Another SAS Thread
Old Jan 2, 2013 | 03:53 AM
1986YODA's Avatar
Another SAS Thread
Ok.... So I just finished cutting the Ifs out of my truck last night and I have a few questions. First of all can I use the ifs hubs on my 83 solid axel without much modification or any at all. Second question.... Can I use the brake calipers from the ifs on the solid axel and rotors too? Steering box.... Does this have to be moved forward on the frame or is it just preference. My hub question stems from the fact that my solid axel did not come with the Aisin hubs.... OR are those other hubs better... I have never heard a word about them... They have silver bodies with blue dials. Any other help would be great.... I'm not close to any of these offroad shops to ask questions
Old Jan 2, 2013 | 03:54 AM
1986YODA's Avatar
These are the hubs I was talking about
Old Jan 3, 2013 | 07:06 AM
Austin Marr's Avatar
IFS calipers/rotors will bolt right up. Not sure about the hubs, i think i've read that they will but i'd read up on some build threads to make sure. and im not sure on the steering
Old Jan 3, 2013 | 07:59 AM
JonnyBoy's Avatar
I'll give this a shot, first, the hubs: No. they are a different depth and a different spline count as well as diameter. I think it's a possibility if you change out to the solid axle internals, but as they are now, not happening.
Second, IFS calipers, yes, but not IFS rotors. You'll need FJ rotors, the application that worked for me when I did the brake upgrade on my '83 was for an '83 FJ60.
Third, the steering box may need to be moved, as I understand it's partly your choice in springs and axle location. So, maybe more details could clear that up for people who've actually done an SAS, otherwise nobody knows your application and if you need to move it or not.
Old Jan 3, 2013 | 10:46 AM
Toy-thrasher's Avatar
I'm in the process of my first sas in my 4runner and wanted to use my ifs hubs for spares so i can have one with me on the trail just in case. Because of this i found out that you can indeed convert your ifs hubs by replacing inner hub gear for like $60 bucks per side rather than new ones that are way spendy. Hope this helps a little.
Here are a few links to the ones i've seen.
http://www.davezoffroadperformance.c...-hub-gear.html
http://www.longfieldsuperaxles.com/p...INNER-HUB-GEAR
Old Jan 3, 2013 | 11:27 AM
rattlewagon's Avatar
^This.
You can also use tacoma rotors as slip ons if you do some grinding.
EDIT: found the link
http://www.pirate4x4.com/forum/toyot...sa-no-kit.html
Read this thread:
https://www.yotatech.com/forums/f31/...spacers-59071/
That picture of the hubs that you posted looks like factory hubs. Whats the lettering in the middle say?
Old Jan 3, 2013 | 05:44 PM
95yoter8's Avatar
They probably are warns or other aftermarket hubs someone put on or possibly repainted the factorys with blue or somethin. they should work with ur SFA
Old Jan 3, 2013 | 07:12 PM
waskillywabbit's Avatar
Probably "ASCO" which is early Aisin.
:wabbit2:
Old Jan 3, 2013 | 07:21 PM
mudpunisher's Avatar
:wabbit2:
x2, same thing, just older
Old Jan 3, 2013 | 09:46 PM
1986YODA's Avatar
Thanks guys!
Flying91
45
Apr 11, 2024 04:39 PM
I8URSVT
Sep 3, 2015 11:42 AM
Peevedkitten
11
Aug 31, 2015 06:57 PM
jake_v
Aug 27, 2015 03:18 AM
yourrealdad
Jul 21, 2015 11:13 AM
