1991 pickup 5.3 swap...they said it wouldn't fit
Old May 12, 2016 | 09:26 PM
  #101
crum's Avatar
Originally Posted by 7.62x51ar
What size fly wheel and clutch did you use for your swap?
I used the 10mm thicker flywheel from mcleod and the centreforce clutch advance adaptors recommend for the bellhousing. I did opt for a heavier pressure plate because the ls will most likely make a bit more than a sbc
Old May 12, 2016 | 09:27 PM
  #102
magpede's Avatar
Did you use centerforce pressure plate?
Old May 12, 2016 | 10:37 PM
  #103
crum's Avatar
Sorry forgot to mention that part. Its a mcleod centre for the conversion and a centreforce sbc pressure plate. I'm not sure whether it would be possible to mill the bellhousing down a bit and use the ls clutch and flywheel with an internal slave cylinder like in the t56
Old May 13, 2016 | 08:23 AM
  #104
FGZ's Avatar
FGZ
Is it the popping and backfiring on the deceleration that's telling you there's a vacuum leak? Sounds really great otherwise...in my normal daily driving I'd probably never know unless there is a rough idle issue etc.
Old May 13, 2016 | 08:46 AM
  #105
magpede's Avatar
Actually, funny story, I found the vaccuum leak while looking up ways to route the steam vents. I somehow neglected to plug the small hvac port at the back of the intake. It loads up pretty bad at idle though.
New set of injectors exactly like what were in it with the truck intake are on the way.
Hopefully...finally....it will be running right next week then I can proceed with putting the front end back together.
Just in case anybody was wondering what was going on in the project downtime
Old May 17, 2016 | 08:00 AM
  #106
magpede's Avatar
Finally!!!
The O2 sensor connections were mislabeled on my harness. It finally idles without blowing black smoke.
Old May 17, 2016 | 05:20 PM
  #107
Radchadtrinidad's Avatar
That is SWEET
Old May 18, 2016 | 01:59 PM
  #108
magpede's Avatar
Originally Posted by Radchadtrinidad
That is SWEET
Many thanks.
Small update, I dropped off all my front end pieces at the sandblaster today. Hopefully I will get them back pretty soon.
Old May 24, 2016 | 05:14 AM
  #109
Justin Lenhardt's Avatar
beautiful. This is ridiculous, sending this to my chevy-enthusiast friend right now, he'll probably want me to do this to my car as well.
Old Jun 9, 2016 | 04:34 PM
  #110
magpede's Avatar
It's finally coming together.
My parts are back from the sandblaster and the fuel lines are done. Also finally got my clutch line hooked up and bled down.
I'll try to post up some more pictures later.
Old Jun 14, 2016 | 05:54 PM
  #111
christianlambert's Avatar
Old Jun 14, 2016 | 10:29 PM
  #112
84 yota dude's Avatar
Can't wait to see this thing drive!
Where did you get the engine from? A wrecker?
Old Jun 14, 2016 | 11:15 PM
  #113
magpede's Avatar
Yes, that's correct.
Old Jun 15, 2016 | 05:25 AM
  #114
magpede's Avatar
Old Jun 15, 2016 | 05:33 AM
  #115
magpede's Avatar
Old Sep 22, 2016 | 06:34 AM
  #116
magpede's Avatar
Well, house remodeling slowed me down a bit but I'm getting back to work on the truck.
Hurst shifter installed...feels about like my 6 speed now.
Getting my calipers re-powdercoated
I was terribly dissatisfied with them which was only made worse by the time it took. I'm having them done locally now.
Edge cs2 monitor I got to replace bully dog
Finally....FINALLY painted my arms
Took my driveshafts in to be worked on, they said they couldn't do anything with the front one so only having rear shortened. I'm going to pick it up Friday
That's it for now.
Old Sep 28, 2016 | 02:20 PM
  #117
magpede's Avatar
Well, driveshafts were a total bust.
Got two new ones on the way from tom woods.
Old Sep 28, 2016 | 04:05 PM
  #118
skypilot's Avatar
From your picture, I would have expected custom shafts. The certainly, nothing there to work with. The rear is probably too short for the front section.
But I'm glad you are making progress, that is a tight fit. Kudo's on getting this done!
Old Oct 4, 2016 | 08:24 AM
  #119
nickpohlaandp's Avatar
Dude, this build is awesome!!! I'm about to delve into something similar but I'm planning on going with a Gen III small block. Mine with be 2WD with the end purpose being a dragster with a license plate and a big bottle of nitrous. I'm definitely going to keep watching this though. Very cool with everything you've done. I started a thread for my build, but it'll be a while before I start posting pics, and a much longer while before there's any videos of it running. I've got to get my stepson something else to drive first, but that's in the works. Seems like most of what I've found in the forums are 4WD guys doing these types of swaps, so hopefully I'll be able to help out any 2WD guys later on. I plan on some heavy suspension mods with my build along the way as well since I'm shooting for 9 seconds in the quarter.
Either way, kudos to you dude, I love it. Any advice you have for me, I'll gladly take it.
Old Oct 4, 2016 | 09:08 AM
  #120
magpede's Avatar
All back from powdercoat and I'm very happy.
New parts came in.
NOW...just need to get the front end back together.
