775Toy's 84 X-cab build Thread
Old Mar 14, 2014 | 11:10 AM
  #221
775Toy's Avatar
Originally Posted by Gizler00
Just finished reading through your thread. Love the build. Came a very long way from the first few pics of it in the field.
Im also curious on the ford shock towers. They look awfully close in resemblance to the stock towers on the 84-84 trucks. What year ford are they from?
Well when I was looking into mounting longer shocks on the Yota I came across a lot of guys using these ford towers on jeeps / Chevys / yotas and even buggies . There cheap , simple and if they work for stock f250 & f350s I figure they would be fine for a Yota. I didn't want to run my rear shocks like /\ in the rear like most and not be able to use my shocks to absorb at there full potential. I could have went the route most people go in the front and run shock hoops , but at 80-100$ for a set of hoops I choose to go with wrecking yard f250 towers. All 4 for 40$.
Couldn't tell ya exactly what years but I think 80s - 2000s f250/350 used these towers simply bolted on to the frame. There are a few differant styles through the years but all pretty much the same. My local ford dealer sells them new for 18$ ea and seen them as cheap as 10$ ea online. Google search pulls up a lot of threads covering questions and part numbers. They are famous for ripping off the frame if not welded on good and braced. I've seen hoops do the same if directly welded to frame. Many run them with no problems , I hope I'm one of them.
Old Mar 14, 2014 | 06:19 PM
  #222
775Toy's Avatar
Got some birthday sliders ! Should have the gusset set Monday.
Noticed that my English pointer was on point on some quail in the yard after I posted the pic on a local 4x4 site. Those quail drive her nuts !
Old Mar 14, 2014 | 10:59 PM
  #223
dsal_86Yota's Avatar
Nice sliders, my lab does the same things with geese and ducks, he hears them and stares, Ill mess with him and use my duck call just to get a reaction, its funny, my wife says its mean lol. My healer is older and he just looks at the lab and thinks stupid kid, then the healer try to herd my cats, Hes gotten a few cuts to the nose caue of it lol. Its funny how dogs can make you laugh even after the worst days. They are great entertainment.
Old Mar 21, 2014 | 08:32 PM
  #224
775Toy's Avatar
A little square driveline tech.
* disclaimer - this is nothing new , many threads on differant ways to make these. All drivetrain setups are not the same , many differances between year & model yokes /joints & flanges . Materials and measurements will vary. A Tape measure goes along way . This is just how I did it , for my vehicle and requirements. This is only recommended for off road use as they will make some noise due to slop between the 2 peices of tube and cause vibrations at higher speeds. These can not be balanced ! The better you line up the yoke ends the less vibration you will get. There are many threads going over tricks and pointers on how to combat noise & vibrations as well as explaining if you should use a double u-joint ( cv ) or single on tcase side . Grease is not needed , but will help with noise some. Build at your own risk.
-Materials-
2ft of seamless 2.5" square tube 1/4" thick
2ft of 2" square tube 1/4" thick
1 - rear drive flange off a donor tcase to swap out the stock cv style joint flange for the front driveline since I will be running a single u-joint on each end due to my front pinion angle.
Stock pinion side u-joint & yoke
1 - single u-joint & yoke off donor ifs front driveline
-Tools
Die grinder / cutoff wheels / sanding discs / welder / tape measure / chop saw / file.
First I cut off most of the yoke , left about a 1/2 or so stub
Then take about a 1/2" slice off the 2" square tube to use as a template.
Center the slice of 2" over the yoke I just cut and trace out the inside with a sharpie.
Using a cutoff wheel cut sides off you just traced .
Now that it's square it will slip Inside the 2" tube . It should have a little wiggle to allow you to center it up before tacking it I place . When your happy with its alignment burn it in.
Now for the 2.5" side. I basically cut the yoke off same as before , traced with slice of 2" again , and cut along the trace marks using cut off wheel . But this time once the yoke end was cut into a square I slipped the 1/2" slice of 2" tube over the stub and welded it together on the topside. That way it is a 2" stub that will fit nicely inside the 2.5" tube.
Notice how it fits snugly inside. You still have enough wiggle to center it up.
Now I let it slip in and sit flush against yoke & tube
Centered it up and burned it in.
My transfer case flange to pinion flange was just shy of 30" . I wanted Atleast 5" of compression and Atleast 10" of slip. So I cut the 2" & 2.5" to proper length to get those #s
Fully Compressed . Notice it's not compressed all the way to the welds , well this is the side I welded the 2" slice to the yoke end to fit inside the 2.5" tube. Right around 25" compressed .
Fully extended with about 1/2" still inside holding them together. About 41"
So I got around 5.5" compression and 11" slip.
Installed on the hoist -
On the ground -
I got about 50$ in this driveline. Should take abuse for years to come. I will eventually drill and tap a hole along each side of the 2.5" tube to allow me to thread a grease zerk in now and then and grease it up ( taking the zerk out after grease is inserted ) . Will do a drive test next week with hubs locked in 2wd & 4wd to see what speed I get vibes at. Some people claim 20mph some say 60mph no problem , some get lucky and don't notice a differance beside the slight clicking noise from the tubes ?
Old Mar 24, 2014 | 07:05 AM
  #225
Gizler00's Avatar
Great write up!! I love how easy you made it look. I would like to do this mod someday.
