1987 XtraCab small mods
Old Aug 3, 2013 | 06:47 PM
ManLen's Avatar
Just thought I'd show some of my fixes and mod to my 1987 XtraCab pickup
Not planning anything crazy yet, just a few little things here and there to make it a better rig than it currently is!
Today I decided to fix my droopy door with a little backyard fix
Basically it hung a bit low after some flexing off road and could still close but you had to lift and shut.
So grabbed some washers, unbolted the bottom hinge and slid them in between
I hope to get a replacement hinge one day from a scrapyard but this will save the clasp components for the time being
Attached Thumbnails 1987 XtraCab small mods-image-124942517.jpg   1987 XtraCab small mods-image-4001801353.jpg   1987 XtraCab small mods-image-126638032.jpg
Old May 21, 2014 | 11:29 AM
ManLen's Avatar
So finally got around to installing my new leaf springs
I purschased a set a of Old Man Emu Dakar leafs from http://raddcruisers.ca/
a while back with ubolts, shackles, bushings and nitrocharger sport shocks
cost what seemed to be an arm and a leg at the time but once they were in it was all worth it.
I noticed that I had substantial sag in the rear end and some somewhat light wheeling resulted in a broken leaf in the pack worsening the whole situation. It was time to replace
this what I started out with:
the new parts all ready to go
greasable anti-inversion shackles OME, greasable hanger pins, leafs, bushings and ubolts
Old May 21, 2014 | 11:33 AM
ManLen's Avatar
Starting the tear out, only had one close call with the lifting (not having proper jacks)
Had to basically cut out every part in some way or another.
Shocks were so collapsed they wouldnt return out
new nitrocharger sports to put in
Old May 21, 2014 | 01:24 PM
ManLen's Avatar
Got both leafs out and got a good look at the broken leaf
Old May 21, 2014 | 01:32 PM
ManLen's Avatar
So stoked with the results, ride is smoother, truck feels bigger, I can see clearer out the front now that i'm not looking over a raised hood
Excited to get out in the bush and see how they compare to the old
a couple before and after pics:
Old Jun 2, 2014 | 10:44 AM
ManLen's Avatar
Blew my clutch slave cylinder this weekend mid way through a parallel park, had to finish it off Flintstone style haha. Had to leave it downtown over night. Tried to limp it home by stopping every once and a while to fill up my reservoir but it was so far gone I couldn't even get it in gear once. Got a tow home and hit up Lordco for the part. Got a BeckArnley slave and swapped it in that day.
Pretty straight forward, only problem I came across was the flare fitting to the slave wouldn't spin on the line. A quick soak in some Moovit and it was good to go.
Old Jun 2, 2014 | 10:50 AM
ManLen's Avatar
Buddy and I went for a kayak down Finlayson Arm over the weekend, lightly rain the whole day but the water was so calm it was worth it
Love the look of the kayaks on the roof
Also tried some light flexing with the new OME suspension
Old Jun 2, 2014 | 10:57 AM
chukarhunt's Avatar
Way to go on the upgrades. Good looking truck!
Old Jun 2, 2014 | 11:03 AM
ManLen's Avatar
Thanks! Got a few more upgrades ready to go, just need to find the time haha
Old Jun 3, 2014 | 01:22 AM
Terrys87's Avatar
Great looking little truck you got. I got one with a little sag to it and will probably go the route that you did.
Old Jun 3, 2014 | 06:59 AM
rattlewagon's Avatar
New springs look good. Picked the back up a lot!
Old Jun 3, 2014 | 07:00 AM
ManLen's Avatar
@Terrys87 if you need any help with parts let me know! Most parts were petty easy to find, but a couple weren't listed, and work very well in my opinion
Old Jun 5, 2014 | 09:05 AM
samx227's Avatar
clean 87, lift definitely looks good!
coreyedwards7611
Jan 16, 2016 06:38 PM
ctheiss
9
Sep 15, 2015 01:44 PM
128keaton
Sep 14, 2015 12:16 AM
Peevedkitten
11
Aug 31, 2015 06:57 PM
shisha1999
Aug 14, 2015 01:33 AM
