General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
HID help
Old Sep 10, 2011 | 08:07 AM
wolf28's Avatar
Smile HID help
ws looking on ebay today for and HID kit and i found these and was wondering if they would work
http://cgi.ebay.com/ebaymotors/7x6-H...item20bc91e7aa
Old Sep 10, 2011 | 08:34 AM
91ToyYota's Avatar
I've always heard "say no" to any HID kits off Ebay.. Try going to a local shop that sells them, you'd be better off there
Old Sep 10, 2011 | 08:38 AM
wolf28's Avatar
the shop thats in my town cost to dam much to install hids on my yota
Old Sep 10, 2011 | 02:46 PM
wolf28's Avatar
bump any one else
Old Sep 10, 2011 | 03:25 PM
eric924run's Avatar
I see alot of people use the ddm kits. If you google ddm hid you should find the web sight. also seems most people say the slim ballasts are better quality
Old Sep 10, 2011 | 03:28 PM
wolf28's Avatar
i got them in my durango but was looking to replace the headlight lenses and go to hids n my toyota
Old Sep 11, 2011 | 06:30 PM
wolf28's Avatar
any one else
Old Sep 11, 2011 | 09:20 PM
streetlancer's Avatar
DDM Tuning
Old Sep 12, 2011 | 12:43 PM
wolf28's Avatar
does ddm tuning send me the whole new headlight lense
Old Sep 12, 2011 | 01:16 PM
blake.nemitz's Avatar
i used an ebay kit for like 55 bucks. worked great except the wiring and relays sucked and the relay for the lights and high beam pull in fried so i has to re wire it. the bulbs and ballasts are still good after 4 years so id say do it its cheap enough. and if all else fails just use the bulbs and ballasts and fab the rest
Old Sep 12, 2011 | 01:18 PM
BMcEL's Avatar
Install a set of these projectors in some cheap ebay housings. You get what you pay for with the cheap HID kits...and running HIDs in reflector housings designed for halogen bulbs isn't much of an upgrade. Note that the ebay 'projector' housings are NOT real projectors. My $.02.
Old Sep 12, 2011 | 02:00 PM
wolf28's Avatar
i just want a simple plug and play upgrade
Old Sep 12, 2011 | 02:20 PM
BMcEL's Avatar
If you insist on HID and just want the 'cool' HID look, just get some H4 conversion housings and an HID kit. Plug & play.
If you want an upgrade, get some Autopal or Hella H4 housings and some QUALITY halogen bulbs. Also plug & play. I highly recommend 4crawler's wiring harness upgrade if you stick with halogen, especially if you run high wattage bulbs.
The only thing better than Autopal or Hella housings and good halogen bulbs is the HID true projector kit I listed above, but it requires some modification to the housings.
Old Sep 12, 2011 | 02:24 PM
wolf28's Avatar
dont i need an adapter for the stock wires
Old Sep 12, 2011 | 02:27 PM
BMcEL's Avatar
No. The stock connector plugs right into H4 bulbs.
Old Sep 12, 2011 | 02:47 PM
wolf28's Avatar
i think ill just get the h4 conversion lenses then order h4 HIDs
next question wheres the best plase to get the new 4h conversion lenses
Old Sep 12, 2011 | 03:07 PM
BMcEL's Avatar
If you're going for cheap, it doesn't get much cheaper than ebay.
I just saw your other thread on this...instead of posting multiple threads asking the same questions, try searching. If you can't find what you're looking for, create one thread.
Good luck, welcome to YotaTech, and let us know how the HIDs turn out.
coreyedwards7611
Jan 16, 2016 06:38 PM
clok
Nov 19, 2015 01:09 PM
Edionne13
Jul 9, 2015 01:59 PM
LSUMatt1514
Jul 9, 2002 03:26 PM
