General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Help!! Fuse melting
Old Jul 1, 2007 | 05:51 PM
jonboy99's Avatar
Help!! Fuse melting
I have a 1988 22RE pickup. My problem is that the hot wire that is coming into the fuse box for the EFI relay is getting hot and melting the fuse. I have run a direct wire from the battery into the fuse box but it still heats the fuse and the relay up. So I think it might be the mass air flow sensor, but I'm not sure. Anybody got any ideas?
Old Aug 23, 2008 | 01:21 AM
4wheeler808's Avatar
Check Main Relay And Connecting Relay.......could Be Bad
Old Aug 23, 2008 | 08:07 AM
4Crawler's Avatar
Find out what is pulling too much current on that circuit. Common cause is an O2 sensor wire that has fallen against the hot exhaust, melting the insulation and causing a short.
Old Sep 4, 2008 | 03:01 PM
894x4pickup's Avatar
Take the black top off the AFM and make sure all the little metal contacts are facing up and not touching any other of the contacts...thats what happened to me...
Old Oct 4, 2008 | 05:20 AM
dj86515's Avatar
Hi all,
I went to wash my truck yesterday and rinsed the underbody near the motor and the check engine light began flashing. Drove for 7 miles, gassed up and proceeded, when the truck died. Its turning over but no fuel from fuel pump to filter. Replaced the fuel pump, but still no start. Found a bad EFI fuse (located on right in underhood fuse box) to replaced, tried again, but fuse blew again. Any advice would help. Thanks. DJ
Old Oct 4, 2008 | 05:31 AM
4Crawler's Avatar
Likely a wire to the O2 sensor has shorted out either with the water or by touching the hot exhaust and melting the insulation. Check the stored code:
- http://www.4crawler.com/4x4/CheapTri...CheckConnector
Old Oct 4, 2008 | 10:19 AM
dj86515's Avatar
Thanks for reply 4Crawler,
Slight progress. The vehicle started, drove it for a couple miles but the fuse burnt out again.
Old Oct 5, 2008 | 05:02 PM
dj86515's Avatar
Hi all,
With the help here, I discovered small cracks near the base of the O2 sensor plug wires at the exhaust manifold. Elec taped them and no more blown fuse, however, the CEL flashes every now and then. Wondering if I gotta get a new O2 sensor now. The DD truck runs though and thanks, esp to 4Crawler. DJ
Old Nov 5, 2008 | 05:05 PM
dj86515's Avatar
Hello again,
I was ok there for a few weeks, until this morning after 30 miles of travel on melted snow slush puddles (wet). I pulled over on the side of the road to let my dogg off. I went to start the truck, nothing...took out 3 fuses instantly. Girlfriend came in the 4Runner, towed truck for 10 miles and let it sit at a store for about 3 hours. Came back to the truck to tow it again but she said maybe it dried by now. I throw a new fuse in there and fires up andI returned. Lost confidence now that the girlfriend knows wuts up with the truck. Any suggestions would help. Thanks again. DJ
Old Nov 5, 2008 | 05:15 PM
4Crawler's Avatar
Would help to tell us what fuses are blowing out, or is it one fuse blowing out 3 times in a row? Find out what items are on the circuit of the fuse(s) that are going out and try systematically eliminate things on that circuit until the fuse no longer blows out.
Old Nov 5, 2008 | 05:45 PM
dj86515's Avatar
That would help, sorry.
It is the EFI fuse (15) that blows out and did blow out after 3 replacements in a row this morning. Thanks. DJ
Old Nov 5, 2008 | 05:57 PM
akaphilly's Avatar
i'd check your pervious fix on the 02 sensoe wire.. really clean it up and seal it nicely.
RyanJ989
11
Apr 7, 2021 09:41 AM
bryan34w
12
Sep 30, 2015 02:50 PM
Scotttekoch
Sep 28, 2015 10:30 PM
JPV
Sep 28, 2015 03:15 PM
Rcbc92
Sep 26, 2015 03:00 PM
