Center cap removal
Old Apr 15, 2013 | 01:02 PM
NickRob96's Avatar
Center cap removal
I'm rotating my tires and I can't figure out how to get these covers that go around my hubs in the center of the wheel. It has a series of clips around the back and it's a bitch to get off. Anybody have any suggestions for getting these off?
Old Apr 15, 2013 | 08:19 PM
rokblok's Avatar
They'll only slide in from the back or front. Kinda looks like it would slide out the back, but I have center caps on mine that are shorter but have the same retaining clips, and they just pop in and out from the front...
Old Apr 16, 2013 | 03:50 AM
93Xtra-Cab's Avatar
They pull out from the front. You just need to use a small flat pry bar.
Old Jul 14, 2013 | 10:55 AM
Bmyers791's Avatar
Hey guys, since there's a forum on the topic I didn't want to start a new one to ask; But on my 1991 4Runner I was wanting to know if it's safe to go without the center caps? The guy I bought this from, put these gawdy, awful AR caps on it; that make removing the lugs next to impossible.
Thoughts?
Old Jul 14, 2013 | 11:25 AM
NickRob96's Avatar
Thoughts?
It's perfectly safe to go without them but they will help you out a little bit as far as anti-theft. Maybe not the rear caps but I know my front caps cover up the bolts to remove my Aisin hubs and you'd be surprised how far some people would go to get their hands on a set of those. Plus I think it makes them look a little cleaner and more complete but if money is tight just forget about it.
Old Jul 14, 2013 | 12:27 PM
93Xtra-Cab's Avatar
Thoughts?
You should be fine. When I bought my rims used, the guy only had two closed center caps. I ran without center caps in the front for almost a year with the drive flange exposed before I put on my manual locking hubs.
Old Jul 14, 2013 | 02:25 PM
Bmyers791's Avatar
I would be surprised, super limited knowledge over here. When I joined the forum last year I had just bought my 4runner and I'm finally getting the free time to work on it. That being said I will openly admit I'm not familiar with the Aisin hubs. I've been told I don't have locking hubs but I don't know the difference.
Anywho, I think the capless rims look much better; until I can find some that look good.
Old Aug 25, 2013 | 08:45 PM
Marks81toyota's Avatar
So I'm servicing my Aisin hubs. I'm having a hell of a time removing the center cap after its seized to the wheel face? Suggestions? So far I've used my torch, a little heat might help. No luck. I'm considering cutting and tearing the chrome piece off!? HELP!
Old Aug 25, 2013 | 08:46 PM
Here's a pic.
94whiterunner
9
Sep 22, 2015 07:28 PM
TJWilly
Jul 31, 2015 02:05 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
HookahRoo
Jul 20, 2015 07:06 PM
msane99
Jul 11, 2015 08:08 PM
