Bump's '90 4Runner Build-Up
Old May 19, 2015 | 05:30 PM
  #261
bump530's Avatar
Killer work as always!
Thanks
Got a little bit more done. I installed the painted intake and built a support for it. I also installed the Spartan locker and new bearings on the carrier. Just need to pull the bearing off the pinion and I can start putting it back together.
I was supposed to build the driveshaft today but the guy helping me had something else come up. So we are going to try again tomorrow.
Old May 22, 2015 | 05:23 AM
  #262
bump530's Avatar
Still no driveshaft, but I did get the hood installed yesterday. I had an issue with my "fancy" hood pins tho. When installing the pins on top of the core support, the pin is straight up and down. BUT...the hood is at an angle. The way the poly bushing is built, that wont work. I was aware that might be an issue before I even bought the hood pins, but I figured I could work thru it. For now, I just found some stainless "washers" of some kind we had laying around the shop and made plates to cover the big holes in my hood and be able to use the pins. Anyways...on to the pics
First I had to clearance the hood some my radiator mounts. So I put some grease on the areas I thought might hit and checked where it was hitting.
The cap wasn't hitting, but the stud sticking up was. So I drilled a hole for clearance (No pic of the hole though).
Then I installed the hood pins in the top of the core support and used the same grease trick to drill holes in the hood for the pins
When I tried fitting the bushing, my fears where confirmed...they don't fit.
I even tried notching the bottom side of the bushing, still no fit
So I found some stainless washers laying around and drilled out the holes to fit the pins
Now I just need to drill the small holes in the hood for the rivets and rivet it down.
Before I do that tho, Im gonna try one more idea to try to angle the pin so its perpendicular to the hood so I can use those poly bushings. Maybe it will work lol.
Old May 25, 2015 | 06:09 PM
  #263
rustED's Avatar
That's a bummer about the hood pin bushings not working, but nice work using the stainless washers! She coming along great, can't wait to see some pics of her in action!
Old May 26, 2015 | 05:59 AM
  #264
bump530's Avatar
I finished the hood pin install.
I also got the 2.5 pipe machined for my rear driveshaft, however, he didn't do a very good job and he also cut the pipe way too short. This is how much of the original tube would be sticking out, with only about 0.5" inside of the pipe.
So I decided to try to build a real driveshaft. I cut down the factory rear driveshaft and also cut off the factory CV off the front driveshaft. Im going to take it over to a guys house to get it squared up and welded up. If it vibrates, Ill take it to have it balanced.
Old May 27, 2015 | 06:10 AM
  #265
bump530's Avatar
Well I finally made some progress on my rear driveshaft. We ended up taking the CV joint apart and putting it in a lathe to cut the shoulder down to fit inside the driveshaft tube.
We then set it up so we could put a dial indicator on it to get it as square as possible. Ended up getting it with about .005.
After that we welded it up. I still need to put the CV back together. Im thinking I may clearance it to give me some more angle too. I plan on doing that this evening.
Old May 28, 2015 | 04:48 PM
  #266
wberry85's Avatar
Impressive work.
My front axle looks almost identical in terms of paint scheme. Great minds think alike.
Old May 29, 2015 | 04:15 AM
  #267
bump530's Avatar
Originally Posted by wberry85
Impressive work.
Thanks. And yea they are pretty close to the same. Yours is looking good.
Old May 29, 2015 | 04:23 AM
  #268
bump530's Avatar
Well here is a couple pics of my driveshaft.
It just needs some paint now. Ill do that when I pull the rear end back out to weld it up and paint it. After I got the driveshaft installed, I set my pinion angle and put some pretty good tack welds on the spring perches. Then I did this (don't pay attention to my dad's commentary lol)...
I also made a lap around the yard just to do it. Now its time to get the streetable. First up will be getting the rear 3rd member back together and getting rear shock mounts built. Im hoping to start knocking this stuff out quickly.
Old Jun 7, 2015 | 02:11 PM
  #269
bump530's Avatar
Well some more progress has been made.
