All Other Toyota Swaps I4, I6, Lexus V8
1uz swap in the works.
Old Aug 26, 2010 | 04:21 PM
  #121
4runnerguy's Avatar
Hey birdduck what harnesses did u use out of the ls400?
And what sensors did u pullout of the 3cz
Old Aug 26, 2010 | 06:54 PM
  #122
birdduck's Avatar
the one you will need is your oil pressure "sender", attached to the oil filter mount.
unless you have a non sr5 cluster, then you will be okay with the lexus oil pressure "switch"
you need the engine harness uncut..
i would recommend you get really familiar with your FSM and wiring diagrams, this will help you answer allot of your questions.. and believe me there will be allot.
Old Aug 28, 2010 | 05:42 PM
  #123
RMA's Avatar
RMA
Originally Posted by SuperRunner
Nice work.
Kind of interesting, I came across this swap looking in the LOCAL classified ads and came across a bellhousing and saw the list of parts and thought, oh cool, 1UZ swap.
Well, it just so happens that I just got my 1UZ swap 4runner road worth 2 days ago, the same day as birduck.
Anyway, nice swap there. Can't wait to head over and compare notes.
wheres your thread .. lets see some pics man .. what problems you run into and how did you fix them ..
Congrats..
Originally Posted by birdduck
well so far so good, fixed a couple issues that i had, one was the rear main seal, should have replaced it when i had the motor apart but now i know what i am looking at when i need to put a clutch in it, only took 2.5 hours so not bad.
second issue was the front yoke on the t-case was leaking around the seal, popped it of and found i must have popped the spring off the seal when i had it appart, cleaned seal surface on the yoke, returned the spring to its home and drilled the flange for my auto driveshaft wile i had it off.. no more leaky... sweet...
i feel pretty good about not having issues, i took my time and did stuff right.. lets see how things play out.
60 miles city driving on it so far.
good only minor issues .. enjoy man ..
Old Aug 29, 2010 | 11:10 AM
  #124
SuperRunner's Avatar
Sorry for the small hijack bird, but here is my thread on yotatech I just created.
https://www.yotatech.com/forums/f161.../#post51536858
Old Aug 29, 2010 | 12:40 PM
  #125
birdduck's Avatar
cool. np..
got my PS lines done today and decided to see if the high side would give me any issues.
whent up the street to a gravel pit not far from here and did some wheelin..
well i got one, i was trying to climb a rock with just the front left tire and ass soon as i hit that 12-1400 psi output of the pump it shot one of the high side clamps off... good thing i anticipated a problem and brought ps fluid and some tools ..
looked like i could have put more of a flair on the end, fix that after the the engine cools off..
do to the auto diff having 4.56's in them and the final drive and the trans my 31"
tires are a little short and the 4L in the tcase puts my crawl ratio pretty slow, like 3-4k rpm's in first puts me at maybe 3-5 mph... i can pretty much start in 5th.
some flex pics:
Old Aug 29, 2010 | 03:34 PM
  #126
birdduck's Avatar
got it all cleaned up, no more fender trim/ mud flaps/ or tape from the side moldings.
Old Aug 29, 2010 | 05:10 PM
  #127
toyminator2000's Avatar
Fix that rust and it will look really clean.
Old Aug 29, 2010 | 06:13 PM
  #128
birdduck's Avatar
i know the interior is in great shape too.
Old Aug 30, 2010 | 07:17 AM
  #129
birdduck's Avatar
how about some engine pron..
Old Aug 30, 2010 | 07:29 AM
  #130
Yota 3.0's Avatar
Lookin good man.. i love engine bay pron
Old Aug 30, 2010 | 09:56 AM
  #131
4runnerguy's Avatar
hey birdduck can u take more close up pics of the engine bay
Old Aug 30, 2010 | 11:19 AM
  #132
birdduck's Avatar
what would you like to see?
Old Aug 30, 2010 | 02:55 PM
  #133
85toyman's Avatar
birdduck- that is the nicest and cleanest engine bay I have seen after a swap like this. You did very nice work, I can't wait to start mine. Hope you don't mind questions. I know I will have alot of them. The first one is have you towed anything with it. I worry about overheating it. I have a 1994 4runner with the 3.0 and pull a 17' travel trailer right now. Want more power to pull hills better. It seems to only do about 30 mph now when ever there is anykind of a hill. Hopefully this v8 will change that.
Your skills are definetly showing with these this picture.
Old Aug 30, 2010 | 03:32 PM
  #134
4runnerguy's Avatar
the fuse box area and between the motor and firewall
Old Aug 30, 2010 | 04:00 PM
  #135
I guess the engine doesn't need the charcoal canister.
Old Aug 30, 2010 | 05:36 PM
  #136
RMA's Avatar
RMA
man what a difference not having all the smog stuff.looks super clean.
hey whats that hose under the throttle body .. looks like a fuel hose .
Old Aug 30, 2010 | 06:09 PM
  #137
SupraRunner's Avatar
I guess that's what it would have looked like if it had come from the factory with the v8. Congratulations on making it to the end.
Old Aug 30, 2010 | 06:21 PM
  #138
birdduck's Avatar
wow thanks guys.. it makes me feel like i want to give someone a hug...
yeah no charcoal can.
the line under the throttle body is a fuel line, its my inlet.
yeah it helps to clean up the engine a lot.
there is about 1/2 an inch between the heads and the firewall, get a pic for yah when its light outside.
Old Aug 30, 2010 | 06:24 PM
  #139
birdduck's Avatar
Originally Posted by 85toyman
birdduck- that is the nicest and cleanest engine bay I have seen after a swap like this. You did very nice work, I can't wait to start mine. Hope you don't mind questions. I know I will have alot of them. The first one is have you towed anything with it. I worry about overheating it. I have a 1994 4runner with the 3.0 and pull a 17' travel trailer right now. Want more power to pull hills better. It seems to only do about 30 miles per hour now when ever there is anykind of a hill. Hopefully this v8 will change that.
i haven't towed anything yet, i do have a small trailer i plan on hooking up..
i may run into cooling issues when towing will have to wait and see?
for now my final drive is really short, i need to get some taller tires to even it out and maybe use less gas..
are you keeping it 5spd with the swap?
Old Aug 30, 2010 | 06:29 PM
  #140
birdduck's Avatar
i got rid of a lot of stuff, some even include cruise(for now), i will slowly get it to smog legal, but that will take more money and time for now the basics and getting it on the road with zero problems, once i am there i will start considering things like AC and cruise and yeah not causing global warming...
