possible starter problem??help
Old Apr 13, 2005 | 09:17 PM
knemo77's Avatar
Arrow possible starter problem??help
I have been suffering with a slow starting truck for a little while now. The problem drives me nuts but always starts on the first try. Two days ago in the morning I turned the key and nothing....not even a attempt to turn over. I then turned the key a few times and it started right up.
I thought it might have been the battery so I replaced it with a new one hoping it would solve the problem. But now it is consistantly taking two turns of the key to get it going.
Does anybody have any idea what could be causing this? Could it be the starter? the alternator? If you need more info please ask me and thanks in advance for any help you can give me.
Kris
Old Apr 13, 2005 | 09:29 PM
dragon564's Avatar
It could be the starter that is going out on you.....or to be even more exact the relays inside the starter....do you get the click of the starter or just nothing at all. On the slow starting is it the starter that is turning slow or the eng that is just hard to crank over.....a quick check for that is pull the spark plugs out and try cranking it over, if it turns easier then the eng is hard to crank....if it does not then the starter is the culprit.....ps belts that have been over tightened can also make a eng a little harder to start.....
Old Apr 13, 2005 | 10:35 PM
knemo77's Avatar
when it doesnt start i get nothing at all from the starter. sometimes it will turn once and stop like the battery was dead but im sure the battery is not the problem. then on the 2nd turn of the key it will start right up. Once the truck is started it runs like a dream.
also...could the problem be the spark plugs? they are also the origionals.
i'll try removing them like you suggested in the mornin.
Old Apr 14, 2005 | 06:06 AM
YotaJunky's Avatar
You may have a loose connection in your wiring. Check the positive cable going to your starter for corrosion and the smaller one going to the solenoid. Sometimes they get loose and give you intermittent starting problems.
Old Apr 14, 2005 | 06:17 AM
knemo77's Avatar
that would kick if was only a connection....i'll check that today.
Old Apr 14, 2005 | 06:48 AM
metalhed's Avatar
starter! look at roger browns site or go to the dealership and get a new set of contacts. Rogers site has a excellent description of the complete process
Old Apr 14, 2005 | 11:15 AM
knemo77's Avatar
Who is Roger Brown?
Whats his web address?
thanks for the info.
Old Apr 14, 2005 | 11:17 AM
89_4runner's Avatar
Roger is 4Crawler. His website is 4Crawler.com.
Old Apr 14, 2005 | 11:18 AM
rimpainter.com's Avatar
http://www.4crawler.com
Old Apr 14, 2005 | 03:12 PM
dragon564's Avatar
There you have your answer....Rodger Brown has a really good write up on it......let us know if that fixes the problem....
Old Apr 14, 2005 | 03:25 PM
jc1kz's Avatar
my money is on the battery......its either week or being drained.....once you get going and it is charged your good for the rest of the day.....but what do i know? nothin.....lol
Old Apr 18, 2005 | 01:32 PM
knemo77's Avatar
I don't think its the battery because I changed it out the other day and it is behaving the same as before.....im gonna try Roger's ideas and see if I can sort this problem out.
I'll keep you guys updated on my progress as soon as I find time to start diggin.
thanks for all the replies.
Kris
Old Apr 27, 2005 | 12:40 PM
knemo77's Avatar
I found out that my car was still under the extended warranty and I tool her to the dealership. It was the starter (i'd guess the solenoid) but they replaced the entire starter for me. A front o2 sensor was also replaced.
They hit me up for a grand total of $800!!!!
But the co-pay on the warranty was only $70.
They also said I should clean the MAF and change the fuel filter. But the trucks running great.
Thanks for all the info.
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
clok
Aug 1, 2015 09:42 PM
Hiluxtrucha
Jul 22, 2015 10:00 AM
ZONAYODA
Jul 13, 2015 07:17 PM
colinmil
Jul 6, 2015 04:03 PM
