Dropzone's 1994 4runner Build AKA: Project Recycle:
Old Nov 10, 2015 | 06:38 AM
  #81
dropzone's Avatar
Fossilized
Originally Posted by irab88
do you have a link for the mirror heaters?
also, you could do up a simple bracket for the mirror lights:
that way, when you take the doors off, you won't need to unplug them
Here is the link:
http://pages.ebay.com/motors/link/?n...465190&alt=web
Had them in less than 10 days from china, warp speed shipping.
A bracket is an idea will give it some thought
Old Nov 16, 2015 | 05:00 PM
  #82
dropzone's Avatar
Fossilized
Started on my heated mirror experiment :
$15 heated inserts from eBay
First step was to get the mirror apart, there is a screw on the bottom of the mirror that will allow you to get the motor assembly and mirror out from the housing
Assemble your chosen weapons:
Is this case a wide putty knife and plastic pry bars worked for separate the mirror from the mount
I trimmed the heated insert slightly
No pics but I drilled a couple of holes in the mount to allow the power wires for the heated insert power and remountEd the mirror with some 3M tape
There is a small screw you can remove disassemble the the pivot point on the mount
Remove that screw in addition to the 3 bigger screws on the bottom of the housing, this will allow access to feed your wires through.
I went ahead and added a high power LED for a signal
Should be pretty bright
I went ahead and threw it in the freezer so I can test the insert after dinner...update to see iF this was successful.
It needs some touch up paint later on
Old Nov 16, 2015 | 05:28 PM
  #83
habanero's Avatar
Nice work! I covet my husband's 99's heated mirrors, they're a nice little perk. Think he'd notice if I swapped internals?
Was looking for a light a lot like the one on your mirror....toying around with some kind of unobtrusive ditch lighting. Something along that line or like Irab88's maybe.
Old Nov 16, 2015 | 07:33 PM
  #84
dropzone's Avatar
Fossilized
Thanks Hab, the few times a year I will need them they will be nice to have, especially on some winter snow trips.
The mirror mounted LED'S are for a turn signal. Will see how they work.
I am debating about doing a ditch light, if I do it I want it to be in such a way it doesn't look too Jeepish if you know what I mean.
So I threw the mirror in the freezer with some water on it for a couple of hours and went to grab some dinner with friends.Name:  20151116_201456_zpsb9c5pksk.jpg
Hooked up the battery charger set to two amps
After about 3-4 minutes
I have an extra defroster switch that I might use or just wire them into the rear defrost circuit.
Am happy for an experiment they seem to work OK
Old Nov 16, 2015 | 07:55 PM
  #85
CamTom12's Avatar
That's WAY better than non-heated. Nice work!
Old Nov 17, 2015 | 06:46 AM
  #86
dropzone's Avatar
Fossilized
To Make Fog Lights Come On With Low Beams
From this thread:
https://www.yotatech.com/forums/f116.../#post52297725
1994 model trucks and 4Runners may still have switched ground control for headlights. If that is so, merely tapping positive of relay coil to positive side of low-beam beam wire and grounding the other side of relay coil will not work.
To simplify your wiring BUT STILL MAKE IT WORK LIKE YOU ORIGINALLY WANT:
(1) Tap positive side of relay coil to positive side of low-beam filament, and
(2) Tap negative side of relay coil negative side of low-beam filament
Do this very close to the bulb connector to be exactly sure of the wires.
However, best if you posted (1) schematic of your truck, and (2) schematic of your fog light kit so we can pinpoint exactly where to tap off of.
OK, found schematic for 1990-1995 4Runner. Should be the same.
Here's your circuit:
Before you do anything, probe pins 2 and 3 make sure there is 12V across them when, and only when, low-beams are on.
You can disconnect connector from bulb in order to prove for voltage. positive (red) probe on 3, negative (black) probe on 2
Saving for future reference
Old Nov 17, 2015 | 06:56 AM
  #87
habanero's Avatar
You mean what I mean.
