All Other Toyota Swaps I4, I6, Lexus V8
1jz '88
Old Feb 22, 2010 | 08:11 PM
project88's Avatar
1jz '88
So my truck has the 3.0 v6 with the 5spd and i'm lookin at swappin to a different/better motor. I also can get a g58 with tcase if need be. I'm considering doing either an N/A 2jz or 1jzgte. Will i be able to directly bolt either of those engines up to either of those transmissions...or if i is there a company that makes a bellhousing that would allow me to bolt one of those 2 transmissions up to those two engines?
Old Mar 18, 2012 | 07:47 PM
MaDkAtT44's Avatar
im in the same boat, i can get a 1JZ GTE round my area for cheap.
Old Mar 18, 2012 | 09:18 PM
7m4x4dude's Avatar
get a bell housing for a 2jzge 5spd.
they use a w56 trans in the lexus is300 and in the mkiv supra behind the 2jzge motor. you can purchase the bell housing new for about 350 bucks. you will also need to run the clutch and fly wheel through out bearing from the jz motor..
motor mounts might have to be custom. i haven't searched that route.. but for the 7m motor i used factory parts to install. very tight install for the inline six but definitely do able.
Old Mar 18, 2012 | 10:15 PM
MaDkAtT44's Avatar
dont mean to thread jack, just tring to get some facts striaght. if i get a custom bell housing made the 1jz will bolt to my current r150f trans?
Old Mar 19, 2012 | 07:37 AM
Hadmatt54's Avatar
The 1j and 2j also used the r154 transmission. The r154 has the proper bell housing to bolt to any "R" series transmission, but the input shaft of the r154 is longer than your r150f. The later r150f trannies have an input shaft almost as long as the r154, you will need one of those.
Old Mar 19, 2012 | 08:25 AM
7m4x4dude's Avatar
^yup he's right. I belive you can swap the input shafts between the trans but im not sure where the post or site i read that on is.
The jz bell is shorter than the m series bell for the R series trans.
Old Mar 19, 2012 | 06:07 PM
MaDkAtT44's Avatar
Awsome thx guys, i'm just starting to collect parts now for my swap. good luck project88
Old Mar 20, 2012 | 02:15 AM
suppra87's Avatar
You can't swap the input shafts due to the location of one of the gears on the shaft, 1st gear I believe. You can however swap the output shaft from the R150 into the R154. Then what you end up with is having to source an R154, disassemble both transmissions, reassemble one of them and your still stuck with R154 gear ratios.
I chose the custom bell housing route because it was much less labor intensive and much less expensive. Check out my thread on my 1JZ swap. Ill be dropping the motor in this weekend hopefully and should be able to answer more questions on the swap.
Old Mar 20, 2012 | 09:57 AM
7m4x4dude's Avatar
It would be fourth gear isnt the same ratio if any thing ',first gear is next to the intermediate plate with 5ththe on the other side..
I do remember the article i read the guy swaped most of the parts. Do you have a link to that thread/article?
Old Mar 23, 2012 | 02:28 AM
suppra87's Avatar
I'm looking for the article now as curiosity has gotten the best of me.
Here are the gear ratios though...
R150 gearing:
1st: 3.830
2nd: 2.062
3rd: 1.436
4th: 1.000
5th: 0.838
Reverse: 4.220
R154 Gearing:
1st: 3.251
2nd: 1.955
3rd: 1.310
4th: 1.00
5th: 0.753
Reverse: 3.18
Edit: Found it!
http://www.pirate4x4.com/forum/archi.../t-918808.html
Old Mar 23, 2012 | 07:02 PM
MaDkAtT44's Avatar
great info
Old Mar 23, 2012 | 07:39 PM
7m4x4dude's Avatar
I still feel u can swap the input shafts . Same gear ratio. The only unknow is the shaft od for input bearing. And the id for the main shaft pocket/ bearing.
suppra87
43
Feb 6, 2018 06:57 PM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
robroy75
Aug 17, 2013 08:54 AM
SupraRunner
47
Mar 18, 2012 07:41 PM
Yotamatic
26
Sep 22, 2011 07:46 PM
