Gizler00's 85 4Runner Build Thread
Old Dec 4, 2015 | 10:33 AM
  #941
Gizler00's Avatar
I went for it and started drilling!! I had to bust out the Plasma Cutter to get the Inner hole hollowed out.
Old Dec 4, 2015 | 11:27 AM
  #942
Gizler00's Avatar
Got the Frame Tubes welded on to the Outer Plate and fit in the Frame.
I now need to bolt everything up and get it down on the ground to roll it closer to the welder so I can weld the entire Brace up.
Old Dec 4, 2015 | 01:20 PM
  #943
Gizler00's Avatar
Old Dec 4, 2015 | 08:18 PM
  #944
Gizler00's Avatar
I ended up going back to the shop tonight to try and get some stuff done.
I tightened up all the tie rod ends, hooked all the PS lines back up, topped off the fluid. And cut down and tightened the U bolts.
All I have left is to bleed the brakes, and weld the IFS brace to the frame and I can drive it!!!!!!
I can't wait.
Old Dec 4, 2015 | 11:24 PM
  #945
Terrys87's Avatar
Here is wishing you the best of luck of getting it on the road again soon.
Old Dec 5, 2015 | 07:51 AM
  #946
Gizler00's Avatar
Thanks Terry!! I tried to get some more work done this morning.
Old Dec 5, 2015 | 07:59 AM
  #947
Gizler00's Avatar
So I woke up, got some breakfast with the Family, and decided to head to the school to try and finish up bleeding the brakes and weld the IFS brace so I can get this thing on the Road.
I get there and started in on trying to get the Brakes sorted out. Come to find out after I started bleeding the brakes that threads on the new (reman) caliper for the drivers side were all boogered up and stripped out the brake line threads, then started to leak...........
I was irritated trying to get this all sorted out. I had plans to bleed the brakes then Weld the Brace. Well I had to end up spending the next 5 minutes of the Hour that I had fixing the caliper and making a new line.
The only good out come is that I ended up fixing and sorting the brakes all out and getting the system bled.
List of things to still do.
Bolt front shocks in.(might need longer ones now since there is more droop)
Weld the IFS Brace to the Frame
Set front TOE
Check Caster angle at the Pinion
Bolt the front DS in
Fill the Front diff with Fluid
Old Dec 5, 2015 | 08:04 AM
  #948
Gizler00's Avatar
One thing that I noticed about the Brace kit was that my frame has a slight curve to it right as it comes into the core support.
I found a thread describing the same problem with an older (81-83) frame that someone was installing High-steer on. Of course now I cannot find that thread, but the guy ended up shimming the gap with steel.
I think that I am going to just fill the gap with Weld. I have a pretty high power 220v Millermatic welder at the shop.
My question is that I was under the impression that the 85 frame did not have this curve to it. Maybe my frame is actually an older old 84 and back??
Who knows.
All I know is that when I fired up the truck last night the PS was like BUTTER. Now I know that there was no weight/pressure on the front end because the Tires were off and it was in the air.
Very excited!!
Old Dec 6, 2015 | 04:55 PM
  #949
Gizler00's Avatar
Went back to the Shop today to try and get everything all wrapped up.
I burned the Brace in as Hot as I could get the Welder.
Getting ready to pull it out for the Maiden Voyage!
So far so good for the First Shakedown run! Big Thumbs up From my buddy Nick! We are going to SAS his Truck next and Greg Eccles Jr's also.
Got the Box Primed and Painted to protect against the Winter months.
Took it out for a cruise tonight on some Country Roads.
So My Initial Impressions are the High Steer makes for a Completely Different Driving experience!! I mean so much so that I was a little shaky and not used to the was it drove. It was very weird.
I am not used to How responsive the Steering. I think I am going to Retro-fit a steering Stabilizer onto the tie-rod.
It also has a waaaay smoother ride and More Body roll than before. The old NWOR springs were so stiff that it was a kidney shaker that has ZERO give.
I drove it home tonight and will be taking it back to the school tomorrow to get it up on the Lift to check every thing out.
Im really glad I also replaced the Wheel bearings in it while I was in there.
I will report back with more info tomorrow.
Old Dec 6, 2015 | 05:29 PM
  #950
crashburnoveride's Avatar
Awesome man. Can't wait to see it in person. Looks like you need 35's now!
Old Dec 6, 2015 | 05:48 PM
  #951
Gizler00's Avatar
Thanks pat!
I really wish I could afford them!!! Maybe I'll try to sell these for a set
Old Dec 6, 2015 | 07:25 PM
  #952
Terrys87's Avatar
I just noticed that you do not have the steering stablizer on since you mentioned it. I did not care for my set up at first but the more you drive it and things start settling and breaking in seems to help. Great job and I like the stance of it.
Old Dec 6, 2015 | 11:46 PM
  #953
Gizler00's Avatar
Thanks Terry!
I think I am going to make a bracket to attach one to the steering.
Old Dec 7, 2015 | 12:31 AM
  #954
rustED's Avatar
Nice work Mark, looks great! Let us know how the steering stabilizer works out, I never ran one on mine, but thought about trying one.
Old Dec 7, 2015 | 06:10 AM
  #955
kioti's Avatar
Nice Build really clean 4 runner. I got the link from your fellow Auto Tech Instructor over here in Manchester. He's been telling me about it for a while.
Old Dec 7, 2015 | 09:07 AM
  #956
Gizler00's Avatar
Thanks Ed! It currently drives fine without one, but I figured it would help prevent Death wobble if it ever happens.
Hey!! Yeah I sent the Link to Jason Last night. I also sent him another one that I had my students build.
Glad you are on the Forum!
You need to make a build Thread.
Old Dec 7, 2015 | 09:29 AM
  #957
kioti's Avatar
Yea I was thinking that after reading yours.
I'll have to dig up some pics and get something on here soon.
Old Dec 7, 2015 | 10:16 AM
  #958
rustED's Avatar
Yeah mine drove fine without one as well, I never did experience death wobble, I was just curious if it would help the steering return to center after hitting bumps and dips in the road. I notice that all the ifs eliminator kits come with the steering stabilizer, but since I peiced my kit together I never did get around to installing one, lol. How do you plan mounting yours? I've seen some people add a mount to the front axel, seems like most put the mount on the frame, I'm not sure if there are any added benifits of doing it one way over the other.
Old Dec 7, 2015 | 10:58 AM
  #959
Gizler00's Avatar
Definitely! I want to see it!
I was thinking about making a bracket that mounts or welds to the Drivers side U-bolt plate, then sends the Stabilizer to the Tie-rod.
Not sure when I am going to do that though. Still trying to get the CNC Plasma cutter going.
Old Dec 7, 2015 | 11:06 AM
  #960
Gizler00's Avatar
So Yesterday I setup the Alignment close enough to get me on the Road and driving.
Today My Buddy, he comes to help out at the school on Mondays, helped me setup a home brew alignment station. He has been a steering and suspension guy for the better part of 20 years.
He has some slip Plates with bearings in it.
We set some tape up and Used a Home Brew Scriber to make a perfectly straight line to take measurements from.
I ended up getting it really close on my own. I was pretty happy with that.
But we ended up getting Toe set perfectly and it drives even better than it did this morning.
I also have a really cool Snap-on tool that was used for alignments waaaay before they had electronics and machines.
Now I need to start saving for 35's!! I am planning on selling these 33's when I have enough saved to pay for the difference.
