Broke and driftin SAS
Old Nov 5, 2014 | 03:51 PM
  #361
kornhuskerwizard's Avatar
Originally Posted by rustED
AllPro springs!
Yes!!
Originally Posted by bump530
Glad to hear your making progress. It can definitely be challenging at times.
Thanks!!
Originally Posted by Gizler00
Keep plugging away buddy. Maybe sell the rest of the blazer to fund the rear springs. Don't forget I want to buy those other springs from you as well. I think, since you are in no hurry, just keep building and add what you want when you can.
You are along a lot of progress with this truck. It's going to be a nasty rig when it's done.
Thanks man,yes I'll definetly sell the rest of the jimmy to buy more parts for the build,and those springs are yours.
Old Nov 6, 2014 | 04:56 PM
  #362
Old Nov 6, 2014 | 05:00 PM
  #363
Picked up some used shackles for the rear.probably the best $20 I've spent in awhile.
Old Nov 6, 2014 | 06:45 PM
  #364
rustED's Avatar
Nice $core!
Old Nov 7, 2014 | 07:49 PM
  #365
Terrys87's Avatar
Nice score on the shackles. I have always wondered what all was involved in doing a motor swap with a domestic motor to a Toyota tranny. The 4.3 is a great little motor and quite powerful for a 6 cylinder.
Old Nov 10, 2014 | 05:40 PM
  #366
Thanks Terry,domestic to Toyota all depends on the details.efi...more $$$ but more dependable,carbd....cheaper to build.
Old Nov 11, 2014 | 06:25 AM
  #367
bump530's Avatar
I really cant see a carb setup being that much cheaper if you do most of the work yourself, unless your converting a carb'd motor into efi. The only part of my swap I don't plan to do myself is the PCM reprogramming. Im going to do all my wiring (or at least attempt to lol)
Old Nov 11, 2014 | 10:32 AM
  #368
Crazy_Guy97's Avatar
Do you have the cluster board from the jimmy if so is it good?
Old Nov 11, 2014 | 05:39 PM
  #369
I wish you luck!!
Yep,its in nice shape,126k on the clock.
Old Nov 12, 2014 | 08:09 AM
  #370
Would it hook up to a 350 turbo transmission speed cable?
Old Nov 17, 2014 | 05:05 PM
  #371
No,new speedos run off a vss signal,totally different than the cable.
Old Nov 17, 2014 | 05:23 PM
  #372
So my 4.3 has a crank sensor ignition system....therefore has no adjustable timing,however the Howell aftermarket harness will require going back k to the adjustable earlier distributor... guess that means I have to swap timng covers to so I can have a reference point.by the way there's no way to use the factory computer or harness,or modify it either that I've found so far.what a pain.
Old Nov 17, 2014 | 06:28 PM
  #373
bump530's Avatar
That's weird you can't use the factory stuff wiring and computer.
Old Nov 18, 2014 | 04:32 PM
  #374
Gizler00's Avatar
Sorry to hear that buddy. You will get it figured out.
Old Nov 18, 2014 | 04:39 PM
  #375
Well,its because the donor was a late 95 CPI setup with the black vcm under the hood,if you go later than that,or earlier than that on the CPI your in better shape. Using Howells harness will make my engine like the early CPI setup. This will require changing the crank trigger and cam sensor distributor to the earlier 87-94 electronic distributor.I should be able to find one of them easily in the junkyard. Now maybe if I utilized the auto tranny from the donor (which I still have) I could use the factory harness and vcm.but I really want the 5spd w56 beings I have all the adapter hardware.
Old Nov 18, 2014 | 07:01 PM
  #376
bump530's Avatar
So why can't you use the harness and computer you have the the toy trans? Just remove all the trans wiring and have someone program the computer to work with that. Might want to check out LT1swap.com
Old Nov 19, 2014 | 05:26 PM
  #377
I will,but Howell said the black vcm under the hood is not reprogrammable.
Old Nov 19, 2014 | 05:47 PM
  #378
I checked the website,couldnt find any CPI or csfi info,mostly L's and tpi stuff.but good info in general!!
Old Dec 9, 2014 | 05:26 PM
  #379
Anyone ever tried running a fuel injected pump and housing in a carbd fuel tank?? I know the f.I tank has a square box in the bottom compared to the carbd tank.
Old Dec 15, 2014 | 05:31 PM
  #380
Dang all pros got 10%off til dec31st!!sure would like to get me that rear kit for my rig!!
