All Other Toyota Swaps I4, I6, Lexus V8
1uz swap in the works.
Old Aug 21, 2010 | 09:03 AM
  #101
4runnerguy's Avatar
the vid isn't working
Old Aug 22, 2010 | 07:20 PM
  #102
birdduck's Avatar
fixed them.. i don't have them hosted on youtube, so its just a link..
Old Aug 23, 2010 | 08:16 AM
  #103
4runnerguy's Avatar
now u got post a vid of the complete job
Old Aug 23, 2010 | 08:42 AM
  #104
birdduck's Avatar
i will do that, i have the wif's digi cam to take video instead of my pos phone. installing the radiator and the ps today so we'll see how it goes.
Old Aug 23, 2010 | 09:40 PM
  #105
birdduck's Avatar
got the okay from the wiff to buy a few things, rad fan, thermal switch, and crap to finish the intake.
Finally road worthy!!!
first i let it idle for about 25 minutes, making sure there isn't any leaks or weird stuff going on. after making sure the fan turned on at the right temp and it cooled the engine, i took er for its first road test... first stop gas station for some fresh gas. next stop Checker auto parts to show them what all these parts i have been buying went too.. on the way to checker is a small stretch of highway, got it up to 70mph with light throttle, rode smooth no vibrations or wobbles.
after checker went to my friends house to take him for a ride(he has an 03 taco with lots of stuff) he wanted a good first gear pull to see what this things got.. so first gear pull it is... yeah i think thats the fastest this thing has ever made it to 35mph..
so after about an hour of run time the first problem arose the rear main seal is leaking..
i had no signs of leakage when i had the flywheel of but the seal must have dried out from sitting for all those years. other than that nothing so far! i am expecting some issues
to pop up for the simple fact that that stuff happens when you do engine swaps but for now i ma just going to take er easy and make stuff look pretty wile i wait for funds to come back for new parts and cool goodies!
Old Aug 24, 2010 | 04:27 AM
  #106
Yota 3.0's Avatar
wow thats awesome and really good to hear. Im not sure if i missed it or not but how did you delete your IACV? or are you running a standalone?
Old Aug 24, 2010 | 04:51 AM
  #107
birdduck's Avatar
the iac is there and plugged in. i will be using it later once i get everything nice and organized.. for now its just got a plug on it.
and no standalone using the same pcm as everyone else.
Old Aug 24, 2010 | 05:43 AM
  #108
Yota 3.0's Avatar
Oh ok makes sense.
Old Aug 24, 2010 | 07:37 AM
  #109
birdduck's Avatar
you have first gear traction issues to yota? your on 35' right?
Old Aug 24, 2010 | 07:54 AM
  #110
RMA's Avatar
RMA
Congrats man ..
so your iacv is plugged and the engines idleing fine at start up, and when warm ?
im having problems with my .. she wont idle at start up and after shes warm she will idle ok , not great but ok ..
i tested the iacv and it test out ok. i also removed it took it apart and installed it in the open position, truck idles great. but then i turned her off and tried again , and back to crappy idle ..
so its closing but not opening back up when its supposed to .
Old Aug 24, 2010 | 08:11 AM
  #111
Yota 3.0's Avatar
when i had my MAF unplugged yes it would cook first and a little in 2nd (35's, 4:88 gears) but now no so much, im lucky if it will break lose in the rain. cant seem to get it to run without the MAF anymore lol FML i hate wiring
Old Aug 24, 2010 | 10:12 AM
  #112
4runnerguy's Avatar
what is this iacv cause i got all the parts and all be starting this swap soon
Old Aug 24, 2010 | 10:15 AM
  #113
Yota 3.0's Avatar
Idle Air Control Valve
Old Aug 24, 2010 | 01:09 PM
  #114
birdduck's Avatar
try this RMA, there is a little screw with a hex head on the front side of throttle linkage(same side as the tps sensor) this screw is for the dashpot(keeps throttle from slamming closed) tighten that screw till you reach your desired idle(when hot) this way if the iac sticks oror acts up your idle will stay the same, or you can just block it of/plug it(iac).
Old Aug 24, 2010 | 04:32 PM
  #115
4runnerguy's Avatar
Ok so out of the wires and plugs from Lexus ls400 do u need I know its everything that goes to the motor. What about the key ignition
Old Aug 25, 2010 | 05:43 AM
  #116
birdduck's Avatar
you need a diagram, look on RMA's thread he posted the one from lextreme, its realy simple.
i did mine the hard way.
Old Aug 25, 2010 | 09:01 AM
  #117
4runnerguy's Avatar
Ok thanks
Old Aug 25, 2010 | 01:04 PM
  #118
SuperRunner's Avatar
Nice work.
Kind of interesting, I came across this swap looking in the LOCAL classified ads and came across a bellhousing and saw the list of parts and thought, oh cool, 1UZ swap.
Well, it just so happens that I just got my 1UZ swap 4runner road worth 2 days ago, the same day as birduck.
Anyway, nice swap there. Can't wait to head over and compare notes.
Old Aug 26, 2010 | 11:45 AM
  #119
birdduck's Avatar
well so far so good, fixed a couple issues that i had, one was the rear main seal, should have replaced it when i had the motor apart but now i know what i am looking at when i need to put a clutch in it, only took 2.5 hours so not bad.
second issue was the front yoke on the t-case was leaking around the seal, popped it of and found i must have popped the spring off the seal when i had it appart, cleaned seal surface on the yoke, returned the spring to its home and drilled the flange for my auto driveshaft wile i had it off.. no more leaky... sweet...
i feel pretty good about not having issues, i took my time and did stuff right.. lets see how things play out.
60 miles city driving on it so far.
Old Aug 26, 2010 | 04:16 PM
  #120
4runnerguy's Avatar
Hey birdduck what harnesses did u use out of the ls400?
And what sensors did u pullout of the 3cz
