3.4 swap still viable in 2024?
Old Oct 12, 2024 | 03:51 AM
djowea's Avatar
I've got a 3.0 manual 89 4runner that's been sitting for the last ~15 years that I would like to finally get up and running again. I am wondering, are 3.4 swaps still viable in 2024? I've been looking at salvage options, but it's pretty hard to find something that isn't high mileage these days.
Old Oct 12, 2024 | 07:09 AM
aztoyman's Avatar
I would think if you can get a reman 3.0 you can get a reman 3.4. A 3.0 would be a direct replacement at least but you would still have to deal with what has been sitting all these years. Such as bad gas in the fuel system, rotten hoses and belts, etc.
The 3.4 would require the same plus the swap work and expense but you'd have a better engine.
LS swaps seem to be going in everything these days. Would that be an option for you?
Old Oct 12, 2024 | 05:31 PM
toyoda addict's Avatar
Yes. https://toyonlyswaps.com/
That's what I'd do if it was my rig.
Old Oct 13, 2024 | 07:03 AM
truckmike26's Avatar
Is the 3.0 in it now serviceable?
Old Oct 13, 2024 | 04:45 PM
YotaHunt's Avatar
I plan on doing the 3.4 swap in 2025 sometime. I plan on doing a rebuild of a cheap 3.4 I picked up. I'd rather rebuild it than the 3.0.
Old Oct 14, 2024 | 11:49 AM
djowea's Avatar
thanks for the replies all, lots of interesting thoughts from them.
I guess I didn't think about it in that way but you are totally correct. Either way I am probably doing a significant reman, but it would still be better to end up with a 3.4 I think
thanks! I hadn't seen them yet, but I will definitely be emailing for details.
As far as I know it is. I got it from a friend, and he indicated that nothing was wrong with it, he just slowly stopped driving it until one day it was parked. That was in ~2010. Around 2012, he didn't want it in his yard any longer, so I bought and stored it in my parent's garage. Superficially, it appears to be in pretty good condition. I'll be there in December and that is when I can really see what's up. Right now, I'm just doing the early prep work of figuring out what all I need to do to get it going, and then work up to something approaching a daily.
Old Oct 14, 2024 | 12:17 PM
aztoyman's Avatar
If you are leaning toward a 3.4 swap check out the stickies and read up. I had a running donor for my swap and I highly recommend getting one if you can. Getting all the parts from one truck is the best way in my opinion. If you are going to run an automatic, get an automatic donor and the same if you want to run a manual trans. You will spend a lot more time and money piecing a swap together from multiple sources.
If it was a running truck without problems I think you are on the right track by getting it running again as is. It's still a lot of work and can still get expensive.
I did just that with two pickups that had sat for years. The fuel system was full of crud, lines were plugged. All hoses and belts were dried out. Even the brake hoses. I had a couple split when I was flushing the system. Hopefully no rodents got into your truck. They can do some damage. One of mine had the coolant crystalize. I did get them running. I basically had to go through pretty much everything. Once I got them going I took short test drives at first, did some rechecks and went from there.
Whatever you decide, good luck with your project. Please follow up. Dead end threads suck.
Old Nov 27, 2024 | 07:14 PM
Pat4wd's Avatar
5 Year Member
Still viable and highly recommended, motors are plentiful and such a monumental improvement over the 3.0.
Old Jan 6, 2025 | 04:53 AM
Jake.Werecat's Avatar
5 Year Member
Sure. I'm in a middle of my '91 4R restoration and 5vz swap right now.
1gr are expensive, not a direct fit, and less durable, so that leaves 5vz still a strong & solid choice.
Old Jan 6, 2025 | 01:37 PM
djowea's Avatar
Well I haven't made any progress on the motor situation, but I did get it out of the barn and washed for the first time in 15 years
Old Jan 6, 2025 | 06:26 PM
5 Year Member
Gorgous car!
Old Jan 12, 2025 | 08:46 PM
aztoyman's Avatar
That's a nice truck and definitely worth fixing up. If it was me and it WAS running before, I'd try to get it running before I jumped into a swap. Getting the fuel system cleaned up would have to be done either way so it wouldn't be wasted time or money for that stuff. A running truck would give you time to plan your swap and gather what you need. Good luck.
Old Mar 5, 2025 | 07:34 AM
95-4runner's Avatar
Throwing in the towel with my 3.4 swap
I started a 3.4 swap on my 95 4-Runner many moons ago, then a life changing event halted everything. It is finally apparent this project must move on to someone who can finish it.
I have a 3.4 (90k miles) installed all necessary mods completed.
The truck has a manual 5-sp from a 97 4-runner
I have the harness from toyonly swaps that I was never able to debug.
I will be listing this in the classifieds but I have to get my post count up to 15 in order to list it.
Old Mar 5, 2025 | 09:02 AM
aztoyman's Avatar
That sucks. Sorry to hear this. Where are you located and what exactly needs to be done yet? Just wiring bugs? I'm sure there are people out there that would jump on this if the price was right. Me included but I'm in AZ.
Old Mar 5, 2025 | 12:50 PM
95-4runner's Avatar
I'd like to get $3000 for it. It also has new FP and Gas tank.
Old Mar 5, 2025 | 12:51 PM
95-4runner's Avatar
Alrighty I'm up to 16 posts!
mt_goat
3.4 Swaps
39
May 23, 2016 11:59 AM
towotaguy
3.4 Swaps
Mar 6, 2016 07:40 PM
yotaman
3.4 Swaps
14
Feb 23, 2009 11:20 PM
Azusacanyonbogger
3.4 Swaps
18
Feb 10, 2009 09:50 AM
CoedNaked
3.4 Swaps
88
Dec 30, 2007 05:23 PM
