Bone Collector's 94 xcab 3.0 build thread
Old Sep 26, 2013 | 06:07 AM
  #181
bone collector's Avatar
Originally Posted by SpeedCrazy
Thats a good idea. Should work great in your case. I'm not yet to the point where i want to bob my bed. It has to earn its keep yet.
Thanks. I'm going to take the bed off, cut it all up, and weld it back together. And while the bed is off the frame. I think I will clean up and paint the frames as well. It will be less work than the frame repair I had to do to the 87. Trying to think for the long haul.
Old Sep 26, 2013 | 06:14 AM
  #182
SpeedCrazy's Avatar
Definitely clean up the frame, i wish i could afford the down time to take my bed off and clean and paint the frame and bed underside.
How many inches are you planning to take out?
Old Sep 26, 2013 | 06:28 AM
  #183
10 to 12 inches. The rust on the bedside will determine how much I take out.
Old Sep 27, 2013 | 03:22 PM
  #184
I have the truck all marked out and ready for surgery. Bed bob will 12 inches. Time to cue the music and get to work
Old Sep 28, 2013 | 12:06 PM
  #185
My wife just told me that she was scared for my truck because of how much cutting I have done today. Guess that means I'm doing something right. Lol
Old Sep 28, 2013 | 12:07 PM
  #186
SpeedCrazy's Avatar
PICTURES!! I would be scared to death to cut on my truck like that.
Old Sep 28, 2013 | 12:15 PM
  #187
I will load some pictures in a bit. I took 2 n half inches out of all four wheel wells. Cut the bottom of the bed off behind the wheel wells. And I'm getting ready to do the final cuts for the bob right now. 12. Inches are coming out. Got a friend coming over for the weld up too.
Old Sep 28, 2013 | 12:24 PM
  #188
SpeedCrazy's Avatar
Your cutting the wheel well? If i might ask, why? Won't that necessitate a higher lift for large tires?
Old Sep 28, 2013 | 12:29 PM
  #189
I had rust holes in 3 of the wheel wells. And the 33s definitely won't rub now. Lol. Probably could fit 35s now. Lol
Old Sep 28, 2013 | 12:44 PM
  #190
SpeedCrazy's Avatar
Okay, so thats the clearance you have with 33"s right?(you can just see the fender edges in the pic). 35"s would fit yes, but you couldn't hit a mole hill let alone flex. Atleast from what i can see, but you know your truck and i'm sure it will turn out awesome whatever you do.
Old Sep 28, 2013 | 12:47 PM
  #191
That picture is the rims I cleaned up to put my truck. The truck on the picture is my old 87. Those tires are 31s.
Old Sep 28, 2013 | 07:14 PM
  #192
Well I have a lot done. But a lot more to go. All of the fenders have been trimmed 2 n half inches. I cut 2 inches off then " rolled" the last half inch. I cut 12 inches out of the bed and it's welded back together. A friend of mine came to help with the welding duties. We also scrubbed the frame down and painted it with bed liner. Tomorrow I will grind down the welds, put on some bondo and reassemble the truck. I will also cut and patch the 2 big holes that are in the bed. If I have time, I will apply a layer of bed liner to the bed to help preserve the bed for the long term. Lots to do!
Old Sep 28, 2013 | 07:27 PM
  #193
julsruls's Avatar
I like it. Make sure to put paint or something onany part you cut or trimmed. And your gonna need to test fit some 35s now.
Old Sep 28, 2013 | 07:34 PM
  #194
Ya thanks for the reminder. I have some primer to apply on all parts that I cut. I'm going to enjoy the 33s for a bit before I go looking for a set of 35s.
Old Sep 29, 2013 | 06:14 AM
  #195
Some more pictures
Old Sep 29, 2013 | 11:54 AM
  #196
SpeedCrazy's Avatar
Ah, okay, that makes more sense. Looks pretty good.
I realized where i was misunderstanding you, i read bob and 2 inches out of fenderwells. I thought you were narrowing not extending... derp.
What you did looks solid, how did you roll the edge?
Old Sep 29, 2013 | 12:35 PM
  #197
Mark fenders at 2 and 2 n half inches
Cut off first mark
Cut many vertical cuts up to second line
Fold over tabs and tap with a hammer to smooth it out. Trim bumper and valance to match
Old Sep 29, 2013 | 01:37 PM
  #198
SpeedCrazy's Avatar
Cut off first mark
Sounds easy enough. Looks real clean too.
Old Sep 29, 2013 | 03:18 PM
  #199
And done for now!
Old Sep 29, 2013 | 04:03 PM
  #200
I still have to do the bed liner and sand down the bondo. But for now I am done. I am exhausted. I will try to finish it up by next weekend
