SqWADoosh's 1985 Runner Build
Old Nov 21, 2014 | 01:10 AM
  #301
BigBluePile's Avatar
I was thinking about one of these guys: http://www.uniden.com/cb-radios/bear...vt/bearcat680g
Old Nov 21, 2014 | 09:15 AM
  #302
SqWADoosh's Avatar
Where would it fit at?
Old Nov 21, 2014 | 10:34 PM
  #303
Should fit possibly under the radio where my midland is now.....maybe lol
Old Jan 5, 2015 | 06:26 AM
  #304
SqWADoosh's Avatar
Didn't quite get all that I wanted to get done over the holiday.
14. Add CB radio and antenna (
Cobra 18WXSTII Cobra 18WXSTII
FireStik II 3 FT antenna FireStik II 3 FT antenna
20. Strip sliders current paint and replace with POR-15 and POR-15 top coat(
POR-15 POR-15
POR-15 Top Coat POR-15 Top Coat
The sliders took forever to strip by hand. I will be employing a family friend's sand blaster when I do my front and rear bumper.
Old Jan 5, 2015 | 06:36 AM
  #305
liveoffroad's Avatar
lookin' good. sliders turned out great, i need to start using that paint cuz my bumper is a mess. any pics of the cb installed?
Old Jan 5, 2015 | 06:52 AM
  #306
rustED's Avatar
X2, nice work on the sliders and CB install! Looking good!
Old Jan 5, 2015 | 07:42 AM
  #307
SqWADoosh's Avatar
That is actually not a true representation of the final product. That is just the POR-15 only. I also put on a top coat that is a flatter black. I will take some pictures of the CB installed today.
In other news I picked up a Marlin high steer kit from a local dealer that had it on his shelf for months. I also placed a huge order with All-Pro over the holiday. In the next month or so I will have a complete over haul of suspension and steering.
Old Jan 5, 2015 | 07:51 AM
  #308
rustED's Avatar
That's awesome! Your 4runner has undergone a complete transformation since you first bought! You're going to love having high steer! What size AllPro lift did you go with? I've been really happy with my AllPro rear lift.
Old Jan 5, 2015 | 11:02 AM
  #309
SqWADoosh's Avatar
In an attempt to keep the frame as low as possible I went with 4" up front utilizing their new low profile hanger and 4" shackles this will actually sit like a 3" front spring. I then went with 4" in the rear.
Old Jan 5, 2015 | 01:56 PM
  #310
SqWADoosh's Avatar
Added a picture of the radio installed to the above post. It did require some filing however not very much. I just filed until it fit tight. Its not being held by anything other than the tight fit into the slot.
Old Jan 5, 2015 | 02:31 PM
  #311
Old Jan 6, 2015 | 07:35 AM
  #312
looks good man!
unrelated, how are you liking your 3rz now after running it a while? enough power? hows the mpg?
also, do you have a part # for the rear window weatherstripping?
Old Jan 6, 2015 | 07:45 AM
  #313
SqWADoosh's Avatar
looks good man!
I love my 3RZ except for a small gremlin I have to sort out (hot soak issues that go away after driving a short distance). It is definitely thirsty in the city driving (16-18 mpg) but will go into the 20s when doing highway driving. The motor really shines when wheeling. I put her in 4 Low and just crawl through the trails with very little throttle needed. I usually just leave my foot resting on the pedal. The 3RZ really moves my truck when I need it to. Great acceleration for being a 4 banger and for how heavy my truck is getting with all the steel I have put on her. My Thorley header surely helps in that department of course.
Of course I've got your part number brother. I've got one better I've got the link to the place I got it and all. Which is 1/4 of the price the dealer would charge you.
http://www.toyotapartszone.com/oem/t...160-89111.html
Old Jan 6, 2015 | 08:24 AM
  #314
rustED's Avatar
Nice work on the CB install, it looks clean sitting under the stereo, like it was meant to go there from the factory!
Old Jan 6, 2015 | 08:29 AM
  #315
SqWADoosh's Avatar
Thanks man. I need to find a clearing to put a better tune on the antenna. I tuned it in the driveway of my father in law's place and it was surrounded by trees.
Old Feb 3, 2015 | 05:52 AM
  #316
SqWADoosh's Avatar
15. Upgrade tires (Goodyear MT/R Kevlar 35x12.5x15)
Got myself an absolute steal on some new rubber this weekend. Truck is sitting on 35s now fellas.
16. Add 1.5" wheel spacers (G2 Wheel Spacers)
Before:
After:
No more rubbing for me!
Old Feb 3, 2015 | 09:14 AM
  #317
Thanks for the part number, i just ordered one! Good to hear that you like the 3rz, seems like a nice little motor.
Tires look great! you'll love having 35's!
Old Feb 4, 2015 | 10:01 AM
  #318
rustED's Avatar
Nice score on the 35's, I like the new stance!
Old Feb 23, 2015 | 06:09 AM
  #319
SqWADoosh's Avatar
Well I was quite productive this weekend. Got quite a few things checked off my list that I have been procrastinating about.
17. Replace tired stock 22re radiator (All Aluminum Nippon)
Got the shroud and old radiator out.
I have to say the 3RZ has this amazing drain nipple for the block which made draining a breeze!
The new radiator had a bent mounting bracket that I had to take the vice grips to. Got it bent as straight as I could and the radiator mounted right up.
18.Replace stock 3RZ thermostat with 180* (LCE sells it and its accompanying o-ring)
While I was in there I decided to upgrade the thermostat to the 180* one.
Results after the new rad and thermostat. Block was at 198* before.
21.Belts are squealing on acceleration (replace with Toyota bando belts sourced from dealer)
Did the belts since I had the rad out and they had been lightly squealing on acceleration.
22. Replace spark plugs and wires (
NGK wires NGK wires
Plugs Plugs
Did the plugs and wires I've had lying around since Christmas as well.
Before:
After:
That took up my Saturday. Sunday I had a range day.
My 229 hanging out with my father in law's M&Ps.
100 yds with red dot sight on my AR. Need some work.
Old Feb 23, 2015 | 06:24 PM
  #320
