1uz swap in the works.
#161
! okay very usefull tip for anyone who is doing this swap.. i have a v6 cluster with tach, and was under the impression that i needed a 4clnder tach.. well i was correct.. BUT
i also noticed a little adjustment knob on my v6 tach(under the tack on the circut board)
this adjusts the signal to the tach, after testing it, pulling it out re-adjusting and testing again i was able to get the tach within 250rpms of accuracy(going off assumed idle and rev limit) my idle may be spot on? i need to double check it with a timing light but the rev limit is just under 6500rpms, from the factory its 6750..(go v8!) for me this margin is well enough for me driving it around and whatever else i need it for, its not a drag car so why should it matter if the rpms are off a few hundred? what do you guys think?
#163
When I compared the dial adjuster between a 4cyl and a v6 tach cluster one of them was at about the 10 o'clock position and the other was at about the 2 o'clock position. I forgot now which was which.
#168
you can get the cad file to take to a machine shop for 25 bucks online, ebay or v-eight.com, you can buy the the plate but its around 3-400 bucks witch is kinda steep..
i would buy the drawings and have a machine shop cut it out for you and i bet you would be around 200. you WILL have to modify your 1uz bell to clear the bolts fore the plate, and make a mount for your clutch fork.
the is PMW out of NZ they have a plate, flywheel, and many other items, but from my experiance they have good customer service.
http://www.pmw.co.nz/ProductsList.as...3&selection=12
#173
she is kinda scared of it.. lol.. she was leavin class the other day, turning right into traffic.. said she totally did a burnout on accident.. i think she likes the security of the rig, she be even more happy when the snow falls
#175
too good actualy...
i was out there the other day just laying undernieth it thinkin hmm
what can i do now? no leaks, no breaks... could use a few new parts but other than that its been trouble free... i guess its time for sas? or a new project..
i was out there the other day just laying undernieth it thinkin hmmwhat can i do now? no leaks, no breaks... could use a few new parts but other than that its been trouble free... i guess its time for sas? or a new project..
#178
i don't know if the wife will like having even more power lol.. she has to be carefull to not run over the cars infront of her when she is stopped at light or in traffic.. thing just gets moving so quickly, its a monster out of the hole.
