Dropzone's 1994 4runner Build AKA: Project Recycle:
Old Feb 25, 2016 | 10:21 PM
  #121
BUDD's Avatar
good job!
if you worried that with the bigger tyre, you might touch the ground when offroading, someone done this to have more clearance
Old Feb 26, 2016 | 07:00 AM
  #122
dropzone's Avatar
Fossilized
Originally Posted by habanero
That is just awesome!
Thanks Habanero, It should do the trick
Originally Posted by rustED
The spare tire mount turned out nice. I didn't realize they were only offered for a couple years on second gens, now it makes sense why I never see any around lol. I like your Ram tablet mount. I was trying to find something similar, but my inclinometer kinda limits my mounting options. I cheaped out and started building a mount, it's going to slide into the track were the ashtray used to go. Should have it finished tomorrow.
Yep, from what I could find and have seen only 90-91's.
I am looking forward to seeing how your mount comes out.
Originally Posted by BUDD
good job!
Thanks BUDD, those pictures help. I will have one of my professional welder friends help me when the time comes.
One thing I noticed is that I will need to relocate the rear window key or it will be buried behind a 35.
I wish I could locate the 90-91 tailgate insert(like you have pictured) to replace the stock backup light/license mount, maybe I will get lucky
Old Feb 26, 2016 | 10:47 AM
  #123
BUDD's Avatar
yes, relocate the key, cables inside the tailgate shouldn't be a problem, this is the way it came on the ones i got.
you might manage not relocating it, (this is not my truck by the way)
Old Feb 26, 2016 | 02:38 PM
  #124
dropzone's Avatar
Fossilized
Thanks for the pics. I like the flush mounted bumper on the 2nd truck
Planned on getting a few more things done.
Only thing I did get accomplished before it started dumping was to add an extended harness so I can add a rear/inside mounted window switch.
Need to get the 81 sold and gone so I can get the 4Runner into the garage...
Old Feb 27, 2016 | 02:16 AM
  #125
BUDD's Avatar
mm never thought on that, shows us how you get on with it!
Old Feb 27, 2016 | 05:45 PM
  #126
dropzone's Avatar
Fossilized
Thanks, figured I had it apart any way and easier than running wires up to the switch up front.
Old Feb 27, 2016 | 06:40 PM
  #127
BUDD's Avatar
up front? i thought you meant inside by tailgate to open from inside, like for example if you are camping
Old Feb 28, 2016 | 11:22 AM
  #128
dropzone's Avatar
Fossilized
by running wires up front I meant running wiring to the switch in the center console.
I want to add a continuous hot wire at some point so I can raise and lower it while camping like you mentioned
Old Mar 11, 2016 | 03:12 PM
  #129
dropzone's Avatar
Fossilized
So since the stock back up lights are now useless due to the tire mount I dug into the stash of junk I bought for the Trekker and found some 18w flush mounted LED's
There were too thick
So cut an inch off the cooling fins. I did this on the 81 too and didn't have any issues with the lights. They aren't on that long so heat dissipation should not be too big of issue
Old Mar 11, 2016 | 03:37 PM
  #130
rustED's Avatar
Tire carrier install looks good, I'm envious. I like the backup lights too, look like they are plenty bright!
Old Mar 11, 2016 | 06:31 PM
  #131
habanero's Avatar
Great idea for the back-up lights, I'd have never thought to cut them down like that, since you have experience with others you've cut and had it work out that's a great idea. Of course the carrier looks great!
Old Mar 11, 2016 | 07:43 PM
  #132
dropzone's Avatar
Fossilized
Thanks!
Thanks Habanero
The lights don't put out as much light to the side as I had hoped, thought they put out more of a flood pattern.
I will add a set of floods on the cross member like I did on the Trekker
Old Mar 11, 2016 | 10:05 PM
  #133
punks_is_4x4's Avatar
Oh crap love the mounting of the back up lights I wana do that to my 1st gen my reverse lights are useless as well. Did u cut off that and it fits in front of the regulator ?
Old Mar 12, 2016 | 04:47 PM
  #134
dropzone's Avatar
Fossilized
Yes, cut about an inch off the cooling fins with my 4.5 grinder with a cutting wheel.
It fits nicely right behind the window. Not sure how much room you have on a 1st Gen 4runner
I had made a 1/4" spacer out of some old plexiglass in case I needed a little more room but didn't need them
Old Mar 12, 2016 | 08:11 PM
  #135
vital22re's Avatar
totally a bro
You seem to be doing a lot of things that are not a 3.4 swap..... :cough:
Old Mar 19, 2016 | 05:55 PM
  #136
dropzone's Avatar
Fossilized
Yep..doing the free or cheap stuff first. ..someday you will see this up north to fix its motivation issues.
Today was a great day to tackle some wiring while wearing shorts and flip flops
My new favorite wiring tool...speeds things up a lot
Crimped and heat shrinked momentary on-off-momentary off switch for the rear window
Rear Aux outlet for a future 12v fridge and dual USB for my rear camera
Old Mar 20, 2016 | 11:29 PM
  #137
Terrys87's Avatar
Your reverse lights look great and do come in handy. The tools that are coming out today are so much better then 10-20 years ago. The right tool makes the job so much easier and your crimps look great. In some ways we have it far better then previous generations on tool selections, just wish I could get half of them.
Old Mar 21, 2016 | 07:16 AM
  #138
85toyman's Avatar
I like the aux power port. Need to put one of those in for my ARB fridge. I thought we were going to 1uz it. Much more motivation
Old Mar 21, 2016 | 09:00 PM
  #139
Reluctanse's Avatar
Love it, just got the same pair of crimpers and they are awesome! The rear wiring for the window you are doing is great, I've got a mind to do something similar, but I promised myself no scope creep until the engine is done and back up and running...
Old Mar 22, 2016 | 10:54 AM
  #140
dropzone's Avatar
Fossilized
Thanks Terry. You are correct, some of the tools coming out are just plain awsome. I like how this crimper holds the connector very tight and won't release until you have completed the crimp.
3.4 or 1UZ, either one would be nice but neither option will happen for awhile. obviously need to get the suspension done first
Thanks, appreciate it.
