Broke and driftin SAS
Old Oct 26, 2014 | 06:59 PM
  #341
85sr5excab's Avatar
Yea,,no progress ... but took my kid ridin at the MX track,he did pretty good.sorry need to get going on the build!!
Hey kids are more important that toyotas! Keep em happy!
Old Oct 27, 2014 | 04:04 AM
  #342
Crazy_Guy97's Avatar
I have a 1994 Toyota Extend cab with a 4.3 chevy motor,350 turbo transmission and chevy running gears on 33x12.50. Dual flow masters and has a solid axle . I bought the truck with it done like that. As so far the guy that done it did good with the the conversion. Its at my papaws house so no pics.
Old Oct 27, 2014 | 05:53 PM
  #343
kornhuskerwizard's Avatar
I'm trying to decide the best route on a wiring harness for the truck,its either use the factory harness with the big black vcm out of the donor 95jimmy,or I've been looking into Howell,painless,ad Jim's aftermarket harnesses.plus I have to deal with o2 sensors and vss signal for the obd2 system. TBI 4.3swap would be far easier...but it will pay off with the vortec motors higher HP and rpms.this build is getting interesting.
Old Oct 27, 2014 | 06:48 PM
  #344
kelvinb's Avatar
Aftermarket tuners can bypass emissions and modify settings within the ecu.
Old Oct 27, 2014 | 07:09 PM
  #345
bump530's Avatar
I'd stick with the black PCM. Just send the computer off and have it reprogrammed.
Old Oct 28, 2014 | 04:26 PM
  #346
Removed the stock fuel tank out of the donor jimmy.I'll also get the lines and filter setup to. Dunno yet what fuel system I'm gonna run yet but having the stock setup it had won't hurt to keep around.by the way these s10s,Jimmy's,blazers all suck for clearance to get to stuff or removal. And the p.o put a new pump in and I scabbed 3gallon of fuel for my d.d.
Old Oct 29, 2014 | 05:01 PM
  #347
Been doing alota research and have found no yotas with the CPI 4.3 mated to the Toyota tranny.all I've found are utilizing the 4l60e.
Old Oct 29, 2014 | 05:40 PM
  #348
rustED's Avatar
Hey Chris did you check Northwest Offroad? I thought they had adapters to use either Toyota manuel, or GM auto.
Old Oct 30, 2014 | 04:11 AM
  #349
bump530's Avatar
Are you wanting to run the Toyota manual trans? If so, Im sure its the same as running a toy manual trans on any 4.3 motor.
Old Oct 30, 2014 | 05:15 PM
  #350
Talked to Howell engineering today,I was told the 95computer , vcm, whatever you wanna call it cannot be reprogrammed. 92-94 is easy compared to 95. I will have to change my ignition system (distributor and coil) from the factory crank sensor ignition,which sucks cause I liked how low profile the 95 distributor was,get a aftermarket harness,computer,and custom tune. I was quoted around $650. I hate to drop the coin on it but I have a feeling it will look clean,be less of a headache,a simpler obd system,and I can delete out the vss and other crap. On that note if you want to do a CPI 4.3 swap I recommend going with the early 92-94 years,also sfi 96and up is OK to. It seems I chose a hermaphrodite year.
Old Oct 30, 2014 | 06:05 PM
  #351
rattlewagon's Avatar
Thats a bummer on the odd ball year. But getting rid of the vss would be awesome!
Old Oct 31, 2014 | 05:37 AM
  #352
If I'm not mistaking there is bell housing for 350 engine that goes on a Toyota transmission.I don't know my Chevy engines (yet) could that mount up to 4.3 .
Old Oct 31, 2014 | 01:23 PM
  #353
Yea a 350 and a 4.3 are identical other than having 2less cylinders ,and my engi e is internally balanced,no harmonica dampener.
Old Nov 2, 2014 | 06:46 PM
  #354
Gizler00's Avatar
So that advance adapter bell housing you have wont work then?
Old Nov 3, 2014 | 01:22 PM
  #355
Yeah the adapter will work,and hopefully the clutch setup will to.its a aisin clutch disc,center force gold clutch plate,and I dunno if its a 168 or 153 tooth flywheel.it would be nice to use the stock starter off the jimmy cause its small and gear reduction like the factory Toyota one.
Old Nov 4, 2014 | 07:23 PM
  #356
kelvinb's Avatar
Put a crank on it like a model t
Old Nov 5, 2014 | 03:59 AM
  #357
Or a kick start!!yea I did some stick welding in my passenger motor mount last night.I was using 6010 and I really wish I had our wirefeed dual sheild miller from work,so much easier to weld with.once I get this motor mount welded the 4.3 will be getting close to dropping in the engine bay.
Also trying g to figure out how to make the rear level with the front.I wish I could order some matching all pro spring for the rear, but I might have to wait on that and use some longer shackles and blocks for now. Also wanna flip kit,I hate how the factory u bolts snag up on everything facing downward and how the shocks mount to the leaf plate.using a flip kit you have to remount the shocks on the bottom end.
This is by far the most challenging build I've encountered on my own in the Toyota world.
Old Nov 5, 2014 | 04:44 AM
  #358
bump530's Avatar
Glad to hear your making progress. It can definitely be challenging at times.
Old Nov 5, 2014 | 06:56 AM
  #359
rustED's Avatar
AllPro springs!
Old Nov 5, 2014 | 01:38 PM
  #360
Gizler00's Avatar
Keep plugging away buddy. Maybe sell the rest of the blazer to fund the rear springs. Don't forget I want to buy those other springs from you as well. I think, since you are in no hurry, just keep building and add what you want when you can.
You are along a lot of progress with this truck. It's going to be a nasty rig when it's done.
