93-98 T100s All T100 trucks
Old Mar 30, 2016, 10:40 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Interior Guides
Print Wikipost
Cigarette lighter not working 95 T100
Old Jul 29, 2012 | 10:05 AM
Matt Gaither's Avatar
Hey all,
I've searched around the site and found some info about this issue for 4runners, pickups, and Tacomas, but couldn't find a post about it for the t100. It's a new truck to me so I'm just finding my way around everything. Where could I find the fuse for this beast, and is it labeled anywhere? I've also seen lots of talk about a fusible link right behind the socket itself, is that the case with the t100 as well? If so do I need to pull off the front dash to get to it?
Thanks much!
Old Jul 31, 2012 | 07:11 AM
BamZipPow's Avatar
Um...maybe the CIG fuse?
Old Jul 31, 2012 | 07:30 AM
MaK92-4RnR's Avatar
it could be one of two things.
1) The fuse
2) the wire on the back of the aux. plug. They usually burn up when putting high output products in them. Such as a air mattress pump ( burned mine up a few times ) They're relatively simple to fix. its just a little 12-14 gauge wire on the back of it.
3) buy a new plug.
Old Jul 31, 2012 | 02:36 PM
BamZipPow's Avatar
T-100 didn't come with an aux plug. We were stuck with just the cig outlet.
Old Aug 1, 2012 | 10:26 AM
Bam, where is that fuse box in your pic? I looked in my driver's kick panel and behind the battery and neither have a cig fuse named.
Old Aug 1, 2012 | 10:37 AM
BamZipPow's Avatar
Wink
Driver's kick panel...it should be a 15A fuse (blue) in the middle of the bottom row. It won't be named...since the names are on the door...which you probably don't have.
Old Aug 1, 2012 | 10:57 AM
Awesome, thanks, I'll give it a look over lunch.
Old Aug 1, 2012 | 11:47 AM
cr@ves4wheelin's Avatar
Mine ended up not working because of #2 on what Mak said. After a little wiring fix, it was working again.
Old Aug 1, 2012 | 11:46 PM
stanz's Avatar
Mine ended up being even simpler than that -- previous owner forget to connect the plug when he was working on it.
Old Aug 2, 2012 | 08:52 AM
haha that's pretty lucky.
Old Aug 16, 2012 | 04:49 PM
Ok, the fuse looks fine. Going back to Mak's #2 fix, I've pulled out the ashtray and the panel below it but I don't see how to get behind the plug to check that wiring. Any tips?
Old Aug 16, 2012 | 06:47 PM
BamZipPow's Avatar
You have to pull the radio bezel off and then remove the radio and tray (4 screws). You should be able to see the wiring then.
ashersullivan88yota
Jan 18, 2022 05:37 PM
Sep 4, 2015 09:27 AM
Johntom240
7
Jul 13, 2015 12:18 AM
crashburnoveride
Jul 10, 2015 06:39 AM
madxman21
Jul 9, 2015 10:26 AM
