1uzfe transmission options
#62
so same lines, deep pan, empty t/c, and giant tranny cooler from oreilys = 8.5? quarts so far
the worst part is im not sure which dip stick i am using as i had parts from 3 different trans laying around and only one was found im not sure if they are different lengths so i cant tell if i have enough or to much fluid
#64
i may have a little to much in there what would be the result of this?
also my solenoids or something clicks on an off randomly (not all the time) but rapidly when taking off and i can feel the truck change from 1st to o/d(?) when it happens.. any ideas
#65
mystery clicking solenoid problem solved!!
i am/was using a cable speedometer.
this was converting the signal to send to the computer.
when your speedometer cable is failing it doesnt produce a clean signal.
do to not having the #2(?) speed sensor hooked up the computer was confused and was turning on/off the solenoids.
after hooking up and using only the #2 speed sensor after my speedo quit my shifting is perfect.
I have converted to an electric cluster and will try out the shifting in the next couple days to see if you can operate without the #2 sensor as i really dont have it hooked up appropriately.
#67
crammit442
7
Nov 29, 2017 12:30 PM
Yota.Jay
28
Oct 22, 2015 01:08 PM
