1UZ-FE into 1988 4runner 3.0 3vze
#341
well i guess i have a long weekend ahead of me now. thanks a lot guys!! ill be trying to figure this out this weekend.. also i need that large coolant sensor, im pretty sure it is for the cold start its right beside the engine temp sensor. if one of you guys has a spare let me know.. or a part number/where to find it on rockauto?
thanks again RMA and birdduck
#342
no problem .. good luck .
#343
ok so i got the engine out yesturday afternoon .. wasnt to bad , the hardest part was getting the cats off to get to the bellhousing bolts.(Damn exhaust bolts)
started to swap over some of the parts needed and welded shut the hole at the thermostat housing that was used to fill the lexus radiator.
also finished wrapping the harness .. sheathing tape and liquid tape.
also painted the engine mounts i never painted before .
man what a diffrence between engines .
also need to remove and use some of the better exhaust studs.
#346
Wow you got a really clean engine. Yeah it's funny how you can overdo things. Just keep the engine together and slap it in there. I've seen a few swaps done with basic hand tools and horrible welding skills... but they fire up and haul a$$. These engines are so basic once you get rid of unnecessary stuff.
#347
thats ,my plan to find a nice low mileage motor and swap them out.
#348
well got her going saturday morning.. drove her around all day .for the most part its all good .
but she doesnt want to idle .. when i start her up its real low , when i come to a stop she will die sometimes .
im off today ..so i guess i will be testing all day.
#349
i wish i could do away with alot of the stuff not really needed , but i want to keep her legal.
well off to test some things out in mine.
#350
i don't know how well they inspect all the emissions control stuff in cali, but you may be able to get away with it?
check your IAC first to see if its working properly, and also check for vacuum leaks.
simple way to check for vac leaks is with a can of either, just spray it around the intake and if the idle changes when your spraying you've pinpointed a leak.
#351
yea did that no leaks .. somethings not right with the iacv.. she tested out fine ,according to the fsm.
but it wont open back up , once it closes. i dont have the book with me right now but the computer relies on about 6 different signals to tell it when to open or close the iacv , or what step it should be on between 0-125 steps.. i just need to find out which one is not right , i guess.
#353
Passed first smog with the swap.
ok i got the idle fixed .. adjusted the tps again for the 3 time and that seemed to do the trick ..
then i took it to go get smogged .. it passed ..
and for anyone interested heres a scan .
#355
Wow you don't mess around man! That's awesome that you got everything up and running so quick. Take a couple shots of the engine bay for us when you have a chance. Yeah the TPS has to be set on every engine if you separate it from the original computer. Glad you got it figured out so quick.
#356
ill get some pics up right now ..