Read shock mounts are done. Just need paint
Rear third member is rebuilt, installed and the axle is painted
I didn't get as much done as I would have liked this weekend. That's mainly due to rear wheel bearings. When I pulled the axles out to install the third member I found out both rear bearings were bad. I spent better part of Saturday chasing parts and learnings the tricks of replacing the bearings lol
I'm about to order some parts. I'm getting closer to getting it road worthy
Old Jun 8, 2015 | 03:19 AM
  #270
wberry85's Avatar
Love those clean brake lines on the rear! Its the little things that will find a way to burn your entire Saturday sometimes...
Old Jun 8, 2015 | 07:27 AM
  #271
bump530's Avatar
Thanks. And yea they do but that's how it goes sometimes lol.
Well I just placed an order for some rear pro comp shocks, TG battery box, u-bolts, and tcase ouput flange. Hopefully all that will be here by the end of the week so Ill have some more parts to throw at it next weekend lol.
I also forgot to mention earlier that I didn't clearance the CV joint when I had it apart. I thought since it was going on the rear it wouldn't need to be but I was wrong lol. So now I have to take it back apart to clearance it.
Old Jun 18, 2015 | 10:03 AM
  #272
bump530's Avatar
So Im still making progress, slowly but surely...
Did some painting and got the rear end installed with new shocks. The shocks are 12" travel pro comps. They measure about the same as the 12" bilsteins from TG. I did have to pushing the bolt sleeve out of them and use a piece of 3/4"x.120 DOM tho.
I decided to bolt the TG battery box in (not painted in the pics)
I also extended my steering shaft with a piece of 1"x.120 DOM
Weather permitting (the 4runner is parked outside right now), Ill install the drive shaft, steering shaft, and battery box this evening and flex the front end to see where to set my bump stops at. Hoping by the end of the weekend, the only major thing Ill have left before I can drive it down the road is exhaust. My goal is to drive this thing to work on my bday (july 1) so Im trying to get this stuff knocked out lol.
Old Jun 19, 2015 | 10:56 AM
  #273
bump530's Avatar
Did a little flex testing in the biggest ditch around my house lol. Not quite big enough to fully flex out the suspension, but my 2 year old had a blast lol
Ive got a pretty good leak on one of my hydro-assist plugs on the steering box, just needs a little Teflon tape and itll be good to go. Front shock hoops and bump stop pads go on this weekend between everything else I have going on lol
Old Jun 19, 2015 | 12:59 PM
  #274
RoBatt's Avatar
Looks Awesome!!
Old Jun 20, 2015 | 03:54 AM
  #275
wberry85's Avatar
Looks good man. Such a good feeling when you get her flexed out for the first time.
Old Jun 20, 2015 | 05:31 AM
  #276
bump530's Avatar
Originally Posted by RoBatt
Looks Awesome!!
Thanks
Thanks. Yea it felt good to flex it a little. Gonna feel even better just to drive it work lol
Old Jun 21, 2015 | 10:43 AM
  #277
rustED's Avatar
Nice work, looks awesome! Bet it feels good to finally be able to drive it!!! Sorry if I missed it, but what size Swampers are those?
Old Jun 21, 2015 | 12:00 PM
  #278
bump530's Avatar
Thanks man. Yea it feels good to able to move it around under its own power. The tires are 36x12.5. Got a smoking deal on them.
Old Jun 22, 2015 | 07:19 PM
  #279
bump530's Avatar
Finally made some progress on the front shock mounts tonight. I got the driver side welded up. I plated the frame with 1/4" plate and used the same stuff to build gussets for the hoops. I felt this were easier to get a better weld than the tubes supplied with the TG kit. I also welded a small tab to the frame to use a cushion clamp to secure the brake line. Tomorrow I'll knock out the passenger side.
The light in my shop sucks right now. The light over the front of the 4Runner blew out and I can't get up there to change it until I move the 4Runner lol.
Old Jul 1, 2015 | 06:09 AM
  #280
bump530's Avatar
Well my plan was to have it driveable for today and I almost made it. Made my first real test drive yesterday and discovered that the trans doesn't seem to have 2nd or 4th gear. Not real sure what Im going to do about that yet. Im tempted to just pull it and have a shop go thru it.
I took a pic of it this morning. I had planned to drive it to work today for my 30th bday lol.
