the middle parts of your build.
How did you do that cool latch video?
Old May 11, 2013 | 07:31 PM
  #2276
irab88's Avatar
measured the parts, drew it up using google sketchup, took still shots of the positions, used an online .gif generator to make the animation.
and for this one, my phone has a .gif maker
Old May 14, 2013 | 08:35 AM
  #2277
irab88's Avatar
just thought i'd share my compressor setup. someday, i want to mount it properly on the truck, but for now, it works great
i used empty propane tanks because a) they were free and b) they are good through 300psi
air hose and jumper-cabled harness
Old May 14, 2013 | 08:47 AM
  #2278
RBX's Avatar
RBX
Can you please send me or post up the parts list you ordered for your elocker? I looked thru your thread back when you were talking about it but could find it if you posted.
thanks
Old May 14, 2013 | 09:11 AM
  #2279
aviator's Avatar
Interesting compressor set up Ian...
Old May 14, 2013 | 09:31 AM
  #2280
irab88's Avatar
thanks
hardware? electronics? general materials? everything?
i didn't buy much, because it was basically a big circuit. a few automotive relays, a spdt switch, some led's, and wire. for the wire, i used 3-connector trailer wire (2 runs) to the e-locker, and servo wire (2 runs) for the switches and lights. not too long of a list
it's like a mini contractor-style compressor, but with more cfm
