cr@ves4wheelin's 1991 Hilux Build-Up Thread
Old Aug 12, 2011 | 02:30 PM
  #121
xjfiles's Avatar
Sweet ride. Makes me want to work on my truck I just got. Off to the parts house tonight for a tuneup.
Old Aug 12, 2011 | 05:37 PM
  #122
cr@ves4wheelin's Avatar
Thanks guys
Stewmaker-I probably wouldn't have room to fit 35s as of now. I would need to do some trimming, wider and higher fiberglass fenders and bedsides so nothing would rub. So I'd say, for me, 33 is the max.
Old Aug 13, 2011 | 12:36 AM
  #123
Stewmaker95's Avatar
Yeah I figured as much. Your truck looks proportionate though. I swapped a 3.4 into my truck last winter so I have a 1" body lift on mine, hopefully the BL and a little trimming will be able to stuff 35s under it. Planning on getting a thread started soon enough too!
Old Aug 13, 2011 | 08:08 AM
  #124
Nice, good luck man.
Old Aug 14, 2011 | 03:26 PM
  #125
Even though money is running low right now, I ordered a re-manufactured power steering box from WabFab. It was pretty expensive, but I've been buying some cheap replacement parts for my truck and they just don't hold up like they should. Plus I can't afford any more problems with it leaking and destroying the rest of the power steering gear due to lack of fluid.
Old Aug 14, 2011 | 03:29 PM
  #126
Sounds jam up. What other weak links have you found in the steering?
Old Aug 14, 2011 | 03:32 PM
  #127
There hasn't really been a weak link in my steering as far as I'm concerned. The reason my power steering box leaks is because of me putting regular power steering fluid in it.
Old Aug 14, 2011 | 06:35 PM
  #128
Ahh.. Haha that'll do it! I look forward to ordering my blazeland kit as soon as I sell my other 4runner.
Old Aug 14, 2011 | 11:01 PM
  #129
That'll surely give you more than enough funds for Blazeland stuff. Good luck with your sale.
Old Aug 16, 2011 | 07:10 PM
  #130
Lewis15498's Avatar
This truck is really impressive. Love the long travel suspension! Keep up the good work!
Old Aug 16, 2011 | 07:34 PM
  #131
Thanks man
Old Aug 24, 2011 | 12:15 PM
  #132
Well got my new Power steering Box Installed.
Here's the write-up: https://www.yotatech.com/forums/f116...ite-up-240190/
Old Aug 24, 2011 | 10:47 PM
  #133
Muppet's Avatar
gorgeous truck. really nice work so far. Keep it up!
Old Aug 25, 2011 | 04:17 AM
  #134
waskillywabbit's Avatar
Every Toyota I've converted a new box like yours has been used just because I don't want steering to be an issue ever. Too many other things get torn up wheeling as it is.
Nice truck.
:wabbit2:
Old Aug 31, 2011 | 11:09 PM
  #135
Thanks guys
Old Sep 16, 2011 | 08:29 PM
  #136
New box looks good man hope it hangs in there this time. I just started grabbing the stuff to pep up my front end alittle, I also got in touch with Nate and have my kit coming soon! But Im stationed in AK so itll take a while to get here parcel post. He is a great guy to do business with, its too bad alot of bigger businesses stray away from the little guys trying to save a buck like us!
Old Sep 18, 2011 | 10:47 AM
  #137
Thanks Man I hope it does too. Yeah, Nate's hella cool to do business with. Good luck with the install.
Old Sep 18, 2011 | 10:48 AM
  #138
More Leaks
So I looked under my truck the other day and saw this.
Yep, my rear axle seal is leaking. YAY!!!!!!!!!! -_-
Here's the other side for comparison
After some reading, I learned that the diff breather being plugged can cause pressure to re-route through the seals. I looked at mine and the cap moved up and down so I knew it wasn't rusted shut or anything. So I took some PB Blaster and a 14mm Wrench and removed it from the axle housing. The whole inside of the breather was completely filled with crud.
So I cleaned it out using PB blaster, used a couple of my roommates pipe cleaners (I'll give him a dollar when he gets back, he'll know its for a good cause), and soaking it in hot water.
All clean, and I can actually see the other side.
So now I have a little more peace of mind with the diff breather, hopefully the bearings won't go out anytime soon due to the gear oil. I don't have a press to replace bearings, so if the time comes I'll just take it to the shop.
Old Dec 10, 2011 | 11:15 AM
  #139
Got new new axle seal/bearings. Here's my write-up if anyone is interested:
https://www.yotatech.com/forums/f116/rear-axle-seals-bearings-write-up-250062/
Old Dec 10, 2011 | 12:03 PM
  #140
john4wd's Avatar
How much diff fluid came out when you removed it? if you didn't run it dry, it should be fine for the diff bearings if it was still 1/2 full when you discovered the leak...
