3.4 swap problems?
Old Dec 28, 2014 | 12:28 PM
  #101
rworegon's Avatar
Originally Posted by runnerruning
Stupid question, but what is the right way to fill coolant from completely empty?
Pull the upper radiator hose off the radiator, fill the block through the upper hose, then attach hose to radiator, and fill the radiator. You'll likely need to burp some air out of the system and add additional coolant as needed. Oh yeah, fill the expansion to the cold line also.
Old Dec 28, 2014 | 12:52 PM
  #102
runnerruning's Avatar
Thank you. I just wanted a second opinion.
Old Jan 1, 2015 | 01:55 PM
  #103
Okay, so I got it running and took it down the road after filling with coolant and water. It got plenty hot but never idled down. Also i found a leak where the lines run into the heater control, but that's because there aren't any clamps. But like I was saying, it never idled Down.
Old Jan 2, 2015 | 07:14 AM
  #104
dntsdad's Avatar
Are you sure that your throttle cable is adjusted properly? Every one that I have done needed some tweaking of the throttle cable or the bracket that holds it to allow it to close.
Old Jan 2, 2015 | 02:42 PM
  #105
yeah im positive. the throttle is fully closed.
Old Jan 2, 2015 | 02:45 PM
  #106
sphealy's Avatar
I would still recommend doing the tac mod so you know where its actually at. I do recall seeing someone mention how to adjust idle in the how to ac your 3.4 swap. Haven't read that part but it might be worth a look.
Old Jan 6, 2015 | 07:31 PM
  #107
So while out messing with it, my buddy disconnected the IAC valve and the idle dropped quite a bit. Maybe its stuck open? I'm not sure and won't be till I get off work tomorrow evening. I'll keep posted. Again guys thank you for everything.
Old Jan 7, 2015 | 12:25 AM
  #108
vital22re's Avatar
totally a bro
I'm seeing this more and more. IAC gets stuck or gummed up and will not idle down properly. Sometimes pulling it apart and cleaning works.
Old Jan 7, 2015 | 04:38 PM
  #109
I did. I think I'm gonna pull it off and test it tonight. Maybe. Its too damn cold.
Old Jan 8, 2015 | 06:19 PM
  #110
Okay, so I pulled the green coil off and twisted it back myself, perfect idle. So could that mean bad IAC?
Old Jan 9, 2015 | 12:21 PM
  #111
vital22re's Avatar
totally a bro
yes. Replace it and be done.
Old Jan 9, 2015 | 05:22 PM
  #112
So it turns out I missed a vacuum line. Go figure. Idles fine. But, like anything, a new problem arose. I let it sit there and idle for about 10 to 20 min, checking for leaks and what not, then as I'm going to go shut it down I get in and notice the tach is slowly going up and down. Normally it doesn't move even when I revved it. I gave it some gas and it seemed like it wouldn't take it and wanted to die. Then, it slowly did. Then I have no power whatsoever. Nothing to the key, none anywhere. I thought I heard a faint click, but I'm not all that sure. Thoughts? Is there a main fuse? Im trying to find my meter, but its location is undetermined at the moment.
Old Jan 11, 2015 | 03:23 PM
  #113
Okay. Figured that out too. Popped alt and efi fuse. Fixed both, then cleaned up the runner. Next comes intake and exhaust, speed sensor, then I guess I'll pull the tach and try the mod again. But I'm definitely taking a small break from it for a bit. So again, thanks for the advice, most particularly from vital22re, dntsdad and Jasonyota.
Old Jan 27, 2015 | 08:09 PM
  #114
Oregon'sLoneWolf's Avatar
Thumbs up
Originally Posted by vasinvictor
When I bought my motor, I couldn't easily turn the motor over, and it seemed to catch in a place. I nearly passed on it. I cranked it back and forth until it freed up and it's been an excellent motor for over 10k now. Take your spark plugs out and see if you can spin it over. I kinda doubt it's seized partially.
I'll turn mine over a revolution at the crank bolt when I re check its torque prior to it going in just for piece of mind. Since it has been sitting a year prob a good idea for me to squirt some oil in the cylinders too just in case.
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
XtraCab
Apr 12, 2020 05:25 AM
mskalmus
May 28, 2017 07:51 AM
steve miller
Oct 10, 2015 01:40 AM
coryc85
Sep 9, 2015 06:24 AM
