Broke and driftin SAS
Old Mar 14, 2014 | 07:13 PM
  #41
kornhuskerwizard's Avatar
California area code showed up on my phone...Allpro says my springs i ordered are on backorder for 3to4 weeks. The guy was very nice and considerate about it and ill just wait as im still getting my 220 hooked up in the garage so its all well.
Old Mar 16, 2014 | 08:38 AM
  #42
Gonna bring my front axle in the garage and start disassembling it.
Old Mar 16, 2014 | 12:41 PM
  #43
Dad helped me load the 85 axle outta my yard and into the garage, i made a makeshift bench for it to start disassembly to rebuild it,clean it up,paint it, and install the upper gusset after i hack off the crap i dont need. Ill post some picks later..gotta go to wild game feed.free will donation, alligator,pheasant,beaver,deer,raccoon are just a few of the things to try.yummy...and theres beer inolved as well.YAY
Old Mar 16, 2014 | 05:07 PM
  #44
Heres the 85 axle in the garage.
Old Mar 17, 2014 | 05:12 AM
  #45
Gizler00's Avatar
Making progress! I wish I could have went to the Wild Game feed!! Love eating good like that.
Old Mar 17, 2014 | 07:25 AM
  #46
92yota92's Avatar
Have you considered your pinion angle? now's a good time to turn the nuckels if you need to, I wish I had.
Old Mar 17, 2014 | 05:05 PM
  #47
gave me a stomach ache but it was still great
Hmmmmmmm.........So your not talking about shims under the spring plates when adjusting pinion angle???
Smack these with a brass drift and theyll bust loose.
Cut some stuff
Helped KelvinB With some chevy 63's blew the old bushings out, cleaned up and painted with urethane bushings
Old Mar 17, 2014 | 05:08 PM
  #48
So can i cut off the steering stabilizer brackets with the high steer??Im assuming YES
Old Mar 17, 2014 | 06:24 PM
  #49
Yes they will be removed as well...Name:  20140317_182023_zpsktuqczw8.jpg
Old Mar 17, 2014 | 06:28 PM
  #50
Whoops sorry about the repost photo... So in order to use my allpro springs do i need to install a 3/8" thick pad to the drivers side spring perch pad???
Old Mar 17, 2014 | 09:45 PM
  #51
rustED's Avatar
Post
Yeah you can cut off the steering stabilizer brackets off the axel, if you decide to run a stabilizer most people weld tabs to the frame. I planned on running one when I first sas'ed mine, but after driving it didn't think it was needed. Does your Allpro springs come with a 3/8" pad? I had to make my own, I think I welded a 1/4" plate to the driver side spring perch when I did mine, it turned out level.
Nice progress on the axel tear down! Are you going to use your ifs wheel hubs and up grade the brakes, or use wheel spacers?
Old Mar 17, 2014 | 09:57 PM
  #52
scuba's Avatar
Yes you need the spring pad.
The drivers side perch is 3/8" lower than the passenger side.
Old Mar 18, 2014 | 03:35 AM
  #53
Im undecided, i thought i use my ifs hubs or upgrade the brakes rather than the spacers.
Thanks scuba,
Old Mar 18, 2014 | 05:37 AM
  #54
rattlewagon's Avatar
Ifs hub swap is easy peasy. You can also weld 3/8 plate to the drivers perch to bring it up, which is a great time to extend the perches.
Old Mar 18, 2014 | 07:32 AM
  #55
92yota92's Avatar
It's not always necessary, but with 5" of lift up front even a high angle driveshaft can have problems. shiming the plates works to a point untill your caster bearings get flat. If you don't care about your caster bearing angles then shim away but in my experience it gets a bit sketchy after like 10 degrees. You have to shim a lot for there to be an issue with your steering linkages but it's possible.
If you're shimming alot I would advise you make them out of steel and weld them in place, the aluminum pre made ones can pop out.
The nuckle turning isn't terribly hard if your good with a grinder you just have to be carefull, then if you shim your perches the caster bearings are back to normal, or you can cut and rotate the perches and use no shims.
It's alot of work and some might say uneccessary but I think many would argee it's the best way to get the pinion where youw want it with more or less no cost but time.
I didnt' bother putting the stabaliser on either.
Old Mar 18, 2014 | 01:54 PM
  #56
Great information to know!!! I am running 4"allpros so hopefully the angles not to bad.
Old Mar 18, 2014 | 03:06 PM
  #57
Terrys87's Avatar
I forgot about you doing this thread. You are making some great progress. The Wild Game Feed sounds great!! I have tried several different things as well.
Old Mar 18, 2014 | 05:39 PM
  #58
did some more cutting and grinding,
3rd member looks good,just filthy
do these tabs get cut off with the bolts??Not the shock mounts of course...
and the perch on the bottom??
my front spring hangar...tryin to figure out what kind it is...The shackle bolts are threaded to where the threads will rub on the bushings, which isnt good, Gizler told mr thats a trait of trail gear...
Had to help my bro get his cylinder head off tonight and it was parent teacher conference and my boy is doin great!!!YAY!!!But i didnt get as far as i wanted. It looks as if the PO of the front axle didnt ever change the axle grease...very broke down and dirty but the ring and pinion look to be well so i hope theyre ok.
Old Mar 18, 2014 | 06:14 PM
  #59
By the way this is a little off topic, but not justifiable yet to start a engine swap thread.... I am debating on tbi,cpi,or sfi 4.3 swap for i have the adapter and clutch setup... I was wanting to do cpi but have fell upon a 2000ish?? safari awd van that i know runs (it has a balljoint out)and i beleive i could pick it up for a reasonable price...however i know the sfi engine is more wiring and obd 2 compared to the cpi .Is itt worth it if i could pick the entire van up for like $500??
Old Mar 18, 2014 | 06:21 PM
  #60
Looks like the bottom perch on the right side of axle stays!!Good thing i didnt hack it off.
