Domestic Swaps Chevrolet, Ford, ect
LS1 into 2nd gen 4Runner ayone?
Old Jul 30, 2008 | 07:30 PM
  #181
dupontrob2000's Avatar
I plan on starting my project this fall. I plan on using the 5.3 with a 4L80 trans, then adapting it to the toy transfer. I want to try and leave the front IFS intact. I do already have a 3" body lift in it right now. I'm thinking about using a set of 4.88 from a v6 that i have in the garage. Any comments are encouraged. I work at a salvage yard, so I have very good access to parts and on the cheap!
Old Jul 31, 2008 | 06:55 PM
  #182
jamesrhcp's Avatar
scrap the ifs
rob, sounds like a cool idea but i would scrap the ifs for a solid front axle. with that kinda power youre gonna break it anyway
Old Aug 1, 2008 | 01:32 PM
  #183
Adam F's Avatar
Biggest issue with the V8 and IFS Is the oil pan and differential clearance. You may have to modify the oil pan or raise the engine up really high. Thats why most people swap to SA with a V8 swap.
Old Aug 4, 2008 | 09:17 PM
  #184
Rocketwrencher's Avatar
I know i am joining late but has anyone heard of swapping a 5.7L chevy into a 95 4runner 2wd. I plan on doing a SAS at the same time. I have a doner gmc suburban that the wife wants to get rid of next year and if it will fit and work, it will be perfect for my sons $3000.00 95 3.0 yota that we just picked up. Any Ideas?
Old Oct 5, 2008 | 06:35 PM
  #185
CamTom12's Avatar
The LS2 TBSS's have a modified oil pan that might work if you want to keep the IFS...
This is a project I've been kicking around for my 1st Gen 4Runner, since I already have a ~450whp motor in my TA I'm going to pull out of it for a 6L block Procharger build I want to do in 2010
I've also thought about just finding a stock higher-mileage 5.3L to drop in there, too.
If I do it I'm going to modify a 6cyl 5-speed for the lower OD as posted elsewhere in here.
Hope that helps a bit!
--Cameron
Old Oct 5, 2008 | 08:31 PM
  #186
toyzukisamroid's Avatar
I have never seen anyone use 400+ HP rockcrawling before. I gotta see this. Make sure you videotape the event and post it here. before you do, wrap the transmission tunnel with kevlar.
Old Jul 1, 2009 | 07:52 AM
  #187
MaXXis85's Avatar
What did you use for the VSS operation or was it tuned out in the PCM? If it was tuned out how well does the engine run on deceleration?
Old Aug 3, 2009 | 04:55 PM
  #188
blazerboy72's Avatar
runs great. The only thing I changed in the pcm is the torque managment and the anti theft thing that I cant remember what its called right now.
Old Dec 15, 2009 | 09:06 PM
  #189
the 38 special's Avatar
Did you end up needing the full 3 inches of body lift?
Old Jan 31, 2010 | 12:09 PM
  #190
CamTom12's Avatar
--Cameron
well change of plans... After pulling some cars up hills durning TN's recent freak storm I think the 22re earned it's right to stay! I think with a cam change and maybe updated EFI it'll have the torque I'm looking for. And an exhaust change is a must, pretty sure my cat's clogged!
/derail
Old May 28, 2012 | 04:52 PM
  #191
Bumpin' Yota's Avatar
Originally Posted by Rusty Davis
Oh yeah, I forgot about the distributor being in the front....meaning it does "technically" have a funky flat distributor on the front(I owned a 94 Formula w/ an LT1) ...
actually it does not have any distributor.
Generation III chevy small blocks 4.8/5.3/5.7 did away completely with the distributor and instead use coil packs.
The LT1 and LT4 were the last of the generation II small blocks that used distributors. The LT1/4 both used the inferior optispark which was idiotically placed below the water pump so you can guess what happens when the water pump gaskets start to leak...
Old Jun 2, 2012 | 06:43 AM
  #192
Blazerboy - got some questions for ya!
How has the 700r4 tranny been treating ya? Also would it (the tranny) have fit without the body lift? I cant count the threads Im reading online stating that the 4L80e was far easier to fit than the 4L60e/700r4 courtesy of the bell housing not being as wide...
How close is the tranny to the transmission tunnel at the closest point?
Im planning on doing a 4.8L vortec with beefed up valve springs and arp rod bolts and a 01-03 LS6 cam, LS6 intake, so as to spin up to 7k rpm and reduce a little bit of tq on the bottom end of the rpm curve (should help driveline longevity.) Since I will be turbo'ing the 4.8 Im planning on going for about 450-550 hp at the rear wheels so I need a tranny that will hold that AND deal with a 4800lb suv that will occasionally hook at the track. I've read too many horror stories about the 700r4 puking its guts out in 3200lb Fbodies to think that it'll work for my goals, but I wanted your thoughts too.
Also what did you do about the A/C? Im sure that I can get the toyota wiring to engage the a/c clutch, but how does one go about attaching the toyota lines to the GM compressor?
Did you use the stock fuel lines? Did you keep the return system? Did you keep the OEM pump in the tank?
Any ideas on how much power will our OEM rear end hold without any drag strip launches?
Jun 1, 2021 01:51 PM
tpd143
Jul 7, 2015 09:06 AM
Steezy96yota
Jul 6, 2015 10:00 AM
HRDC0R19
Jul 5, 2015 06:43 PM
CJ94yota
Jul 3, 2015 10:14 PM
