General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
'89 4x4 intermittent starting issues (relay?)
Old Aug 30, 2010 | 04:16 PM
cLandstreicher's Avatar
Hey guys,
I've been having an intermittent problem with starting my 4-cylinder 4x4 pickup. From what I've read, it sounds like the starter relay needs to be replaced since I know it isn't the starter itself.
What I'm looking for is the location of the starter relay. The junction box behind the battery didn't contain it, nor did the panel on the driver's side in the cab have the relay in it.
Here are the symptoms, if you're curious. If I turn off my truck after driving for an extended period, I'm unable to start the truck again until it cools down sufficiently. When I turn the ignition, there is a single click and a quiet hum. I get power to my stereo, lights, etc..
Does anyone have any other ideas of what the problem could be?
Thanks in advance!
Old Aug 30, 2010 | 04:35 PM
c0ugar69's Avatar
It could be the relay, or the clutch switch if not pushing clutch down far enough, also i can still be the starter. there is a contact in the starter that can go out or bad and then it will start sometimes and just click other times. my guess is the starter. you can clean the contacts, look at my build thread for the part where i take the starter apart and clean the contacts.
Old Aug 30, 2010 | 04:37 PM
c0ugar69's Avatar
https://www.yotatech.com/forums/f199...thread-207740/
Old Aug 30, 2010 | 04:51 PM
Thanks c0ugar, I'll look into that. I should have mentioned that I have an automatic transmission. Also I had a warranty on the starter and replaced it for free, but the problem persists.
Old Aug 30, 2010 | 04:59 PM
broncrider's Avatar
sounds like a fuel pump problem to me. test the fuel pressure to see how strong your pump is
Old Aug 30, 2010 | 05:04 PM
c0ugar69's Avatar
thats good. So if you got a replacement starter and it is still clicking the i thinks it the relay. I am pretty sure mines in the driverside kick panel.
Old Aug 30, 2010 | 05:53 PM
4Crawler's Avatar
Relay location below:
- http://www.4crawler.com/4x4/CheapTri...l#OtherOptions
Old Sep 18, 2010 | 03:21 AM
skypilot's Avatar
I have an '88. check the ground under the starter relay on the right hand fender. should be round. look for corrosion and clean real well, perhaps some aluminum wire grease (used by electricians) to lube the retaining bolt before tightening into place.
If all else fails wire in a momentary push me switch to the starter solinoid lead in parallel with the current one. So when the key does not roll it, you can flick the swicth to start.
sonic concepts
Aug 16, 2025 03:13 PM
rbravo1
Jun 29, 2015 01:34 PM
sharrack
Jun 26, 2015 09:33 AM
slider417
Jun 22, 2015 10:18 AM
Dennis140
Jun 17, 2015 10:37 AM
