Diesel Swaps Diesel engines
PowerstrokeJoe's om617 Turbo Diesel swap/build in 1990 P/up
Old May 9, 2012 | 04:25 PM
  #341
PowerstrokeJoe's Avatar
Originally Posted by 89lc
You'll need bigger tires or higher gears if you want to comfortably cruise above 60.
How does your truck do on the highway? I am running 31's currently and 65 is about it. I really don't think something is right.
Old May 9, 2012 | 06:31 PM
  #342
delmert's Avatar
Well I'm hoping to move up to 35s anyways....
An Joe.. heres a couple sights wit quite a bit of gear info...
http://www.brian894x4.com/Gearratiosanddiffs.html
http://www.4crawler.com/4x4/4R_TechI...l#Transmission
Old May 9, 2012 | 09:02 PM
  #343
Thanks Delmert!
Old May 10, 2012 | 03:37 PM
  #344
delmert's Avatar
Originally Posted by PowerstrokeJoe
Thanks Delmert!
No problem man.... an if I decide to go through wit the swap instead of rebuilding this motor I might have to come out an look at your set up... ha...
Old May 10, 2012 | 04:11 PM
  #345
You are more than welcome to take a look any time. I think it would be really cool to have a gtg of all the Missouri Yota's on here.
Old May 10, 2012 | 04:45 PM
  #346
89lc's Avatar
Mine is about the same. The gearing calcs say I should be around 3000 rpms doing 60, but it sounds like I'm spinning the engine a lot higher than that. Might help if I had a real tach to go off of, but I am done with the diesel. Going 1uz to a taco 5spd, maybe even 1uz-tt if my cousin has his way.
I have another 4runner with worn out 37" mtr's and 5.29's. I should look at what my rpms are on that thing since it's pretty damn close to my 35's and 5.38's.
edit: I just measured the diameter of the mtr's, they are the same as my bfg's on my diesel. So that should tell me how fast the engine is spinning. With the 31's, the RPM's were 34xx at 60 on the calc.
Old May 10, 2012 | 06:14 PM
  #347
delmert's Avatar
..... ya it would be... I know a few people on the ks side an thats it... But ya might have to give me a bit... other wise ill have to push her their\
Old May 13, 2012 | 10:34 AM
  #348
Sounds good to me! When you get her ready give me a holler.
Just a little update on the truck- I have put around 600 miles on it so far. its still way down on power, and I am suspecting my IP is bad. I am going to swap it out with my spare and see if it helps. Otherwise, I love it and the mileage is compared to the 3vze. The last tank was all city driving it hard and It got mid 20's.
Old May 13, 2012 | 03:52 PM
  #349
delmert's Avatar
Aite cool.... an ya man thats nice.... Ive noticed my truck gets an average of 13mpg.... or got. An its the 4banger....
Old May 13, 2012 | 06:34 PM
  #350
aviator's Avatar
dang Joe that mileage sounds sweet and the eng. not even dialed in yet...
Old May 14, 2012 | 08:54 PM
  #351
I was pretty impressed my self about the mileage. I have the ip back on but thats as far as I got. I had to work cattle at Dad's this morning and laid hay down here this afternoon. Hopefully I'll know more tomorrow.
Old May 15, 2012 | 09:37 AM
  #352
89lc's Avatar
Is it only gutless on the highway or is it in the upper rpms everywhere?
Old May 15, 2012 | 03:53 PM
  #353
Its pretty much totally gutless everywhere. Around town its not as noticeable, but on the highway it just didn't have it. If this new pump doesn't work I'm going to crank up the fuel and boost a bit. If nothing else I will increase the cooling capacity. The only reason I am even messing with it is because it warms up about 210 on the hills and the 300D I have the temp stays right at around 190ish. I am not wanting a ton of power out of it. I'm going to either do a 7mgte or 1uz swap in runner next. That will be the fun toy.
Old May 17, 2012 | 09:13 PM
  #354
Well the spare pump had a seized port so I just put my old pump back on and cranked a little fuel to it. I should have it back together tomorrow. I'll post results.
Old May 17, 2012 | 09:19 PM
  #355
Transplanter's Avatar
Try advancing the ip timing,really improves throttle response and spool up. If you go to far it will just get harder to start,louder and make less power,so no real harm playing with it.
Old May 17, 2012 | 09:26 PM
  #356
Your high coolant temp and sluggishness make me think the ip timing is retarded. Giving your torque management and tweak along with you crankin up the fuel will make a BIG diff also,just keep an eye on your egts.
Old May 20, 2012 | 10:47 AM
  #357
89lc's Avatar
Like what was said above, check the timing again. The engine should sound like a cummins with the IP advanced to 26-27º btdc. Also, you should make sure there are no restrictions on the fuel lines and check your boost pressure. These engines need boost and fuel to make them go anywhere.
Old May 20, 2012 | 03:12 PM
  #358
2003mikem's Avatar
Well? ????
Old May 21, 2012 | 08:51 AM
  #359
Sorry guys I had a pretty crazy weekend. I have the pump back in. I am waiting on my drip tube to come back in the mail. I drove it a bit and it seemed much better but the timing must still be retarded as my egts are only like 1000 on the highway and the coolant temp is a little warm. All the fuel filters are new and its making about 10lbs of boost. I intend to crank it up a little later.
Old May 21, 2012 | 07:54 PM
  #360
g.stickwan's Avatar
PowerstrokeJoe
I have a weird question.
how long is your rear drive line on the 1990 pick up? im going to be swapping my POS
A/T tranny out in mine for a 5 spd and was wondering if i need to get a different size drive line.
thanks
