Dunkin's 1990 4Runner 2DR Build-Up Thread
Old Apr 3, 2011 | 09:30 AM
  #181
Dunkin's Avatar
Cool. Thanks shaggy. I paid attention to the front shaft orientation, but not the rear. I just assumed to put the slip at the front since some trannys use the output yoke as the slip joint too.
I got about a hundred miles in total done yesterday, all flawless. Fuel economy seems about identical to the 22re so far. And, I still haven't had a starting issue since installing the relay yesterday.
I plan to install my new second hand drivers door today and maybe play with some more wiring.
Old Apr 5, 2011 | 05:00 PM
  #182
Dunkin's Avatar
Gahhhh! Dammit....
I have a coolant leak. It's dripping from the clutch fork. Looks like the rear crossover is leaking, and I'm gonna have to pull the intake again anyway. :mad:
Old Apr 5, 2011 | 05:53 PM
  #183
SHAGGY21's Avatar
thats a bummer man,
Old Apr 5, 2011 | 06:12 PM
  #184
Dunkin's Avatar
I found a bonehead mistake, thank god...
Whoops! That was the source of the leak, filling the block valley and running out the back onto the clutch.
Wooooo, I don't have to pull the intake!
Old Apr 5, 2011 | 06:17 PM
  #185
SHAGGY21's Avatar
thats good man. i found something like that on the 93 i had. someone didnt put one of those clamps back right on the heater core inlet to the water temp housing.
Old Apr 5, 2011 | 10:19 PM
  #186
85toyman's Avatar
Glad it was that easy.
Old Apr 10, 2011 | 06:33 PM
  #187
SHAGGY21's Avatar
hey dunkin did u have to do anything with the tranny tunnle for the t-case shifter or do u not have it sitting back that far?
Old Apr 10, 2011 | 06:42 PM
  #188
Dunkin's Avatar
I had to trim it a bit for the shifters to come through, but not much.
Old Apr 10, 2011 | 06:45 PM
  #189
SHAGGY21's Avatar
im going to have to trim a bit. right now the hole in the tranny is about covered by the tunnle. i do have it sitting pretty far back though. i dont want to have to run a pusher fan.
Old Apr 14, 2011 | 07:11 PM
  #190
SHAGGY21's Avatar
hey dunkin not to be the bearer of possible bad news. but i did some measurements and unless your input shaft spacer slid right on your input shaft you might want to pull your tranny maby. i ended up drilling the one i have out to fit over it and its very close. i have all the measurments i took if you want them.
Old Apr 15, 2011 | 11:04 AM
  #191
Dunkin's Avatar
Thanks bud, but mine fit perfectly with the KS Flywheel. I was able to measure the clearance before I installed it.
Narin from KS Racing did get back to me recently as well. I found out he is using a clutch kit from the JDM/EDM 3.0 TD Toyotas.
1KD-FTV (3000cc. turbo diesel engine)
I believe that is where the flywheel came from also.
However, I do have to pull the tranny soon, since the rear main is leaking a bit. I knew I should have picked up a seal from the dealer and not from WorldPac... Oh well.
Old Apr 15, 2011 | 11:08 AM
  #192
SHAGGY21's Avatar
Well the pilot bearing still goes in the crank. Don't be saying that. That is where I got my cam seals and rear cam plugs from.
Old Apr 15, 2011 | 11:30 AM
  #193
Dunkin's Avatar
The cam seals and cam plugs look to be OK and fit great for me. The rear main just slid in by hand though, and made me a bit leery of it to begin with. Now that I see small drops from the bottom of the bell housing, my fears have been confirmed.
When I originally installed the transmission, it fell right into place. I didn't have to force it at all.
Old Apr 15, 2011 | 12:38 PM
  #194
ChefYota4x4's Avatar
Sorry to hear you're pullin the Trans for the rear main! GRR! Hope it goes without hitch, man! (I'm going to have to pull both front and rear eventually.... even with New Oil pump, Timing Cover, Rebuild, REplacement Low Miles Crank, Clutch Complete Kit, ...GRRR! lol.. Oh well, the beat goes on, eh? lol)
Be safe man, best wishes on the work at hand, ....
Mark
Old Apr 16, 2011 | 11:54 AM
  #195
SHAGGY21's Avatar
Hey dunkin where did u put the ecm. I'm tryin to get some ideas. I'm thinkin bout mounting it to the floor with a plate over it like the subies.
Old Apr 16, 2011 | 12:12 PM
  #196
Dunkin's Avatar
I just have it tucked under the carpet at the moment. I need to get motivated and finish the wiring.
Old Apr 16, 2011 | 12:15 PM
  #197
SHAGGY21's Avatar
Yeah that's what I'm trying to work on right now but every time I look at the lump of harness sitting on the engine and floor I just want to walk away. Need some ambition
Old Apr 16, 2011 | 11:08 PM
  #198
Dunkin's Avatar
I can tell you that you will absolutely love 3rd gear from 70-90ish on the freeway. I'm also pretty amazed with how stable she feels at 110.
I hope that helps with the ambition. Lol
Old Apr 18, 2011 | 08:06 AM
  #199
siplakoff's Avatar
Your so lucky to find a 2dr second gen with a 22re. They made 1200 2dr 2nd gen runners, I was unfortunate enough to get one with the 3.slow V6. And then I rolled mine. Wish you better luck with yours.
Old Apr 18, 2011 | 08:09 AM
  #200
siplakoff's Avatar
I still have my interior panels and window switches for the doors of my 2dr runner if you need replacements. They are the blue color. Also have tons of 2nd gen runner parts if your lookin.
