"Clocking" axle
Old Oct 12, 2007 | 08:49 PM
Spinnbait's Avatar
"Clocking" axle
Who "clocked" his or her rear axle when a leaf swap was done? What degree? Rotating the axle in order to turn the 3rd member upward a bit would help, correct? Would this increase axle wrap issues?
By the way, once my SAS and rear leaf swap is underway, I will post a comprehensive thread and maybe delete my others.
Old Oct 12, 2007 | 10:36 PM
Blizzard's Avatar
I don't see why it has to be more prone to axle wrap, if you weld the spring perches accordingly you're only improving the pinion angle...
In the front you'll mess the steering but the rear can be rotated.
David
Old Oct 13, 2007 | 05:52 AM
Spinnbait's Avatar
thanks
Great, thanks. I was just concerned that if there was any axle wrap, the symptoms would be worse.
Old Oct 13, 2007 | 06:15 AM
waskillywabbit's Avatar
I cut off the OEM spring perches and welded on new ones that were rotated so the rear pinion was aimed at the t-case output. Takes a little more time but with it all torn apart it was pointless not to do it if I was only going to have to shim it later.
Old Oct 13, 2007 | 09:40 AM
Spinnbait's Avatar
Thanks
Thanks Wabbit. I'll hopefully be contacting you sometime next week for a leaf swap.
Old Oct 13, 2007 | 10:02 AM
4Crawler's Avatar
The angle of the rear pinion will depend on the type of driveshaft you are running:
- http://www.4crawler.com/4x4/ForSale/Shims.shtml#FAQ1
Old Oct 13, 2007 | 05:04 PM
44Runner's Avatar
Exactly...
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
Cycles
Sep 29, 2015 06:37 AM
Toys4parts
Sep 26, 2015 01:56 PM
