3.4 swap problems?
Old Jun 22, 2014 | 07:51 AM
NWLS's Avatar
Hmm. Weird. Id say just Get it in there and see what'll work in your situation. Every swap is a little different.
Old Jun 22, 2014 | 10:48 AM
runnerruning's Avatar
Straightforward enough i suppose. I need the pump first. So I'm pretty sure I got my fuel lines figured out. I took off the big line with the screw in connection off the rail, flipped it 180* and got that buttoned down. Then flipped the smaller line over so it can run back down to return. Now tell me, is the hard line that's attached to the fender where the return hooks back into? It has a yellow stripe painted on it, as does the other line I flipped. I just need to be sure.
Old Jun 22, 2014 | 06:04 PM
PICDUMP!!!! from earlier!!!!Name:  IMG_20140622_142229599.jpg
Old Jun 22, 2014 | 07:23 PM
SacRunner's Avatar
https://www.yotatech.com/forums/f160...l#post50682888
Seriously, EVERYONE should read Elvota's swap 3-5 times, I'm pretty sure he covers just about everything in great detail:
https://www.yotatech.com/forums/f160...4-swap-128285/
Old Jun 22, 2014 | 07:29 PM
  #25
SacRunner's Avatar
Connect that hose in your hand:
Originally Posted by runnerruning
to the exposed fuel line:
You'll need to loosen the banjo bolt on the aluminum fuel rail and rotate that hose so that it "points" toward the passenger side (from the driver side) and that should give you enough slack to connect it to the hard line.
^ That port in the middle should be the vent line from the gas tank, or the fuel return; I don't remember off the top of my head.
Old Jun 22, 2014 | 07:55 PM
  #26
Boom! Answers! Hahaha thanks Sac. I've been scratching my head on which is which. I suppose I flipped it right, guess well see. As for whether or not its the return I figure it oughta be, why would Toyota put a vent in that particular spot? But then again its just speculation, and I needed some clarity. I guess I'll read back through Elvotas swap AGAIN and see if I'm missing anything.
Old Jun 22, 2014 | 08:27 PM
  #27
vital22re's Avatar
totally a bro
the vent line is isolated like that so it won't be confused for the return. Also the charcoal canister is located on the fire wall so why not have the vent right in front of it but not in the way of engine wire harness and not next the return so slightly less confusion.
Old Jun 23, 2014 | 08:07 AM
  #28
Well crap. I suppose now I need to isolate the return. Any clues on which one that one is? And I'm using the evap box from the 3.4, do I still need the charcoal canister from the 3.0?
Old Jun 23, 2014 | 12:17 PM
  #29
SacRunner's Avatar
I looked at my truck, and that hard line in the middle IS the vent line (unless the soft lines at the tank got mixed up at some point), and the return line is the hard line that has the little 'S' bend in it near the disconnected A/C ports in the fire wall (just to the far right in your picture).
Old Jun 24, 2014 | 11:16 AM
  #30
thanks for checking on that. Any chance you can find the return for sure?
Old Jun 24, 2014 | 02:50 PM
  #31
SacRunner's Avatar
See above.
Old Jul 22, 2014 | 08:17 PM
  #32
okay guys, done more work on it, and have a few more questions. firstly, what is this line that comes from the firewall?Name:  IMG_20140722_165303961.jpg
Second, do these two lines connect?Name:  IMG_20140722_165242324.jpg
one is from the booster, the other is the biggest line on the plenum. if not, where DO they connect? since im on my laptop for once im going to thumb through elvotas swap again. for the 20th time. thanks in advance.
Old Jul 22, 2014 | 08:38 PM
  #33
rworegon's Avatar
In pic 2, the one on your pointing finger with the silver end plugs into the air intake tube.
Old Jul 22, 2014 | 08:41 PM
  #34
ohh okay. and what about the line from the booster?
Old Jul 22, 2014 | 10:03 PM
  #35
dntsdad's Avatar
Pic one is the drain for your ac unit if I'm seeing it right.
Brake booster? Big line on drivers side right next to the diagnostic plug, above the header. Make sure you use the check valve.
Old Jul 23, 2014 | 05:58 PM
  #36
that clears up that bit. ill look tomorrow. I worked on getting the trans in today. I have the crossmember bolted up and the trans hanging. trouble is it doesn't seem like it is wanting to line up correctly. it seems a bit off and once I finally got one of the bolts to thread it was really tight and hard to turn. I didn't proceed any further. im severely hoping that I got it lined up right and didn't ram the input shaft straight into one of the fingers on the pressure plate. god that would be so awful. any advice as far as installing a transmission anyone?
Old Jul 24, 2014 | 11:56 AM
  #37
Can anybody offer help here?
Old Jul 24, 2014 | 12:25 PM
  #38
JasonYota's Avatar
Installing the transmission? How did you take it out?
Old Jul 27, 2014 | 06:15 PM
  #39
neverming. I got some help with it and got it in. another question, I had thought about running my intake into the cabin plus a filter. if that's the case, do I even need to move the battery?
Old Jul 27, 2014 | 06:18 PM
  #40
JasonYota's Avatar
I wouldn't see a reason to move the battery if your rerouting the intake