Old Mar 24, 2014 | 03:01 PM
  #226
775Toy's Avatar
Thanks. It's a great cheap alternative to a 300$ + long slip drive line , and much stronger.
Only took about 1.5hr or so. Pretty simple tuff.
Old Mar 25, 2014 | 06:24 AM
  #227
rustED's Avatar
Nice work on the driveline, it turned out great, can't beat $50! Looks let you are getting close to taking this out for a test run, what do you have left?
Old Mar 25, 2014 | 06:45 AM
  #228
Gizler00's Avatar
Definitely worth it especially at 50$ I really need to give this a shot.
Old Mar 25, 2014 | 07:17 PM
  #229
775Toy's Avatar
Thanks. Yes I'm gettin close to getting it in the hills for a shakedown. Nothing cool is gonna happen anytime soon besides finishing sliders . Mainly just some maintainance type stuff . Rear brakes / possibly weld up the rear / cut the rear overloads down / all new belts / new thermostat / powersteering resivor hose has seen better days and needs replaced / put all the lug nuts on haha.
Then I guess ill see how it does and what things need to be addressed and make a new todo & needs list.
Still got to install my cb stuff / CD player & speakers / rear wood panels / tool box for the bed / rubber bed mat . This stuff can wait tho.
I have a feeling after a shakedown if everything goes well ill have the itch to do some performance drivetrain upgrades. Gears / dual cases or single case 4.7s in the near future ?
Old Mar 26, 2014 | 06:22 PM
  #230
775Toy's Avatar
O man , sliders can be very time consuming. Getting them all lined up , desired angle just right , distance just right and cutting the legs correctly was no fun. Not to mention the prep on frame and frame plates. I was a dummy and forgot to weld the gussets onto the plates & legs till after sliders were already welded to the frame lol. Not as easy on the truck to weld those gussets in , I'll remember for the other side for sure. 67" 1035 dom sliders aren't light either.
All mocked up
Let's cut and welded on
Frame prepped & frame plates 90% welded in. I suck at weldong upside down , so I'm gonna wait till I have the truck up on a rack to weld bottom side.
Got them about a 1/8" from the pinch weld , decided I'd knotch out the pinch weld for extra clearance if they decide to come up some under weight.
They are out just about flush with fender flares , 26-27* angle . I stared with a 1/2" gap from slider to bottom of door. Well after welding they came up some . More like 3/8" gap now. Hopefully the gussets will do there job and not let the slider come up much more after smashing on them ?
Door gap
One side done. Hopefully the driverside will go faster .
Old Mar 26, 2014 | 07:27 PM
  #231
Yota's Avatar
driveshaft is awesome, ill need to do that too since i'm moving my rear axle closer to the front since i chopped the end of the frame a little shy.
and the sliders. ... .... ... F"""N SICK! really nice work man. im stoked.
edit- birthday sliders... when was ur bday. happy bday.
Old Mar 26, 2014 | 08:02 PM
  #232
775Toy's Avatar
Thanks man , appreciate the kind words. I wouldn't recommend square drive line for the rear if driven much on the street , seeing you can't get them balanced . Trail rig for sure tho.
Old Mar 27, 2014 | 08:52 PM
  #233
775Toy's Avatar
Driver side on
Old Mar 28, 2014 | 05:54 AM
  #234
Gizler00's Avatar
The Sliders look great!!! You did a great job on them!
Old Mar 28, 2014 | 06:42 AM
  #235
Yota's Avatar
good point.
guess ill keep thinking. and i gotta say it again the sliders look bad ass.
Old Mar 31, 2014 | 05:52 PM
  #236
775Toy's Avatar
Fairly productive lunch break today. Made a shock tower brace out of some scrap 1" x .95 thick square tube , with 1/8" tabs welded on the ends & drilled out to 1/2" for the shock bolts to run through. Should offer some support to the rear ford towers & also keep my spare tire from sliding around.
Just gotta get a coat of paint on it.
Old Mar 31, 2014 | 09:14 PM
  #237
rustED's Avatar
Nice job on the sliders, turned out great! I like the shock tower brace too, good idea! I thought about doing that on my front shock hoops and tying them together through the engine compartment, still kicking the idea around in my head, lol.
Old Apr 1, 2014 | 05:11 AM
  #238
Boomtacoma01's Avatar
Looks like some good progress.
Old Apr 1, 2014 | 07:19 PM
  #239
775Toy's Avatar
^ Thanks rusted & boom
Few small tasks done today . Welded a large crack inside my bed behind the wheel well that would squeak like crazy at idle. Adjusted my tailgate to get the latch to work.
Picked up a few parts -
Replaced my old crusty belts & thermostat. Also adjusted my steering stops , they were way out of adjustment since I added wheel spacers. Painted my rear shock tower brace , but would like to get longer bolts before I install it for good. Going to tear the rear brakes apart tomorrow so I can get the drums re-surfaced before new shoes go in.
Old Apr 3, 2014 | 06:36 PM
  #240
775Toy's Avatar
Got some 3" shock bolts to mount the freshly painted shock tower brace.
Had a buddy bring his toe in alignment bar over to help with the alignment.
Mark the tires with spray paint . Jack up the tires and spin to apply paint.
Use a fancy tool to scribe a mark in the paint while tire is spinning.
Set the toe in bar to the lines and make adjustments as needed. We got it aligned to 1/8" tow in.
