General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
New Alternator same problem ?
Old Apr 27, 2018 | 05:34 AM
85camo's Avatar
1st of all ... Much Thanx to everyone !
I am now in the process of going back to a" starting point", checking wire harness ,pulled alternator , connectors , grounds , plugs , wires , checked valve lash , timing, compression , all of it.
I put a new motor in this truck several years ago had no problems with it till this past winter
The beast has been re-geared with detroit lockers and centerforce clutch ,85 solid front , with racks it's my firewood hauler. Can't give up on it
I've stated before "Electrics " not one of my strong points SO I THANK ALL FOR THEIR KNOWLEDGE AND EXPERIENCE !
Old Apr 27, 2018 | 05:39 AM
Thommo Thompson's Avatar
i think electrics are no ones strong points, even auto electricians.
electricity does what it wants, and we cant see it. all i know is it hurts if i touch it
Old Apr 28, 2018 | 05:31 AM
85camo's Avatar
Charge light relay behind passenger kick panel on 83 ..... the problem or at least part of it
There's a lot of posts on other sights relating to "charge light relay malfunction "gauge light not coming on / light staying on AND its relationship to the Reg & Alt
if so I have a lot of company in this nightmare
my charge light was staying on even while alt is charging at 14.20V
I took off parking break and the charge light turned off
now when turning on Ign and starting motor, charge light doesn't come on at all
85camo "oscar mike"
Old Apr 28, 2018 | 09:18 AM
RAD4Runner's Avatar
Originally Posted by 85camo
Charge light relay behind passenger kick panel on 83 .......
now when turning on Ign and starting motor, charge light doesn't come on at all...
Haven't herd of a charge light relay, at least not on 1986 22RE.
IF charge light comes on when your alt output is between 13.5 and 15.1V, then either:
1) Regulator is bad- thinks it's not doing a good job when it is., OR
2) Bad diode on gage/combo meter/dash cluster circuit causing brake error to also indicate charge error.
I have a 83 Yota PU SR5 with standard 1985 22R- Carb...
Need to know whether your charging circuit remained that of an 83 or updated to that of an 85.
Old Apr 29, 2018 | 07:43 AM
  #25
85camo's Avatar
My charging circuit is still 83 , i used 83 alt with external reg same as stock. My 85s have internal regulators
Old May 13, 2018 | 12:03 PM
  #26
85camo's Avatar
UPDATE , As I said I went back to a starting point then after going through all that...no change BUT since I had a missing problem until alternator kicks in I got a very wild hair and decided to upgrade my stock carb to a Weber 38 . If it made no difference I could still use it on my other trucks. Any way long story short , changed out stock for Weber 38 and I'll be darn the charging /missing issue is now gone !
Took all emissions off, the weber works fine may need a little jetting adjust for up here but THE ORIGINAL PROBLEM IS GONE !
*the chicken or the egg thang ....Thanks All !
Old May 13, 2018 | 12:38 PM
  #27
NYHumpinUtah's Avatar
Good for you, I'm glad you found the problem, or did you? I have a gut feeling that your problem wasn't the carb but something to do with all the emissions you removed.
Old May 13, 2018 | 02:44 PM
  #28
85camo's Avatar
Yeah it's nice to have it run like the lil'beast it is AGAIN !!!
No doubt NY, Removing the emissions , switches , sensors, etc sure reduces the amount of "stuff" that side of the motor...kinda like frying bacon !
'79 beagle hauler
Sep 12, 2010 06:06 PM
H2osetd
Mar 17, 2009 08:36 PM
JShaffer0525
Feb 18, 2009 09:06 AM
funrunner91
Jul 3, 2006 10:06 AM
