General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Daytime running lights
Old Jan 1, 2013 | 05:44 PM
EmtLawson's Avatar
How do I disconnect the daytime running lights on my 00 tacoma?
Old Jan 3, 2013 | 08:51 AM
Hadmatt54's Avatar
The headlight circuit wiring between a Tacoma that has Daytime Running Lights and one that does not is not even close to being similiar. If your truck has a factory DRL system, you can't disconnect it. To start with the coil side of the main headlight relay goes to ground through the Main Daytime Running Light Relay.
If you pull the 7.5 a DRL fuse you disable the coil side of Day Time Running Light Relay #4, but your headlights won't work at all, because the contact side of this relay allows current from the high and low beam headlights to flow to ground.
Having said that I have to ask the question :- Why would you want to disable the DRL system?
It's a safety system like airbags and seatbelts...would you want to disable those?
Almost all of the studies done around the world indicate that DRL's reduce the number of multiple vehicle daytime crashes.
Check out the link below.
http://www.iihs.org/research/qanda/drl.aspx
Old Jan 3, 2013 | 09:40 AM
brianh699's Avatar
Some army bases require drl's to be disabled on vehicles on base,not sure why. On my 02 corolla I had to pull a wire from the drl relay and isolate it which disabled them. Do a search on Google for Toyota daytime running light disable there is TSB for dealers out there.
Old Jan 3, 2013 | 09:43 AM
EmtLawson's Avatar
Thanks for the advice ill google it and see what I can do
Old Jan 3, 2013 | 03:40 PM
brianh699's Avatar
Not sure if you found it but here's a link to a procedure for 4runner. https://www.yotatech.com/~corey/tech..._drl/ducky.htm
Old Jan 3, 2013 | 07:17 PM
EmtLawson's Avatar
Hey thanks alot I'm gonna give it a shot to disconnect them.
Old Jan 4, 2013 | 02:18 AM
dropzone's Avatar
Fossilized
Which Army posts require DRL's to be disabled?
Old Jan 4, 2013 | 08:09 AM
EmtLawson's Avatar
I hadn't ever heard of that myself till the person said that. I'm just disabling mine because of my hid kit
Old Jan 4, 2013 | 09:01 AM
Cameoman53's Avatar
When i installed my hid on my 00 tacoma the DRL relay was by the battery on the drivers side up by the headlights its a little box that looks like it has a heat shield on it, just uplug the cable and no more DRL
Old Jan 4, 2013 | 05:41 PM
brianh699's Avatar
Misquoted when I said army bases should've said military bases. That's what the TSB from Toyota says anyway.
ashersullivan88yota
Jan 18, 2022 05:37 PM
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
Johntom240
7
Jul 13, 2015 12:18 AM
madxman21
Jul 9, 2015 10:26 AM
