What rotor are you using??
Old Aug 25, 2003 | 10:55 AM
kctopher's Avatar
Co-Founder/Administrator
Ok guys, I’ve found plenty of post on the why’s? but I need to know the where’s.. I need to replace my front stock rotors but I don’t really know who to use.. I have no problem forking over some extra $ IF I get a good quality rotor that will perform better then stock (Drilled/slotted will probably be the best bet).
So, what have you replaced your stock rotors with? How long have they been on? Problems? Who did you use?
I’ve found anything from 122 a single rotor to 180 a pair…
Thanks,
Chris
Old Aug 25, 2003 | 11:37 AM
jacksonpt's Avatar
Senior Member
Gadget has said that aftermarket rotors are not worth the extra money over OEM rotors, especially considering how fast the rotors warp. That's good enough for me.
Old Aug 25, 2003 | 11:46 AM
SLC Punk's Avatar
I turned my OEM rotors when I did my brake job. But to answer your question, I would go with OEM rotors with performance friction pads.
Old Aug 25, 2003 | 11:50 AM
jacksonpt's Avatar
Senior Member
That's the combo I'm running. Under typical driving condition, I don't notice any difference over stock. But when I really jump on the brakes, the performance friction pads have a lot more grip.
Old Aug 26, 2003 | 06:15 AM
amorphous's Avatar
1.5k thus far....
...on my Brembo's w/ Apex kevlar brake pads. I'm loving them - they stop on a DIME (way better than the stock I had, plus thier not warped!) So far, I've had great performance with this combo.
hope that helps,
aaron
ps, they were $72 each for 16" wheels from www.thepartsbin.com
- of course if you want OEM - talk with Todd at Toyota of Richardson TX!
Old Aug 26, 2003 | 08:27 AM
3.4v6's Avatar
i just replaced my rotors with some powerstop slotted rotors that i got from www.truckperformance.com . they are pretty good. but it was around $250 shipped.
Old Aug 26, 2003 | 08:34 AM
data's Avatar
Senior Member
I bought mine from www.raceconcepts.net
I've had them for about a year and I've been really pleased with them. They also were at my door in like three days. Good stuff!
Old Aug 26, 2003 | 10:47 AM
CLin9383's Avatar
AMORPH, I DIDN'T SEE THE BREMBO BRAKES ON THAT SITE YOU PUT UP...I WOULD LOVE TO GET BREMBOS FOR THAT CHEAP..
Old Aug 26, 2003 | 11:10 AM
amorphous's Avatar
go here....
here ya go....
http://catalog.thepartsbin.com/?year...imageField.y=8
the top set is what your looking for ....they say "disk brake BRE"
it cuts off, but having called them to confirm...then recieved them...they are most certainly brembo's! AND cheaper than I thought I paid....$65.94 each!
Email me if you don't get the link to werk!
~aaron
Old Aug 26, 2003 | 11:15 AM
oly884's Avatar
Guest
I'm running the NWOR cross drilled rotors.
Old Aug 26, 2003 | 02:34 PM
Krash's Avatar
Re: 1.5k thus far....
Whats the deal with Brembos? I got to get my warped rotors fixed and was just going to have my rotors turned but if these are better (only 50$ for my truck) I will probably buy them.
Old Aug 27, 2003 | 05:55 PM
CLin9383's Avatar
amorph, you have to buy 2 of them right? it's 65 for one disc? and do you think those with OEM yota pads would work well?? are they slotted or cross drilled??? any pics??? thanks
Old Aug 27, 2003 | 07:10 PM
amorphous's Avatar
Brembo's
I don't think you "have to" buy 2 at a time from them...but it's standard practice to replace in pairs.
I'm sure they'd work great w/ OEM yota pads!
no slots, no cross drilling, just the standard vents you'll find on OEM rotors.
I don't have any shots of the rotors themselves except one of the pads and them installed...you can't see too much of the rotors -i'll post these next....
~aaron
Old Aug 28, 2003 | 05:35 AM
amorphous's Avatar
here....
Old Aug 28, 2003 | 05:38 AM
amorphous's Avatar
apex pads
heres the kevlars....
Old Aug 28, 2003 | 08:06 AM
loosehead's Avatar
I replaced my pads and rotors (warped, I live in the mountains) last month with all new parts from the local Napa. They are Napa/United brand rotors for $60.00 each and the pads are a semi-metallic, also from United for around $35. No shipping and I had 'em the next day. Actually, the pads were in stock and the rotors had to come up from a warehouse...It stops better now than it did when I bought the truck last year.
One more thought, don't forget to adjust the rears and bleed the lines after you get the new ones in...
Old Aug 28, 2003 | 08:10 AM
amorphous's Avatar
true words.....!
SUCH a good idea....get new fluid in there!
~a
ladybugRC
458
Aug 21, 2020 10:41 AM
Kamaloha
Oct 16, 2015 05:13 PM
the_supernerd
Oct 1, 2015 09:20 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Toys4parts
Sep 26, 2015 01:56 PM
