Broke and driftin SAS
Old Sep 17, 2014 | 05:55 PM
  #281
rustED's Avatar
Looking good! nice to see it on all 4's!!!
is it the IFS locking hubs your taking about? if so somebody (I think Marlin and TG) make inner hub gears that converts them to the correct number of splines, can't remember what they cost tho...
Old Sep 17, 2014 | 06:04 PM
  #282
85sr5excab's Avatar
Lookin good man. Ya ifs lockouts don't fit on sfa. Gotta reuse the sfa ones. On a good note ppl snatch the ifs lockouts up on here like hot cakes. Got $90 shipped for mine.
Old Sep 17, 2014 | 06:11 PM
  #283
kornhuskerwizard's Avatar
Thanks ED!!
Thanks,yea I've noticed the ifs lockouts are a hot item at the junkyard,if you know how to takem off without destroying them.
Old Sep 17, 2014 | 06:41 PM
  #284
kelvinb's Avatar
i wonder if you can just take the sfa inner gear out and swap it into your ifs hubs
Old Sep 17, 2014 | 07:06 PM
  #285
rattlewagon's Avatar
you can get the conversion gears from Davez. You can either use your entire solid front axle lock out hubs, our you need to get the special conversion gear to make IFS hubs work on a Solid Axle.
read-ski: http://www.pirate4x4.com/forum/suzuk...ts-toyota.html
Old Sep 17, 2014 | 07:36 PM
  #286
Gizler00's Avatar
Truck looks great.
Sell those babies. I always snag the hubs at the yard if I have time. Can manage to get both sides totally off in about 20 minutes with the right tools while I'm there.
Old Sep 18, 2014 | 05:16 AM
  #287
bump530's Avatar
Feels good to have it sitting on the ground finally huh? Looking good.
Old Sep 18, 2014 | 05:33 AM
  #288
pyrojoe22's Avatar
Your shackles will sag a little more once you cycle the suspension a bit (300-500 miles). Mine was sitting so high when I did the SAS that I was mad because I could've easily fit 40's, but now it's settled about 1 to 1 1/2 inches. They were 5" springs that raised it 7" right after the installation.
Old Sep 18, 2014 | 05:37 PM
  #289
Thanks guys,yea I'm sure it will settle down after the engines in and a few miles,I'm bouncing back and forth on this build and my runner,plus I'm trying to get ready for winter and stock up on firewood to heat the garage if I wanna keep my projects rolling.
Old Sep 18, 2014 | 06:51 PM
  #290
lil_red_yota's Avatar
I'm going to have to keep an eye on this thread. I want to do a sas on my 92, but not really feeling a motor swap seeing as i just put a new 22re in it. So the ifs hubs (not the locking hubs, the knuckle I guess) bolts straight to the solid axle?
Old Sep 19, 2014 | 01:48 AM
  #291
Terrys87's Avatar
Great to hear you having it on the ground again. I made getting ready for winter a priority this year. Couldnt do anything last year and it will be here before you know it. Working in the cold and frozen is for the birds.
Old Sep 20, 2014 | 04:36 PM
  #292
Gizler00's Avatar
Totally right terry. And the rust will be forming before you know it. I might give oil coating my runner a shot this week
Old Sep 21, 2014 | 05:53 AM
  #293
Nothing wrong with the 22re,great engine..I just found the parts to do the 4.3swap at a price I couldn't turn down.and yes,the ifs spindle mounts on the straight axle,or u can get the spacers.
Old Sep 21, 2014 | 06:49 AM
  #294
I know ppl that have had a lot of problems with wheel spacers. That's why I was asking about the spindles.
Old Sep 22, 2014 | 05:26 AM
  #295
pyrojoe22's Avatar
I used to soak the entire undercarriage with ATF, then drive down my country roads immediately afterwards for a dozen miles to get a good coat of dust on everything, to keep the salt from setting directly on the frame and body. Now the undercarriage is all sand blasted and coated with POR-15, so I don't worry about it.
Old Sep 22, 2014 | 01:24 PM
  #296
Joe have I mentioned your truck is way RAD????!!!!!
Old Sep 22, 2014 | 01:39 PM
  #297
pyrojoe22's Avatar
Meh... soon yours will be way cooler. Can't wait to go wheelin with you! By the way, I'm only 1 hr 20 min from you now.
Old Sep 22, 2014 | 01:54 PM
  #298
Gizler00's Avatar
I want to go wheeling with you guys and see your truck!!
Old Sep 22, 2014 | 01:58 PM
  #299
Gizler00's Avatar
I want to go wheeling and see your truck pyrojoe!!
Old Sep 22, 2014 | 06:29 PM
  #300
Tried getting banjo bolts for my calipers at the local Napa and they didn't have the right ones,so I went out to the garage and blocked up the rear end with cribbing and jackstands to get it level with the front and removed the rear end . I also bought a 84ex cab 4x4 from Kyleb for $500 for more parts,its set up with a 4.3 carbd and a th400 tranny with the 205 transfer case. It has practically new bilstein 5100s for the rear of my builld and that's where I got my extended s.s brake lines too.I'll post some pics of all the junk. Haha. On a good note my 87s frame is in really good shape, it also has 123k miles on the truck,my neighbor bought it new in 87.
