All Other Toyota Swaps I4, I6, Lexus V8
1uz swap in the works.
Old Oct 11, 2010 | 06:13 PM
  #181
birdduck's Avatar
yeah just been drivin the crap outa it.. i need to put some vids up, i will get a 0-60 pull soon.
Old Oct 12, 2010 | 07:21 AM
  #182
4runnerguy's Avatar
how u like the power compared to the 3.0 lol?
How is the clutch taking all this power
Old Oct 12, 2010 | 01:15 PM
  #183
birdduck's Avatar
clutch is fine no signs of slipping or chatter.. power is nice, its just all around more torque and power that you can feel just moving from a stop. or cruisin on the freeway at 75..
Old Oct 12, 2010 | 06:34 PM
  #184
raddude666's Avatar
seems like you got it fixed lets see some finished pics... also any advice on starting this project because i just bought a ls400 with a 1uz been wanting to put it in my 86 4runner with a 4cyc and need desperate help
Old Oct 13, 2010 | 05:40 AM
  #185
toyminator2000's Avatar
If you're starting with a 4 cylinder you will need to come up with a v6 truck power steering lines. You will also need a v6 fuel filter, mount and fuel lines since the 4cylinder truck locates them in a spot that won't work with the 1uz. hmm. can't think of anything else right now.
Old Oct 13, 2010 | 06:49 AM
  #186
birdduck's Avatar
what is different about the 4cylinder fuel lines? you will need a v6 fuel pump i think? you running the 4 cylinder one(FP) toyminator? you realy only need the feed line, make sure you get one without abs, you can get some rubber hose from any auto parts store for the return i used some 400psi stuff designed for ps/trany cooler.
are you going 5spd or auto?
first step would be to pull the engine out of your ls, DO NOT!!!!!!! cut any wires, hoses or anything for that matter... take your time, and i found it pretty easy to pull the engine/trans as one.
prep the engine, clean it off and make it look pretty get some wiring diagrams for your car and runner (car year is?)
if you drive your runner alot then wait till you have all your parts before you dig into the runner..
start a build thread and ask these questions in there so you don't have to dig into other threads to find the answers to your questions
Old Oct 13, 2010 | 09:20 AM
  #187
The 4cyl has a power steerting fluid cooler line that routes out through the core support and it also has a remote resevoir. The high pressure line isn't routed correctly either. The v6 ones bolt right up.
I am currently using the 4 cyl fuel pump and it runs fine but I haven't done any full throttle launches yet to see if it starves for fuel. I plan on getting a Walbro at some pont.
Old Oct 13, 2010 | 01:13 PM
  #188
birdduck's Avatar
i ment the differences on the fuel lines. i know about the PS..
Old Oct 13, 2010 | 07:03 PM
  #189
Oh sorry. The 4cyl has its fuel filter right up by the engine under the intake plenum. Kind of close to the starter on the 22re. The v6 one is located on the frame rail right by where the crossmember bolts to the frame. I suppose the actual filter would work if you bought the proper mount to put it on the frame and the proper v6 fuel lines from the tank.
Old Oct 14, 2010 | 08:10 AM
  #190
RMA's Avatar
RMA
hey man why dont you just use one of your sc fuel pumps .... that way you can let us know what all it takes to mount one . im thinking the pump alone will swap right over , but am unsure.
Old Oct 14, 2010 | 06:49 PM
  #191
Well It would take some modification of the cradle to make it fit. Anyway, I sold the low mileage one I had. The other SC has 225k on it so I really don't want to do all the work to modify it to fit a pump with that many miles on it.
Old Oct 21, 2010 | 08:52 PM
  #192
4runnerguy's Avatar
so no vids yet i need motivation to complete mine
Old Oct 22, 2010 | 02:15 PM
  #193
birdduck's Avatar
sorry life has been busy...
Old Oct 28, 2010 | 06:00 PM
  #194
RMA's Avatar
RMA
Videos !! Videos !! haha.
Old Nov 2, 2010 | 04:06 PM
  #195
birdduck's Avatar
soon i promise !!
Old Nov 3, 2010 | 09:53 AM
  #196
Kuntryboy's Avatar
awesomeness! had to subscribe and did i hear the words SAS? haha
Old Dec 29, 2010 | 02:50 PM
  #197
4runnerguy's Avatar
so u got any vids yet
Old Dec 29, 2010 | 06:26 PM
  #198
birdduck's Avatar
no not yet, have been drivin the crap out of it though.. it gets driven every day
Old Dec 30, 2010 | 07:45 AM
  #199
SuperRunner's Avatar
SC pump goes in just fine. I had to switch over to an SC pump because I was running way too lean on the factory pump with the supercharger, and now it runs much better. I still need more fuel so I will probably stick in a walboro.
Old Jan 4, 2011 | 09:03 AM
  #200
birdduck's Avatar
so what do you guys think... i am considering selling my toy for a newer runner, what would be a good price to ask for the beast? i have a number in my head but i am wondering what people would be willing to pay?
