CBO's 87 4runner build
Old Apr 12, 2016 | 03:57 AM
  #121
crashburnoveride's Avatar
Originally Posted by rustED
Nice score on the calipers. Will the emergency brake still be functional with this swap?
Besides the fact that I cut out and removed my ebrake stuff, it would not work with these calipers. You can source ones that have an ebrake option, but I obviously don't care about that.
Old Apr 12, 2016 | 05:35 AM
  #122
Disc brake conversion cost
Keeping track of my expenses for this mod here:
Junkyard 01 montero sport calipers: $45
2x rear brake hose. These connect the caliper to the toyota hardline.
$22 after shipping.
Brake rotors: $75 ebay
Caliper bushings & sleeves: $17 ebay
Ceramic brake pads: $15 jcwhitney
Current Total: $174
Old Apr 12, 2016 | 03:14 PM
  #123
rustED's Avatar
Cool, glad you're doing a writeup, with cost of parts and links included!
Along time ago I seen a mod where they didn't have all the emergency brake cables, but they still had the pull handle in the cab. So they just ran a short cable through the firewall and back into the cab (just a big loop) and ran the cable to the brake pedal. That way when they were out wheeling they still had an emergency brake (as long as the rig was still running)......Then again, when you got dual cases you park that sucker in gear and it ain't going anywhere, lol.
Old Apr 15, 2016 | 07:14 AM
  #124
Loaded up the 4 new tires, 4 new rims, and one of my MTR's into the armada.
Went to my buddies to mount these bad boys. Used the 500 balancing beads from inside the MTR combined with 3000 other beads I had left over in the bottle in the new trepadors. I can now work a tire machine.
Got home threw one on. Heres a pic of the stance. Love it!
All my disc brake parts should come in on monday. So next week I'll begin that project!
Old Apr 15, 2016 | 11:02 AM
  #125
Gizler00's Avatar
Oh Yes!! Same rims that I have on mine.
Old Apr 15, 2016 | 03:54 PM
  #126
I got home to a surprise.
Did some work.
Test fitting.
Just need to design and make the caliper mount bracket.
Old Apr 15, 2016 | 04:22 PM
  #127
Gizler00's Avatar
Very nice!!
Try to find a DXF file for a bracket and we can cut it out on the plasma
Did some work.
Test fitting.
Old Apr 15, 2016 | 04:40 PM
  #128
That would be awesome but I'm not sure there is one. The mount for the montero caliper is a little more difficult. I should have used isuzu trooper calipers. But I do like not having too many different vehicle parts on my yota. This way its all montero on the rear brakes. This is the easy bracket for other calipers. Just one piece and some shims. Bolts go through.
This is the bracket I have to make.
Two pieces welded together and I'll hafta thread the outer holes for the caliper to fasten into. Not the easiest design but its cool cuz it also looks like it will help clean off mud from the rotor on the back side. I wish I could find a file for it cuz I suck at making such precision stuff. But I doubt theres a file out there.
Old Apr 16, 2016 | 08:32 AM
  #129
rustED's Avatar
Looks like it's going to be a sweet setup! Do you have to run a residual or proportioning valve with this setup?
Old Apr 16, 2016 | 01:54 PM
  #130
I have no idea. Lol
Old Apr 16, 2016 | 05:56 PM
  #131
Bored at work so I did a little shopping. Didn't really need it yet but got a good price.
$35 from low range offroad. Gonna put in on the rear axle when I clean it up.
Old Apr 17, 2016 | 02:29 PM
  #132
kelvinb's Avatar
did you install both brackets already? i can pull some measurements off them and make the brackets.
Old Apr 17, 2016 | 03:52 PM
  #133
No I haven't yet Kelvin. I was tinkering around with some cardboard today when I noticed that I need to drill out the rotor stud holes. The wheel studs cone out at the bottom so the rotor won't bolt down flush.
I turned the rotor around and mounted it backwards so you can see the gap. And that's after hitting it with the impact.
When I spun the rotor it was clearly wobbly and not on straight. I was gonna buy a 9/16 drill bit but at $25 I'll just borrow one from work. Then once its on straight I can move forward on the mounts.
Old Apr 19, 2016 | 11:56 AM
  #134
bump530's Avatar
Im glad you noticed that the rotors didn't sit all the way on. I was about to get on here and warn you about that until I got to the last post. In all the research I did, no one ever mentioned that.
Old Apr 19, 2016 | 05:13 PM
  #135
Yah man. That would've screwed everything up! So if your reading this thinking about doing the disc swap, drill em out.
The 9/16 bit worked perfectly. Fits nice and snug now. I actually only drilled out 5 of 6 stud holes. One of the studs doesn't cone out. Then I tore into the brake calipers. The bolt sleeves hadn't been greased regularly and were rusted bad. Took me a long time, pb blaster, and many hammer wacks to get them all out. I wire wheeled them, greased them, and put one caliper back together. Some boots got destroyed and a sleeve too.
I'm hoping to find new boots and sleeves to put the other one back together. But one is good so I can make a bracket now!
Old Apr 19, 2016 | 06:39 PM
  #136
Gizler00's Avatar
Very nice work Pat. You should be able to get all the rubber and other parts for those calipers pretty easy.
Old Apr 20, 2016 | 05:16 AM
  #137
Old Apr 20, 2016 | 05:34 AM
  #138
Gizler00's Avatar
There you go. I always buy them from the local parts houses we use here for the school. Always fairly cheap.
Old Apr 20, 2016 | 11:17 AM
  #139
I'm addicted to ebay and like getting packages in the mail. Physically shopping is so old skool Mark!
Old Apr 26, 2016 | 06:05 AM
  #140
Spent hours yesterday with a goal of finishing the caliper mount. I had to remake the bottom bracket piece but 2nd time around it didn't take me long. The other day I bought a 40 piece metric tap and die set from harbor freight for $13! And I got some free batteries haha.
So glad I have my drill press! The caliper bolts were m10x1.25. This was my first time using a tap. It was pretty fun actually. Welded the pieces together after a fit test on the rotor.
Then I bolted it all on to make sure everything fit.
I just need to play around with some washers to shim it to perfection, spray some paint on it, and its done! The next one should be way easier. There's a poker run at tuttle creek orv next month I'd love to enter so I gotta button this thing up!!
