83Toyota88's 1983 Pickup Build-Up Thread
Old Nov 24, 2012 | 09:54 AM
  #221
westjohns yota's Avatar
truck looks good, when i get there in jan we def have to meet up!
Old Nov 24, 2012 | 09:55 AM
  #222
83Toyota88's Avatar
Sounds good.
Old Nov 24, 2012 | 01:47 PM
  #223
83Toyota88's Avatar
To everyone that does the Facebook thing follow this link and "Like" the picture of my truck so I can win this contest! Please and Thank You!
http://www.facebook.com/photo.php?fb...r&notif_t=like
Old Nov 24, 2012 | 02:53 PM
  #224
83Toyota88's Avatar
Ordered Me a voltage reader to do the mod on last page of this thread:
https://www.yotatech.com/forums/f123...1/index35.html
Here is the part:
Amazon Amazon
Also found this one:
Amazon Amazon
This will help me keep track of my system since my charge light isn't functional due to the GM alt install. FTW!
Old Nov 24, 2012 | 11:51 PM
  #225
ChefYota4x4's Avatar
Hey Bud... NICE PIC! Truck looks good, man!
Old Dec 3, 2012 | 07:05 AM
  #226
83Toyota88's Avatar
Thanks. I have a bearing that that either went out or is about to because it is noisy as anything under my hood. I assume it is the idler pulley/tensioner bearing but will look into it more soon. Anyone know where to get just the bearing?
Old Dec 4, 2012 | 11:58 AM
  #227
83pingpong's Avatar
New lights:
The round off road lights make me want to do a headlight conversion to the 79' round lights.[/quote]
Those look like the SAME lights that came on the front bumper of my truck. Mine are not wired yet. Other priorities
One of the bezels is bent on mine, but it doesn't seem to matter. Also, one bulb is missing. I need to wire them up.
Nice build thread. I need to start one.
Old Dec 4, 2012 | 12:12 PM
  #228
duckmaster88's Avatar
Nice build thread. I need to start one.[/quote]
I agree I like watching these 1st gen builds cant wait to get started on mine
Old Dec 4, 2012 | 01:57 PM
  #229
Terrys87's Avatar
This help? The video I found after I did mine.
Youtube video...
My Power Steering Pulley is a little noisey so thought I would show how to replace the bearing. I used PN# 204-FF.
Then I removed the nut and the pulley. On the backside there is a wire clip that holds the bearing to the pulley. Remove it,
then I used a 3/4 inch socket and drove it out over a vice.
I put a little oil in side the pulley and used the vice and slowly worked it back in most of the way. Once it is flush with
the pulley I used another socket to finish getting it all the way in so as the wire clip would seat.
Here it is all cleaned and painted. The bearing was $22. Toyota wants to sell the whole assembly. I was unable to
find just the pulley. Hope this helps someone.
Old Dec 4, 2012 | 06:39 PM
  #230
83Toyota88's Avatar
^^^ Thanks a lot Terry! I looked up that part number and found it on RockAuto.com as like a wholesale closeout item on sale for $11 shipped. Local O'Rielly has it for $25 but I'm in no rush do it. To much to do at work right now and with the holidays there isn't much Yota time lol so Im content with ordering it and saving $15. Preciate the write up I will def use it when the time comes
Old Dec 12, 2012 | 07:17 PM
  #231
83Toyota88's Avatar
Well got some problems with the truck. Its making this awful sound of a bearing going out still and its gotten worse. I started the truck tonight and was gonna drive to the store and I decided to try out my voltage reader that plugs in the cigarette outlet. I plugged in and the voltage was going all over the place. I saw it get as low as 11V and up to 13.5V and also noticed to headlights dimmed once like the alt dropped out or something. Im starting to think the alt is going bad or already has and thats where all this noise is coming from. I know Sarajevo had this same problem also. The pulley on the alt is maybe like a 1/8" off alignment from the other and I think it jacked up the alt pulling on it like that. But also the alt kinda shakes where its stands off so much so my bracket is a POS lol.
But I had anticpated this and told santa I wanted a Trail Gear GM to Toyota alt bracket for x-mas and he was kind enough to give it to me early lol . Probably go ahead and exchange my alt for a new one and get it installed. Gonna have to order me some cable to run from the battery to the alt since Im putting back in its stock location. Makes me feel better that it will be done properly and not rigged. But building that bracket I made was fun and a good learning experience I think.
New Trail gear bracket:
Old Dec 12, 2012 | 07:25 PM
  #232
Rollz79's Avatar
GM 1 wire is almost the best mod you can do to a 1st gen. I did it a while back. I made my own lower bracket and modded the top bracket. i went threw 2 alt and 1 voltage reg before i did the swap. Never looking back.
Old Dec 12, 2012 | 07:34 PM
  #233
83Toyota88's Avatar
I have a cs-144 GM alt installed right now that I built a bracket for and mounted on the passenger side of the engine. I'm moving it to stock location with a TG bracket.
Old Dec 15, 2012 | 10:29 AM
  #234
2 more dasy and ill be home to work on my truck ill be patching the floors and installing shocks and u_-joints the firstday ! im hopping to get old yella on the road in two days !
Old Dec 15, 2012 | 05:33 PM
  #235
83Toyota88's Avatar
Well I had some motivation to work on my truck today. Pulled the idler pulley off and took out the old bearing. It was really noisey. Then went to local shop and paid them $10 to press in the new bearing for me. I didnt wanna risk messing it up. also removed the alt bracket I made and mounted the trail gear one and got the alt on it. Put the pulley off the stock alt on instead of the I ordered a while back. Spun the fan on it and it appears to just barely clipping the bracket so Im gonna put the fan from the stock alt on it since its slightly smaller in diameter. Gonna have to get a new belt. Looks like one maybe an inch longer will work. Ordered a longer batt cable too and it should be in this coming week.
Old Dec 19, 2012 | 06:36 PM
  #236
83Toyota88's Avatar
Worked on my truck some more. New wire for the alt came in today so installed at and re-wired the alt harness. All I need now is a new belt and to swap fans on the alt.
Old Dec 21, 2012 | 02:39 PM
  #237
83Toyota88's Avatar
Got the alternator finished. Old belt was 35" per autozone's measurement and I ended up using a 36 1/2" belt. Everything is working good. No more grinding sound with the new idler pulley bearing in.
Alt with belt:
Voltage indicator:
Old Dec 26, 2012 | 05:46 AM
  #238
83Toyota88's Avatar
Got some snow this weekend. Took a nice pic:
Old Jan 3, 2013 | 05:11 PM
  #239
83Toyota88's Avatar
Got me an original toyota bug shield for my truck.
Attached Thumbnails 83Toyota88's 1983 Pickup Build-Up Thread-2013-01-02183949.jpg
Old Jan 3, 2013 | 10:50 PM
  #240
Just checkin in, bubba.... GREAT NEWS on that all working out so far... and NICE FIND on the Yota-Deflector!
