92ehatch's 87 4runner build up
Old Feb 14, 2016 | 01:15 PM
  #41
92ehatch's Avatar
Well i got sick again so not much done, however i did find a guy on Craigslist with some parts.
Got a good vafm to replace my bad one. I think it will work even though it's from the newer style 22re.
Got a Crank pulley bolt, mirror, climate control bezel.
It's different from mine but i kinda like it better.
I also picked up a newer style tb thinking i could use it but the iac valve doesn't work with the old style manifold. It says bad tps on the side but it tests good.
I cleaned up and adjusted my factory air valve instead. It tests good and will work fine
Good vafm from newer 22re i think will work fine if someone cares to confirm
Has a light in it but i think I'll just paint the cover with the body
Different from stock but i like it and is not faded out and cracked
I won't need this if anyone is interested in it or the tps from it pm me
Old Feb 14, 2016 | 03:36 PM
  #42
SwVa_1stGen's Avatar
Originally Posted by 92ehatch
I got them from charlies junk in hendersonville nc.
I don't know where you live but if you are in this area you can have my old rear glass. Is scratched but functional
Deal let this snow get out, I may ride over next weekend.
Did you see any more runners in that junk yard?
Im not far from you or ladybug
Old Feb 14, 2016 | 03:40 PM
  #43
I love to see these old runners fixed back up, seeing some of these build threads where guys take good looking 4 runners and just totally gut them makes me sick lol.
Old Feb 14, 2016 | 04:02 PM
  #44
92ehatch's Avatar
This 100% drives me crazy as well. I can understand buying one wrecked and crawling it, but taking a good one spending thousands then running it is crazy.
Old Feb 14, 2016 | 04:04 PM
  #45
92ehatch's Avatar
Yes there were a few. Pm me when you decide to ride and I'll get the glass out of the tailgate for you.
I may run to charlies next weekend add the weather should be nicer as of the forecast right now
Old Feb 14, 2016 | 04:13 PM
  #46
Will do, would like to look around the junk yard lol
We just got slammed with 6 of snow inches this evening, did get to run around in the 4runner though lol
Im about 40 min. north of Johnson city, just inside Va
Old Feb 14, 2016 | 04:31 PM
  #47
92ehatch's Avatar
Ok well you are about 3 hours away. This truck was bought band new at toyota of kingsport. That's where my grandfather lives
In fact we used to take this truck to a cabin he has just over the tn va line to fish hunt and ride 4 wheelers. Best home grown food and cooking I've ever had over there
Old Feb 15, 2016 | 05:22 PM
  #48
92ehatch's Avatar
Well work canceled today due to ice so i rented a hoist and pulled the motor out.
Next time I'll hook it closer, barely cleared the ceiling
Redneck engine stand 1x2's
When i took the pan off the timing chain bits were attached like this from a previous repair that didn't clean it out. I bet this thing was starving for oil.
Broken teeth on chain sprocket
Made in China
And it shows
Old Feb 15, 2016 | 05:31 PM
  #49
92ehatch's Avatar
Holy lots of stuff
Had some casters from a portable ac unit. Made a creeper
Old Feb 15, 2016 | 07:16 PM
  #50
ladybugRC's Avatar
You had a good day- nice progress!
You've earned a good beer.
Old Feb 16, 2016 | 04:57 PM
  #51
92ehatch's Avatar
I've got a hoppyum ipa from foothills brewery in Winston Salem. Yummy it is.
I'm contemplating painting the top, bumpers and grill black and removing the chrome since the windshield chrome is garbage but I'm afraid I'll ruin the original look of it. Opinions?
Old Feb 16, 2016 | 05:37 PM
  #52
rustED's Avatar
I think it would look good with a black top and de-chromed. It will give it a personal touch without straying to far from the original color scheme. I can see wanting to keep it some what original since it was your grandfather's, and you probably have good memories with him in it.
If I was keeping the original color on mine I'd probably do the same thing, but I'm going to be changing everything lol.
Old Feb 18, 2016 | 01:38 PM
  #53
92ehatch's Avatar
Head and block are at the machine shop!
Parts cleaning and body work time
Old Feb 18, 2016 | 04:20 PM
  #54
Nervo19's Avatar
For the top I'd use black satin. For the former chrome parts instead of black I'd probably go with Rustoleum Hammered Black which comes out a deep charcoal similar to the original 4Runner painted bumpers. My grill and bumpers of my 1st Runner had that and it looked great. What is your body color going to be or is that a secret? You could actually go all VA Tech right now and just paint the cap orange to go with your body color. LOL
Old Feb 18, 2016 | 06:12 PM
  #55
92ehatch's Avatar
No secrets on color. I think I'll try and keep it close to original. I haven't decided yet. Depending on how much the motor costs will decide alot. I'm super picky and if i color change the jambs will have to go to.
I am however getting super irritated with this inner fender. I was grinding the welds down and found a spot that didn't get penetration then blew a massive hole in it. Is a tough spot to weld in plus I'm extremely new to it.
I think once i get some decent penetration there and fill the hole up I'll just seam seal everything really well, under coat it and let it be. Cosmetics there isn't really important but my constant need for perfection keeps me trying to do to much.
Old Feb 18, 2016 | 06:19 PM
  #56
arlindsay1992's Avatar
Things are way easier when you don't care. Just admit you'll never see it and move on.
Old Feb 18, 2016 | 06:38 PM
  #57
ladybugRC's Avatar
Sweet!
I'm with y'all on keeping it original color- would you redo the SR5 decals, too?
Sounds like you're feeling better, too! And once you put a battery in there you'll mostly forget about the cosmetics of that inner fender- but one afternoon while changing your oil you'll look up at it and smile at your first adventures in welding.
Old Feb 19, 2016 | 03:07 AM
  #58
92ehatch's Avatar
I found a guy who makes and sells the decals so i plan to get them as well. I have the rear sr5 badge inside the truck.
Old Feb 20, 2016 | 09:20 AM
  #59
92ehatch's Avatar
So i was trying to fit up a battery holder and realized that the original must have sat on the part of the inner fender that turns upward. Because after i tacked in my frame the water bottle didn't fit. 2 hours planning cutting and fitting to have to undo it all and re plan
Gonna get interesting now
Old Feb 22, 2016 | 02:37 PM
  #60
ladybugRC's Avatar
Man, I'm sorry- would it help to have some pictures? I could take a couple of shots with a tape measure in there to help you get an idea where things should go. Let me know!
Joe
