Anthony's 3.4 swap
Old Apr 22, 2012 | 05:55 PM
  #101
anthony1's Avatar
She starts!
I got a bad MAF cause it throw P0100 code. It also die when I give it some gas.
My tach still read at 3K. I gotta chase down the right wire for that....
..... no muffer yet.
frst_start1.mov
Old Apr 22, 2012 | 07:47 PM
  #102
vasinvictor's Avatar
Put an EDM on it, and make sure you have +12 going to your MAF.
Old Apr 22, 2012 | 07:53 PM
  #103
ChefYota4x4's Avatar
Anthony.... THAT'S GREAT, MAN!
Congratulations, brudda!
Old Apr 23, 2012 | 05:40 AM
  #104
anthony1's Avatar
thanks.
I'm going to check the voltage on that. The engine I got it from is a 98T100. The MAF might be bad already. I'll call the place I got it from to see if I can exchange for another one.
I also need to order two O2 sonsors. Unless I can use the 95 ones.....any thoughts on that?
I'm gonna nget new cat converter cause the old one probably went bad due to the HG problem.
Old Apr 23, 2012 | 08:46 AM
  #105
ultimase's Avatar
Probably a long shot but I think I remember someone having the same problem with the maf placed backwards in the intake tract...
As for the o2 sensors check on oreily's and see if the part numbers are the same for compatability.
Old Apr 23, 2012 | 09:10 AM
  #106
anthony1's Avatar
well, the side with the hole in the middle of the "bullet" is where the air flows in right? This pictue is how I have mine...
Old Apr 23, 2012 | 09:17 AM
  #107
ultimase's Avatar
I'll be honest with you I'm not sure, I never removed my MAF from the air box so far because I didn't want to accidently reverse it. I just remember a posting mentioning some similar symptoms with the maf reversed.
Old Apr 23, 2012 | 10:02 AM
  #108
anthony1's Avatar
That's cool. Thanks for trying....
Old Apr 23, 2012 | 03:10 PM
  #109
dntsdad's Avatar
There is an arrow that indicates the airflow direction on it. And it will really only go in one way
Old Apr 23, 2012 | 03:42 PM
  #110
anthony1's Avatar
Yeah, I've noticed the arrow and it's pointing towards the Throttle body.
I'm picking up another one during my luch hour tomorrow for 50.00
I hope to get the tach working tonight....
Old Apr 23, 2012 | 06:04 PM
  #111
anthony1's Avatar
t the tach problem solved. I didn't put the signal from the igniter (8 blk) in the right pin on the IH2 (20) side. I also made the mistake of taking out the needle when I soldered the 10K ohm resistor. When I put the needle back it was way off...like 3K off.... Anyway, it's in the ball park now...)
Old Apr 23, 2012 | 06:07 PM
  #112
anthony1's Avatar
I'm going to get the K&N air filter kit since I don't want to deal with the air box. I think 4wheel parts sells them for about 220.00
I also found out that the Autozone exhaust pipe I got has the O2 sensor in the wrong position. I'll have to modify it to work. As it is, I can't put the O2 sensor on cause the frame of the truck is in the way.
Second thought, I'm going to take out the section to see if I can install the sensor then put it back and see how much clearance I have...if any. When I have to replace it again, I'll just remove that section again.
BTW, I did not do the fuel relay mod yet. The truck started fine and idle fine for about 30 sec. Does this mean I'm good to go?
Old Apr 24, 2012 | 09:55 PM
  #113
mpleitez's Avatar
Nice Swap!
I just read the whole thread,that is a super clean install. I'm on a couple other forums and the info and stuff you guys do on here is great! Something I may try next year. If you dont mind me asking what is to total cost to this point? Again Nice job
Old Apr 24, 2012 | 10:36 PM
  #114
anthony1's Avatar
Thanks. I put the majority of my expense on the first post. I'm too scared to add them up ...
Old Apr 26, 2012 | 07:08 PM
  #115
anthony1's Avatar
Ok. I finally got the truck started with NO code at all. It rev. fine too.
I'll take some pics after I finish putting in K&N filter kit. I don't want to use the air box. Getting the whole kit with the CARB approved air filter setup will help me pass smog...I hope.
Old Apr 26, 2012 | 11:19 PM
  #116
ultimase's Avatar
Was it the maf giving you trouble?
Old Apr 26, 2012 | 11:45 PM
  #117
anthony1's Avatar
Yeah. the MAF and the coolant temp wire wasn't making contact. I end up buying two more MAF for 80.00. The original placed told me they want 50 bucks for exchange....forget it!.
Oh, and the fuel pump wasn't coming on...reseated the FC connection and it worked.
Old Apr 26, 2012 | 11:47 PM
  #118
anthony1's Avatar
I still need to test the evap connection after the engine is hot to see if it will open or not....and to see if I'm dumping gas through the canister. If that happens, I got the gas lines reversed.
Old May 22, 2012 | 02:19 PM
  #119
anthony1's Avatar
My first tried at passing the referee wasn't sucessful.
The ECU wasn't "seeing" the EVAP system. It came back with "Not Available"
I'm going to check my wiring again. Maybe I got the wires reversed.
The second thing is that the K&N filter I got is for the 4runner instead of T100. The ref looked up the CARB number and told me it's for the wrong vehicle even though you and I know it's the same freakin' engine.
I have to get the CARB number for the T100. I've worked out a way to do it with a rep there after he reviewed the difference between the two systems. I have to send him a form for the d-cal and a picture of the K&N system installed in my truck. He'll send me the right CARB d-cal.
Old May 23, 2012 | 07:39 AM
  #120
anthony1's Avatar
Btw, the ref didnt' even mention anything about the cross over pipe to dump to the driver side. He said everything else looks good.
