1JZ GTE VVT-i into 22R 84 Runner
#161
Maybe I missed where you said (if you did) what intercooler you used? earlier in the thread it looks like you had a typical one in the photo not a top mount looking one like that. I'm fighting where to put mine right now, the plumbing is going to be complicated. I thought about doing a top mount like that, its how my 2005 Subaru STI was, top mount and it made decent power. Where did you get that one? Is it anything like this: http://www.speedyracer.com/intercool...ic-Accord-CRX-
The one I'm using I found on two different sites but then found it on ebay at a store the cheapest. I'll half to look it up and get back to ya.
#162
#164
This is just so you can see what I have with the stock rear driveshaft, and for the front just remember it's already been extended about 2 inches in the past and that's an 1 1/2" spacer which is a hair to long. Probly end up with a 1inch instead.
#166
Yeah the only reason it worked out I think is just cause of the combination of lifting it and then moving the whole drivetrain back so the two kinda helped to counter the other. But as of now with only minor wheeling and over a thousand miles on the road and no issues
#167
So the past two months ive had ALOT of people ask about or atleast tell me that I should put a kit together that would allow somebody to bolt this motor and drivetrai into there truck or Runner.
Just wondering what people's thoughts would be on that?
#168
#169
Ha Thanks for the feedback chefyota. When I started this build I wanted to make it easier for the next person and answer a lot of the questions I had starting out after hours and hours and hours of research and trail and error with parts.
#171
how much difference would there be between yours and the 2jz?
#172
The 2J is almost the same identical setup. Except that it is a 3.0L instead of 2.5L. So overall the dimensions of the motor make it a little taller than my 1j. So in short I'm not so sure you could do a 2j swap with out having to do a body lift. I could of gone with a 2j but #1 I really do not like body lifts and #2 lol I figured the 1j would be a tight enough fit in their, no reason to get greedy with it. There is a guy here that has posted on my thread that just completed a 2j swap in his 1st gen Runner
#173
2jz requires a body lift, when i mounted mine it stuck up out of the engine compartment a couple inches. a 2 in body lift would probably do it or push it back in the bay 6 inches with a clearanced firewall. it all depends on the oil sump and what configuration its going in. with a rear sump and sas it could be mounted lower in the frame rails
#174
#175
hey guys signed up to yotatech all because of this thread, love ya work mate awesome job
just wandering if you could do a parts list of the required components minus fuel system to have to the motor and box all mounted in??? like radiator, the engine mounts ect
ive got a 87 xtra cab hilux i put a 1ggte in but now ive got a 93 duelcab lux with a buick v6 and th700 in it and i missss boost......the turbos on the 1g are dead and im tossing up whether to 1j the dual cab or single turbo convert the 1g and drop all of that in the duelcab
#176
As for the Radiator, I believe its on page 14 or 15 maybe not sure. its actually just a custom kit from summit. I roughly knew what dimensions I needed for one to fit. So on summit racing I found very close to what I wanted and orderd a "custom radiator kit" where you get the aluminum radiator and all the pieces. You half to cut them in and weld it out yourself. All you half to do is fabricate the mounts for it.
#178
I wish i would have checked out your build first before hacking mine up
#179
#180
