"Clocking" axle
"Clocking" axle
Who "clocked" his or her rear axle when a leaf swap was done? What degree? Rotating the axle in order to turn the 3rd member upward a bit would help, correct? Would this increase axle wrap issues?
By the way, once my SAS and rear leaf swap is underway, I will post a comprehensive thread and maybe delete my others.
I don't see why it has to be more prone to axle wrap, if you weld the spring perches accordingly you're only improving the pinion angle...
In the front you'll mess the steering but the rear can be rotated.
David
David
I cut off the OEM spring perches and welded on new ones that were rotated so the rear pinion was aimed at the t-case output. Takes a little more time but with it all torn apart it was pointless not to do it if I was only going to have to shim it later.
The angle of the rear pinion will depend on the type of driveshaft you are running:
- http://www.4crawler.com/4x4/ForSale/Shims.shtml#FAQ1
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
Cycles
Sep 29, 2015 06:37 AM
Toys4parts
Sep 26, 2015 01:56 PM