Old Nov 18, 2015 | 05:39 PM
  #88
dropzone's Avatar
Fossilized
Yes i do
Old Nov 20, 2015 | 05:30 AM
  #89
irab88's Avatar
From this thread:
good diagram. a note: the relay has a high chance of back-feeding through the high-beam indicator bulb. this might activate the relay even when the high beams are on. i have a different schematic that will a) allow accessories to turn on without backfeed, and b) be an upgrade to the headlights. if you want, i can dig it up.
also, i suggest putting the switch somewhere on the green ground (to the relay coil). it keeps the positive out of the cab, and worst case (a short), the lights turn on.
Old Nov 20, 2015 | 05:25 PM
  #90
dropzone's Avatar
Fossilized
that would be cool if you did. I was thinking of adding a diode.
Old Nov 23, 2015 | 05:44 AM
  #91
irab88's Avatar
https://www.yotatech.com/forums/f116...88/index9.html
the +12L and +12R are from the factory harness, you can use both, left or right, doesn't matter. those turn on with the headlights.
the switched ground from the high beams is the only other factory wire you'll need.
the factory plug consists of +12 (switched on with the headlights), switched ground for lows, and switched ground for highs.
the high-beam indicator will back-feed through the relay contacts, not through any relay coil (to give normal, stock functionality)
the right relay activates the headlights, and stays on when the headlight switch is on.
the left relay activates when the high beams are on, switching between low and high
to use this circuit and a fog light circuit, use another relay with its coil in parallel with the left relay the added relay will be on with the high beams, so use the middle NC terminal (87a) and common (30) with the fog lights
i'll see about getting a better diagram for you (and me, when i need it again)
Old Nov 23, 2015 | 07:29 AM
  #92
dropzone's Avatar
Fossilized
Ian-
Thanks, with that info and my test light I'll be able to wing it.
Thanks!
Old Nov 28, 2015 | 08:02 PM
  #93
85toyman's Avatar
Looks good Rob,
I think the Zrunner might get some heated mirrors too
Old Nov 28, 2015 | 08:06 PM
  #94
dropzone's Avatar
Fossilized
Originally Posted by 85toyman
Looks good Rob,
Thanks Don. It was a pretty quick project and should yield some good results.
Old Nov 30, 2015 | 06:23 AM
  #95
rustED's Avatar
Nice work on the heated mirrors/turn signals, and other mods, alot of good ideas I'm going to have to "borrow" for my next project!
Old Dec 9, 2015 | 10:05 PM
  #96
coopster's Avatar
From: exo-reality -wave if you see me; Front Range, CO
Cool stuff. I'm lazy, and easily lost. Thanks for your work!
'scribed.
Old Dec 10, 2015 | 01:55 AM
  #97
dropzone's Avatar
Fossilized
'scribed.
Thanks guys. I wish this project could progress faster but doing it as $$ and time becomes available.
Hopefully have the suspension swap done sometime this summer
Old Dec 10, 2015 | 08:53 AM
  #98
coopster's Avatar
I'm in no hurry. (Well, I need to be!)
After 4 (four?!) years in storage down in TX, finally got my 2 moved near-er so I can work on them on days off. Spent some time this week, and man am I screwed.
So I get the time/$$ thing.
Old Dec 16, 2015 | 03:00 PM
  #99
Terrys87's Avatar
Will eventually look into your heated mirrors, that would of come in handy this past week. Fog light is going to be moving up the list, we have been dealing with more fog lately and do a lot of night driving. Will be intrested in seeing what you come up with.
Old Dec 16, 2015 | 05:50 PM
  #100
dropzone's Avatar
Fossilized
4 years, you got me beat Glad you got them closer
I haven't touch this once since I did the mirrors
I usually have a set of fog lights.
I have a set of 25w LED Knock off Light Cannons that i have picked up a few sets of filters for. I can have flood, spot or fog lights with one set of lights.
