General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
EFI fuse keeps blowing?
Old Oct 30, 2010 | 02:54 PM
92Yotaa's Avatar
Angry EFI fuse keeps blowing?
on my 92 yota 22re my EFI fuse keeps blowing i cant figure out whats causeing it any ideas???
Old Oct 30, 2010 | 07:04 PM
4Crawler's Avatar
Common cause is an O2 sensor wire that has fallen against the hot exhaust causing the insulation to melt and the wires inside to short.
Old Oct 30, 2010 | 11:17 PM
92Yotaa's Avatar
yeah thats happened before but i dont even have the o2 sensor hooked up the wires are taped and tied off to the frame could it just be from it not being hooked up?
Old Nov 10, 2010 | 04:13 PM
macktowninmate's Avatar
I have the same problem. Just started in the last week or so. Was told by the dealer it could also be the EFI relay or circuit opening relay under dash. Mine blows fuse when I turn key to start. Thought it might be the fuel pump, but removed the circuit opening relay to test it, and problem is still there. Fuse went last week when wife was driving down the road. All relays seem to test ok. 95 x-cab 4x V6 auto. Any thoughts?
Old Mar 9, 2011 | 11:36 AM
royboy's Avatar
Make sure that your ground wire from the bat to the engine is first rate and check the ground wire for the efi circuits( located on the passenger side of the motor just below the aluminum air intake, about in the middle,a large wire bolted on). Good luck!
Old May 8, 2016 | 08:11 PM
Diego toyota's Avatar
Did you ever get that fuse blowing situation fix. I'm having the same problem with the EFI fuse. Took mine to the shop, was there for a week. Problem was not found.
Old May 8, 2016 | 08:15 PM
I'm having the Same problem. Did you ever fix the blowing of the fuse? Mine was in the shop for 1 week, they could not find it, maybe you can help. Thanks
Old Jul 10, 2018 | 09:30 AM
Bonnie Chalmers's Avatar
Did you get your fuse problem fixed, having same issue with a 1995 corolla, not o2 sensor, changed the ignition switch, bit the fuse keeps blowing as soon as the key is turned to acc, before the crank up
Old Jul 10, 2018 | 02:28 PM
RAD4Runner's Avatar
You absolutely sure the EFI fuse blows when you turn switch to ACC? Please see signature.
Post on APPRORIATE FORUM (MODEL-year), get multi-meter, find Schematic and share here and we'll help you.
Old Jul 10, 2018 | 07:15 PM
what did I not do! The tests you mentioned, I did plus more. Mine happened to be the fuel pump in the tank. Try taking yours out to test. You don’t have much choice but to be patient with the efi.
Gutted91
Jan 3, 2020 09:48 AM
bryan34w
12
Sep 30, 2015 02:50 PM
JPV
Sep 28, 2015 03:15 PM
Rcbc92
Sep 26, 2015 03:00 PM
Gutted91
Sep 17, 2015 05:44 PM
